Create Mobile Scene Package (Data Management Tools)
Summary
Creates a mobile scene package file (.mspk) from one or more scenes for use across the ArcGIS system.
Usage
  • Mobile scene packages can be used in ArcGIS Pro and by developers building applications with ArcGIS Maps SDKs. Mobile scene packages are supported as a file type in ArcGIS Online and Portal for ArcGIS 10.7 and later. See Share a mobile scene package for more information.
  • Mobile scene packages can be imported into ArcGIS Pro using Import Map on the Insert tab in the Project group.
  • When creating a mobile scene package, all scenes and data layers will be projected to a common coordinate system. The coordinate system that will be used is the coordinate system of the scene. If there are multiple scenes, the first input scene coordinate system will be used. Faster processing time can be achieved by ensuring that all datasets are in the same coordinate system. Currently, ArcGIS Maps SDKs applications only support global scenes in the WGS84 and Web Mercator Auxiliary Sphere coordinate systems.
  • If the scene contains service layers, vector tile packages (.vtpk file), or tile packages (.tpk file), ensure that their coordinate system matches the scene's coordinate system in the scene properties or basemap coordinate system. Packages that have a coordinate system other than that of the scene will be blocked from the mobile scene package. Both the horizontal (x,y) coordinate system and vertical coordinate (z) system must match the scene's coordinate system. See Work with coordinate systems for detailed steps on updating a scene's coordinate system.
  • If the scene contains a network layer that references a network dataset, it will be included in the mobile scene package as a transportation network for routing and driving directions. All feature classes and tables that the network references will become part of the mobile scene package. This may include layers that are not part of the scene. For example, if there is only a network layer in the map, the package will include the streets, junctions, and turns feature classes associated with the network. See Author a mobile scene package for ArcGIS Maps SDKs for additional considerations.
  • You can use the interactive edit tool to define the area of interest (AOI) by drawing a rectangle on the ground of the scene. If an extent is not specified, the current scene extent will be used to define the AOI and consolidate only those features that intersect that extent. See Area of interest considerations for details.
  • Mobile scene packages are optimized for 3D visualization, and multipatch feature layers, 3D point feature layers, and LAS dataset layers will be converted to scene layer packages for fast drawing. See Operational layers in mobile scenes for more information on how layers are packaged in a mobile scene package.
  • The following table lists supported input data and how the output data is converted or copied in the mobile scene package. It also lists whether the data can be reprojected to the scene's coordinate system. Datasets that cannot be reprojected will be blocked as input to the Create Mobile Scene Package tool.
    Source
    Dataset in mobile scene package
    Reprojection of data supported
    2D Point, Line, or Polygon Feature Layer
    SQLite Feature Class
    Yes
    3D Point Feature Layer
    Scene Layer Package
    Yes
    Multipatch Feature Layer
    Scene Layer Package
    Yes
    LAS Dataset Layer
    Scene Layer Package
    Yes
    3D Tiles Layer
    3TZ
    No
    Scene Layer Package
    Scene Layer Package
    Yes
    Raster Layer
    Raster Dataset
    Yes
    Elevation Source
    Tile Package or Raster Dataset
    Yes for Raster Dataset
    Tile Package
    Tile Package
    No
    Network Layer
    Transportation Network
    Yes
    KMZ or KML
    KMZ or KML
    No
    Table
    SQLite Table
    No
    Service Layer
    Service Layer
    No
    Caution:
    Scenes that contain large or many datasets may require significant processing time to convert the data for use in the mobile scene package.
Parameters
Label Explanation Data type
Input Scene
One or more local or global scenes that will be packaged into a single .mspk file. Active scenes and .mapx files can be added as input.
Map
Output File
The output mobile scene package .mspk file.
File
Input Locator
(Optional)
One or more locators (.loc file) that will be included in the mobile scene package.
Locators have the following restrictions:
  • The locator cannot have an unknown coordinate system.
  • The locator or any participating locator in a composite locator cannot be a geocoding service, including services from ArcGIS Enterprise or ArcGIS Online.
