Work with coordinate systems
A coordinate system is a reference framework that defines the position of features in two- or three-dimensional space. Maps and scenes use coordinate systems to locate and display data correctly on the earth's surface and relative to one another. Coordinate systems can be defined in maps and scenes.
Coordinate systems can be horizontal, defining where features are across the globe, or vertical, defining how high or deep features are relative to a surface. Horizontal coordinate systems can be geographic or projected. Projected coordinate systems are composed of a geographic coordinate system and a map projection.
A map or scene should always have a horizontal coordinate system. Optionally, you can also define a vertical coordinate system. In a new, empty map or local scene, the default horizontal coordinate system is WGS84 Web Mercator. For global scenes, the default horizontal coordinate system is WGS84. There are numerous coordinate systems to choose from for maps and local scenes, but the horizontal coordinate system for a global scene is limited to WGS84 or China Geodetic Coordinate System 2000 (CGCS 2000). See the topic on scenes to understand the differences between local and global scenes.
Empty maps and scenes derive their coordinate systems from the first layer added to them. When you add more layers to a map or scene, they are automatically displayed using the current coordinate system of the map or scene. If the map or scene's geographic coordinate system is different than the geographic coordinate system of the layer, the data is projected in real time using a transformation.
Caution:
Projecting data in real time can take longer to draw and is not advisable if you are editing data or performing analysis. It is better to ensure that all the data is in the same coordinate system. Use the Project or Project Raster tool to project spatial data from one coordinate system to another.
Follow the steps below to choose or import a coordinate system, or you can create a coordinate system instead.
Set the coordinate system
You can set the coordinate system of a map or scene directly, you can define it from a layer in the map or scene, or you can set it from another data source. In some specific workflows, you may need to use an unknown coordinate system.
Choose a coordinate system from a list
Follow these steps to set the coordinate system directly by choosing one from a list:
  1. In the Contents pane, right-click the map or scene and click Properties.
  2. On the Map Properties dialog box, click the Coordinate Systems tab.
    The Current Map Coordinate Systems heading shows the current horizontal and vertical coordinate systems of the map or scene, respectively. There may be no vertical coordinate system defined. Click the name of the coordinate system for either coordinate system (in blue text) to see how they are defined.
  3. To change the horizontal or vertical coordinate system, in the Available Coordinate Systems box, choose the Horizontal systems or Vertical systems tab.
  4. From the list of coordinate systems shown, choose an appropriate coordinate system for the map or scene.
    1. To learn more about a coordinate system, right-click it in the list and click Details to see the coordinate system parameters. The valid area of use for each coordinate system is specified in the list of details, and also visually as a blue rectangle on the map at the bottom of the dialog box. If the area is very small, it may appear as only a circular point instead.
    2. Optionally, search for coordinate systems. Enter a search term in the Search box to help locate a specific coordinate system.
    3. Optionally, filter the list of coordinate systems. Click the Filter Coordinate Systems button to filter by spatial extent, geographic coordinate system, or projection property. See the next section below for more information about filtering coordinate systems.
    4. In some troubleshooting workflows, it may be necessary to set the map to an unknown coordinate system.
  5. Click Apply to set the coordinate system, or click OK to apply the settings and close the Map Properties dialog box.
Choose a coordinate system by spatial extent, geographic coordinate system, or projection property
When you choose from the list of coordinate systems, you can filter the choices by specifying any combination of a spatial extent, a geographic coordinate system, and the projection property.
Download a poster that compares all the map projections.
To choose a coordinate system based on properties, complete the following steps:
  4. Click the Filter Coordinate Systems button to open the Filter Coordinate Systems dialog box to filter the list of available coordinate system as follows. You can filter by more than one method simultaneously.
    Filter coordinate system by Guidance
    Spatial extent Turn on the Spatial extent toggle button to filter the list of coordinate systems to those whose area of use partially intersects the specified spatial extent. See Set the map extent for more information about different ways to specify a spatial extent.
    Geographic coordinate system Turn on the Geographic coordinate system toggle button to filter the list of projected coordinate systems to those that have the specified geographic coordinate system as part of their definition.
    When setting a vertical coordinate system, ellipsoidal-based vertical coordinate systems are based on the same datum as their corresponding geographic coordinate system. This filter returns a matching pair.
    Projection property Turn on the Projection property toggle button to filter the list of projected coordinate systems by one of the following projection properties. This option is not available when setting vertical coordinate systems.
    Equal-area—Coordinate systems that are optimized to preserve relative areas.
    Conformal—Coordinate systems that are optimized to preserve local angles, which gives the appearance of preserving shape at the expense of area and distance.
    Equidistant from one point—Coordinate systems that are optimized to preserve distances only along lines running through the center point of the projected coordinate system (the point where the latitude of origin and the central meridian intersect). No projection can preserve distances in every direction everywhere on a map.
    Equidistant along meridians—Coordinate systems that are optimized to preserve north-south distances only. Distances in any other direction are not preserved. No projection can preserve distances in every direction everywhere on a map.
