Prune Branch History (Data Management Tools)
Summary
Removes retired archive records from branch-versioned datasets.
Learn more about prune branch history
Usage
  • When no Prune Before Date parameter value is provided, the tool will prune as much of the archive history as possible based on referenced moments. When a Prune Before Date parameter value is provided, all rows will be removed up to that moment.
  • If the Prune Before Date parameter value is invalid due to a version or replica that is referencing a moment before the requested prune date, a warning message will be issued. The output log will report the earliest moment that can be used and will include the moment and version that blocked the tool.
    Learn more about referenced moments
  • The versioning type of the Input Dataset parameter value's geodatabase connection must be set to branch.
  • The Input Dataset value must be a table, feature class, or feature dataset that is registered as branch versioned. It cannot participate in any controller datasets, except a topology, parcel fabric, or utility network.
    While using this tool, if you receive an error message indicating that an upgrade is necessary, upgrade your geodatabase to the latest version. See this knowledge article for more details.
  • The tool can only be run by the data owner.
  • When the Input Dataset value is a feature dataset, all feature classes in that dataset and related data outside of the feature dataset will be processed, excluding data in another feature dataset.
  • If a feature class is in a feature dataset, use the feature dataset as the input.
  • An exclusive schema lock is required to run the tool. Services referencing the input data will need to be stopped using ArcGIS Server Manager.
Parameters
Label Explanation Data type
Input Dataset
The feature class, feature dataset, or table that will be pruned.
Table View; Feature Dataset
Output Log File
A log file that reports the feature classes and tables that were pruned or will be pruned. The output file will also list the replicas and versions that prevented using the requested prune before date.
File
Report Only
(Optional)
Specifies whether the eligible archive records will be reported or pruned.
  • Checked—The eligible archive records will be reported to the log file; they will not be pruned. This is the default.
  • Unchecked—The eligible archive records will be pruned.
Boolean
Only Prune System Tables
Specifies whether only the eligible internal tables will be reported or pruned.
  • Checked—Only the eligible internal tables of the extension datasets will be pruned or reported to the log file.
  • Unchecked—All eligible tables will be pruned or reported to the log file. This is the default.
Boolean
Prune Before Date
(Optional)
Archive records that are older than the date and time provided will be pruned. The date and time must be in UTC. If no date is provided, the oldest referenced moment in the database will be used.
Date
Derived output
Output Dataset
The updated dataset.
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
