ArcGIS requirements for using PostgreSQL
ArcGIS Enterprise and ArcGIS Pro support connections to PostgreSQL databases and enterprise geodatabases in PostgreSQL.
Visit Esri Technical Support for information about the Esri Supported Environment Policy.
The information below applies to ArcGIS Enterprise 12.1 and ArcGIS Pro 3.7.
Minimum supported database versions
The following versions of PostgreSQL and PostGIS are supported with ArcGIS. The specific versions listed are the minimum minor version supported and certified for each supported major release of PostgreSQL and PostGIS. Later minor versions are supported but are not certified unless otherwise stated. The PostgreSQL version and updates must also be supported by the PostgreSQL Global Development Group.
PostgreSQL 18.1 (64 bit)
- PostGIS 3.6.1
PostgreSQL 17.7 (64 bit)
- PostGIS 3.6.1
PostgreSQL 16.11 (64 bit)
- PostGIS 3.6.1
PostgreSQL 15.15 (64 bit)
- PostGIS 3.6.1
PostgreSQL 14.20 (64 bit)
- PostGIS 3.6.1
Due to changes in PostgreSQL data type support, if your database contains a geodatabase, you must use the pg_dump and pg_restore commands to upgrade PostgreSQL from 11.x or earlier to one of the versions listed above. When you use this method to upgrade, it removes unused, unsupported OID fields from geodatabase system tables that would otherwise block you from upgrading PostgreSQL.
After you upgrade to a supported PostgreSQL release, if the database contains a geodatabase, ArcGIS 10.8 and earlier clients and ArcGIS Pro 2.5 and earlier can no longer use the data; you must upgrade your ArcGIS clients.
Esri tests and certifies PostgreSQL installations that are available from PostgreSQL.org. For each PostgreSQL release that Esri supports, available PostGIS modules are also tested and certified. No other modules extending PostgreSQL functionality are included in Esri certification.
A supported PostgreSQL installation for Microsoft Windows is available for download from My Esri.
Cloud support
See Requirements for using ArcGIS with databases in the cloud for information about support for database services and databases deployed in the cloud.
Supported operating systems for ST_Geometry
The following operating systems have been tested and are the minimum supported version for the ST_Geometry library. If you use a database or geodatabase in PostgreSQL that uses the ST_Geometry type, the PostgreSQL database cluster must be installed on one of these operating systems.
The operating system version and updates you use must also be supported by the operating system provider.
Microsoft Windows
To use the ST_Geometry type in PostgreSQL on Windows, you need the latest Microsoft Visual C++ Redistributable for Visual Studio 2015–2022 installed on the PostgreSQL machine. See the latest supported Visual C++ downloads from Microsoft support for more information.
Production environments
Supported operating system |
Latest update or service pack tested |
Windows Server 2025 Standard and Datacenter |
April 2026 update |
Windows Server 2022 Standard and Datacenter |
April 2026 update |
Windows Server 2019 Standard and Datacenter |
April 2026 update |
Development environments
Windows 11 Pro and Enterprise |
April 2026 update |
Prior and future updates or service packs for these operating system versions are supported unless otherwise stated. The operating system version and updates must also be supported by the operating system provider.
Linux
The Linux operating systems listed below have been tested.
ST_Geometry on Linux requires the precesence of libstdcc++.so.6.0.29 on the PostgreSQL server. If you use the ST_Geometry type on a Linux operating system that does not have that version of the libstdcc++.so.6 library present, copy the libstdcc++.so.6 library with the st_geometry.so library from My Esri when you create or upgrade a geodatabase in PostgreSQL that uses the ST_Geometry type or add or upgrade ST_Geometry in a PostgreSQL database.
Red Hat Enterprise Linux Server 8 |
Update 10 |
Red Hat Enterprise Linux Server 9 |
Update 7 |
AlmaLinux 8 |
Update 10 |
AlmaLinux 9 |
Update 7 |
SUSE Linux Enterprise Server 15 |
Service Pack 7 |
Ubuntu Server 24.04 LTS |
24.04.3 |
Ubuntu Server 22.04 LTS |
22.04.5 |
Oracle Linux 8 |
Update 10 |
Oracle Linux 9 |
Update 6 |
Rocky Linux 8 |
Update 10 |
Rocky Linux 9 |
Update 7 |
Database requirements and limitations
When you use a database connection file (.sde) to access PostgreSQL data in ArcGIS Pro, you can only edit data that is registered with the geodatabase. To edit database data, publish an editable web feature layer that references the database data, and edit through the web feature layer.
EDB Postgres Advanced Server
ArcGIS supports EDB Postgres Advanced Server. Supported versions are based on the minimum certified PostgreSQL and PostGIS versions listed in the previous section.
You can use the Create Enterprise Geodatabase geoprocessing tool to create a geodatabase in EDB Postgres Advanced Server. Only the PostGIS spatial type is supported in EDB Postgres Advanced Server, not ST_Geometry.
Connections to PostgreSQL
ArcGIS applications that can connect to a PostgreSQL database contain the PostgreSQL client libraries that are required to make a connection. These applications include ArcGIS Enterprise on Kubernetes, ArcGIS Server, and ArcGIS Pro.
