Operational layers in mobile scenes
Operational layers are overlaid on top of the basemap of a scene. Operational layers are often interactive and tell the story of a scene. They can include KML layers, feature layers, LAS dataset layers, scene layers, and raster layers. Operational layers can be visualized differently depending on the source data. Supported operational layers in a mobile scene package as well as items to consider before creating a mobile scene package are discussed below.
Feature layers
In ArcGIS Pro, feature layers can be organized in the 3D Layers or 2D layers category in the Contents pane. If a point feature layer is in the 3D Layers category, it is exported as a scene layer package when you package a mobile scene. Point feature layers in the 2D layers category are written to the SQLite database. Line or polygon feature layers in the 3D or 2D category are written to the SQLite database. Multipatch feature layers are exported to a scene layer package when you package a mobile scene.
Consider the following for data that is exported to a scene layer package:
ArcGIS Maps SDKs supports only absolute height elevation mode for feature layers. Review the base height for each layer on the elevation property page before creating a mobile scene package.
Extents are not supported in the create scene layer package tools. The Area of Interest parameter in the Create Mobile Scene Package tool is not honored when exporting to scene layer packages. Select the features you want to include in the package and make a selection layer before packaging a mobile scene. See Area of interest considerations for details.
Real-world units are required when sharing 3D point feature layers symbolized with 3D model markers. This functionality is available on the Display tab on the Layer Properties dialog box.
Custom point symbology using Arcade expressions is not supported.
Procedural symbol layers are not supported.
KML layers
KML layers are supported in a mobile scene package. These files are only supported in global scenes in a WGS84 horizontal coordinate system. KML layers cannot be clipped or reprojected. Ensure that no network links are present in the KML layer before packaging it in a mobile scene package.
LAS dataset layers
LAS dataset layers are supported and are exported as a point cloud scene layer package when you package a mobile scene. LAS dataset layers are projected to the scene's coordinate system. Currently, clipping of LAS datasets is not supported. Use the Extract LAS tool before running the Create Mobile Scene Package tool if clipping is required.
Default values for Point Size, XY Max Error, and Z Max Error are used when exporting to a point cloud scene layer package. If additional configurations are required, consider using the Create Point Cloud Scene Layer Package tool and adding the scene layer package to the scene before running the Create Mobile Scene Package tool.
Raster layers
Raster layers are supported as operational layers or as basemap layers when you package a mobile scene. Raster layers are clipped or reprojected to the scene's horizontal coordinate system.
3D tiles layers
3D tiles layers of type integrated mesh are supported as operational layers. 3D tiles layers are consolidated into a 3D tiles archive file in the mobile scene package. 3D tiles layers cannot be clipped or reprojected. A 3D tiles layer of type 3D object is removed in the output mobile scene package as it is not currently supported.
Tile packages
Tile packages are supported as an operational layer or basemap layer when running the Create Mobile Scene Package tool. Because tile packages are cached datasets, they cannot be clipped or reprojected. An error may appear at tool execution indicating that the coordinate system does not match the scene coordinate system. Either re-create the tile package in the new coordinate system or update the scene coordinate system.
Vector tile packages
Vector tile packages are supported as an operational layer or basemap layer when running the Create Mobile Scene Package tool. Because vector tile packages are cached datasets, they cannot be clipped or reprojected. An error may appear at tool execution indicating that the coordinate system does not match the scene coordinate system. Either re-create the vector tile package in the new coordinate system or update the scene coordinate system.
Services
Services are supported in mobile scene packages to support hybrid offline and online workflows in ArcGIS Maps SDKs apps. For example, when the mobile device is connected, you can access weather or traffic information in real time. The following services are supported in a mobile scene package:
Service |
Supported in mobile scene package |
Scene service |
Yes |
Cached map service |
Yes |
Dynamic map service |
Yes |
Image service |
Yes |
KML service |
Yes |
Stream service |
No |
Vector tile service |
Yes |
Older ArcGIS Maps SDKs apps may not support services in a mobile scene package.
Scene layer packages
Point, 3D object, integrated mesh, and point cloud scene layer packages are supported in a mobile scene package. You can clip 3D Object, integrated mesh, and point cloud scene layer packages. You can reproject all scene layer types to WGS84 or Web Mercator Auxiliary Sphere when creating a mobile scene package.
By default, the create scene layer package tools create a scene layer package in the WGS84 horizontal coordinate system and the EGM96 vertical coordinate system.
The table below lists the supported input data and notes how the output data is converted or copied in the mobile scene package. It also specifies whether the data can be reprojected to the scene's coordinate system. Datasets that cannot be reprojected are blocked as input to the Create Mobile Scene Package tool.
Source dataset |
Dataset in mobile scene package |
Reprojection of dataset supported |
2D point, line, or polygon feature layer |
SQLite feature class |
Yes |
3D point feature layer |
Scene layer package |
Yes |
Multipatch feature layer |
Yes |
LAS dataset layer |
Yes |
Yes |
3D tiles layer |
3TZ |
No |
Raster layer |
Raster dataset |
Yes |
Tile package |
Tile package |
No |
Vector tile package |
No |
KMZ or KML |
KMZ or KML |
No |
Table |
SQLite table |
No |
Unsupported layers
The following layers are currently not supported in mobile scene packages:
Voxel layer
Integrated mesh modification layer
Graphics layer
Map notes layer
Building layer
Utility network layer
Geostatistical analyst layer
3D object 3D tiles layer
