Share Package (Data Management Tools)
Summary
Shares a package by uploading it to ArcGIS Online or ArcGIS Enterprise.
Usage
  • The following are supported package types:
  • The package file size limit is 500 GB. For more information, see Considerations and limitations.
    Tip:
    If you have a scene layer package that is larger than 500 GB and want to publish it as a web scene layer to ArcGIS Online, add it to a 3D scene and share it as a web scene instead. The scene layer package is published as a web scene layer with the web scene. If you have a scene layer package in a scene, you can share it as a web scene layer directly. Right-click the layer, point to the Sharing menu, and click Share As Web Layer .
  • You cannot enter your ArcGIS Online or ArcGIS Enterprise username and password when using this tool in ArcGIS Pro. The tool will obtain your credentials from ArcGIS Pro. You must be signed in and connected to ArcGIS Online or ArcGIS Enterprise before you can share a package using this tool.
  • A summary and one or more tags are required when sharing a package to an ArcGIS Enterprise 10.9 or earlier portal. The summary and tags, along with an optional package description and credits, will be used when searching for packages online.
  • If a package of the same name exists in your ArcGIS Online or ArcGIS Enterprise organization, it will be overwritten.
  • If you share a tile package, scene layer package, or vector tile package, you can publish the package automatically as a web layer of the corresponding type. (A tile package is published as a web tile layer, a scene layer package as a web scene layer, and a vector tile package as a vector tile layer.) To publish a web layer successfully, you must have the necessary privileges in your active portal account.
  • To share a package to ArcGIS Online with a public account, your Esri Global Account must be registered as a member of ArcGIS Online. To create and register an Esri Global Account, go to arcgis.com/home/signup.html.
Parameters
Label Explanation Data type
Input Package
The input layer (.lpk or .lpkx), scene layer (.slpk), map (.mpk or .mpkx), geoprocessing (.gpk or .gpkx), tile (.tpk or .tpkx), mobile map (.mmpk), vector tile (.vtpk), address locator (.gcpk), or project (.ppkx or .aptx) package file.
File
Username
The ArcGIS Online or Portal for ArcGIS username.
This parameter is not available from the Geoprocessing pane. You must sign in to the active portal from the sign in option at the top of the application.
String
Password
The ArcGIS Online or ArcGIS Enterprise password.
Encrypted String
Summary
(Optional)
The summary of the package. The summary is displayed in the item information of the package on ArcGIS Online or ArcGIS Enterprise.
String
Tags
(Optional)
The tags used to describe and identify the package. Separate multiple tags with a comma.
String
Credits
(Optional)
The credits for the package. This is typically the name of the organization that is given credit for authoring and providing the content for the package.
String
Share with everyone (public)
(Optional)
Specifies whether the input package will be shared with and available to the public.
  • Checked—The input package will be shared with the public. Anyone can access and see it.
  • Unchecked—The input package will be shared with the package owner and any selected groups. This is the default.
Boolean
Groups
(Optional)
The groups the package will be shared with.
String
Share within organization only
(Optional)
Specifies whether the input package will be available within your organization only or shared publicly with everyone.
  • Checked—The package will be shared with the public. Anyone can access and see it. This is the default.
  • Unchecked—The package will be shared within your organization only.
Boolean
Publish web layer
(Optional)
Specifies whether the package will be published as a web layer to your portal. Only tile packages, vector tile packages, and scene layer packages are supported.
  • Checked—The package will be uploaded and published as a web layer with the same name.
  • Unchecked—The package will be uploaded without publishing. This is the default.
Boolean
Folder
(Optional)
An existing folder or the name of a new folder on the portal for the package. If a web layer is published, it is stored in this folder.
String
Derived output
Tool Succeeded
The result of uploading the package and publishing the web layer if specified. Returns True when successful.
Boolean
Publish Results
The JSON response containing the service URL and portal item ID of the web layer.
String
Package Item ID
The portal item ID of the package.
String
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