Address Locator
Area of Interest
(Optional)
A polygon layer that defines the area of interest. Only those features that intersect the area of interest will be included in the mobile scene package.
Feature Layer
Extent
(Optional)
Specifies the extent that will be used to select or clip features.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Intersection of Inputs Intersect—The extent will be the intersecting extent of all inputs.
  • Union of Inputs Union—The extent will be the combined extent of all inputs.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Clip Features
(Optional)
Specifies whether the output features will be clipped to the given area of interest or extent.
Multipatch feature layers, 3D point feature layers, LAS dataset layers, service layers, and tile packages cannot be clipped and will be completely copied to the mobile scene package.
  • Checked—The geometry of the features will be clipped to the given area of interest or extent.
  • Unchecked—Features in the map will be selected and their geometry will remain unaltered. This is the default.
Boolean
Title
(Optional)
Title information that will be added to the properties of the package.
String
Summary
(Optional)
Summary information that will be added to the properties of the package.
String
(Optional)
Description information that will be added to the properties of the package.
String
Tags
(Optional)
Tag information that will be added to the properties of the package. Multiple tags can be added, separated by a comma or semicolon.
String
Credits
(Optional)
Credit information that will be added to the properties of the package.
String
Use Limitations
(Optional)
Use limitations that will be added to the properties of the package.
String
Enable Anonymous Use
(Optional)
Specifies whether the mobile scenes can be used by anyone or only those with an ArcGIS account.
License:
This optional parameter is only available with the Publisher extension.
  • Checked—Anyone with access to the package can use the mobile scene without signing in with an Esri named user account.
  • Unchecked—Anyone with access to the package must be signed in with a named user account to use the mobile scene. This is the default.
Boolean
Texture Optimization
(Optional)
Specifies the textures that will be optimized according to the target platform where the scene layer package is used.
Caution:
Optimizations that include KTX2 may take significant time to process. For fastest results, use the Desktop or None options.
  • All—All texture formats will be optimized including JPEG, DXT, and KTX2 for use in desktop, web, and mobile platforms.
  • Desktop—Windows, Linux, and Mac supported textures will be optimized including JPEG and DXT for use in ArcGIS Pro clients on Windows and ArcGIS Maps SDKs desktop clients on Windows, Linux, and Mac. This is the default.
  • Mobile—Android and iOS supported textures will be optimized including JPEG and KTX2 for use in ArcGIS Maps SDKs mobile applications.
  • None—JPEG textures will be optimized for use in desktop and web platforms.
String
Enable Scene Expiration
(Optional)
Specifies whether the mobile scene package will time out.
License:
  • Checked—Time-out functionality will be enabled on the mobile scene package.
  • Unchecked—Time-out functionality will not be enabled on the mobile scene package. This is the default.
Boolean
Scene Expiration Type
(Optional)
Specifies the type of scene access that will be used for the expired mobile scene package.
License:
  • Allow to open—The user of the package will be warned that the scene has expired and allowed to open the scene. This is the default.
  • Do not allow to open—The user of the package will be warned that the scene has expired and will not be allowed to open the package.
String
Expiration Date
(Optional)
The date the mobile scene package will expire.
License:
Date
Expiration Message
(Optional)
The text message that will appear when an expired scene is accessed.
License:
String
Keep only the rows that are related to features within the extent
(Optional)
Specifies whether the specified extent will be applied to related data sources.
  • Checked—Only related data corresponding to records within the specified extent will be consolidated.
  • Unchecked—Related data sources will be consolidated in their entirety. This is the default.
Boolean
Reference online content
(Optional)
Specifies whether service layers will be referenced in the mobile package.
  • Checked—Service layers will be referenced in the mobile package.
  • Unchecked—Service layers will not be referenced in the mobile package. This is the default.
Boolean
Environments
Parallel Processing Factor
Special cases
If the Parallel Processing Factor value is empty (blank), the tool will run with a default value of 50 percent (one-half) of the available cores.
Licensing information
  • Basic: Limited
    Some parameters are limited by the Publisher extension—see the tool reference page for more detail.
  • Standard: Limited
  • Advanced: Limited