    Compromise—Coordinate systems that are optimized to preserve none of these properties specifically, but attempt to minimize the distortion for each property. Distortion can still become severe in certain places or circumstances.
  5. Click Apply to close the Filter Coordinate Systems dialog box.
  6. On the Map Properties dialog box, in the Available Coordinate Systems box, choose the Horizontal systems or Vertical systems tab and choose a coordinate system from the filtered list.
  7. Click Apply to set the coordinate system, or click OK to apply the settings and close the Map Properties dialog box.
Set the coordinate system from a layer
Follow these steps to define a coordinate system for a map or scene from a layer within it. It is recommended that you do this to ensure that all layers in a map share the same coordinate system.
  3. Under the Available Coordinate Systems heading, click the Horizontal systems or Vertical systems tab.
  4. In the list, expand the Layers folder. Expand a coordinate system heading to see the layers that reference it.
  5. To set the coordinate system from another data source, click the Add Coordinate System button and click Import Coordinate System . Browse to a data source (or previously saved .prj file) that is defined with the coordinate system you want to use. You can then add the coordinate system to your Favorites list to make it available to all your projects.
  6. Click Apply to set the coordinate system, or click OK to apply the settings and close the Map Properties dialog box.
Set the coordinate system from a data source
Follow these steps to define a coordinate system from a data source:
  3. Click the Add Coordinate System button and click Import Coordinate System . Browse to a data source (or previously saved .prj file) that is defined with the coordinate system you want to use.
  4. Click Apply to set the coordinate system, or click OK to apply the settings and close the Map Properties dialog box.
Save coordinate systems
If there are coordinate systems you use often in your projects, you can add them to your list of Favorites to make them easier to find. Favorites are available across all your projects. You can also save any coordinate system as a projection file (.prj file extension). Projection files can be used to define a coordinate system in geoprocessing.
If you are creating a geographic coordinate system that you want to reuse in a new projected coordinate system, you must save the geographic coordinate system as a favorite for it to appear in the list of geographic coordinate system choices in the projected coordinate system.
Tip:
If you have a lot of favorite coordinate systems, consider organizing them in a folder structure. Create folders to organize your favorite coordinate systems (.prj files) in your operating system. Find your coordinate system that's set as a favorite at [install drive]:\Users\[YourName]\AppData\Local\ESRI\ArcGISPro\Favorites. This structure is then reflected in the Available Coordinate Systems list.
Save a coordinate system as a favorite
Follow these steps to save a coordinate system as a favorite:
  4. In the list, right-click a coordinate system and click Add to Favorites to have the coordinate system appear under the Favorites heading in this list for easy reference.
Save a coordinate system as a projection file
You can save a coordinate system as a projection file (.prj) for reuse and sharing. Projection files contain a well-known text (WKT) representation of the coordinate system, initially defined by the Open Geospatial Consortium (OGC). Choose between the newer WKT2 standard, which is the default option, or the Esri WKT version, which is used in prior releases of ArcGIS Pro.
Dive in:
The WKT2 standard provides a representation of the coordinate reference system (CRS) data model standard. Read about this specification here: OGC Abstract Specification Topic 2: Referencing by coordinates, 18-005r4.
Follow these steps to save a coordinate system as a projection file:
  4. Right-click a coordinate system in the list and click Save as Projection File .
  5. On the Save Coordinate System as PRJ File dialog box, browse to a location on your file system, and type a file name.
    The default location to save the projection file is the Favorites folder, located at [install drive]:\Users\[yourname]\AppData\Local\ESRI\ArcGISPro\Favorites. If you save to this folder, the coordinate system you saved to a projection file will appear in the Favorites section in the Coordinate Systems Available list on the Map Properties dialog box.
  6. In the drop-down menu next to the file name, choose a WKT file format:
    • WKT2 (.prj)—This uses a more complete representation of the coordinate reference system (CRS) data model standard. This is the default.
    • Esri WKT (.prj)—This uses an Esri implementation of an earlier OGC WKT standard. Choose this option for use in versions prior to ArcGIS Pro 3.6.
  7. Click Save to save the projection file and close the Save Coordinate System as PRJ File dialog box.
Work with vertical coordinate systems
Maps and scenes must have a horizontal coordinate system defined, but a vertical coordinate system is optional. To set an ellipsoidal vertical coordinate system, it must share the same datum as the horizontal coordinate system. The datum name, the spheroid name, and all the spheroid properties of the two coordinate systems must exactly match.
If the current horizontal coordinate system is incompatible with the current vertical coordinate system, follow these steps to choose compatible horizontal and vertical coordinate system pairs:
  3. Under the Available Coordinate Systems heading, click the Vertical systems tab and choose Coordinate System None from the list.
  4. Under the Available Coordinate Systems heading, click the Horizontal systems tab and choose a coordinate system from the list with a datum that matches that of the ellipsoidal vertical coordinate system you need.
    To see a coordinate system's datum, right-click it in the list and click Details .
  5. Click the Vertical systems tab again and choose an ellipsoidal vertical coordinate system that shares the same datum from the list.
