Export Data Change Message (Data Management Tools)
Summary
Creates an output delta file containing updates from an input replica.
Usage
  • The geodatabase can be a local geodatabase or a geodata service.
  • The output delta file can be a delta file geodatabase (.gdb) or a delta XML file (.xml). When specifying the output delta file, you must include the appropriate suffix (.gdb or .xml).
  • Use this tool when synchronizing a replica while disconnected. First run the Export Data Change Message tool, which creates a delta file with changes to synchronize. Then copy and import the delta file to the relative replica using the Import Message tool. If the delta file gets lost and you want to resend, use the Re-Export Unacknowledged Messages tool to regenerate the delta file. After the changes are imported, you can export an acknowledgment file from the relative replica using the Export Acknowledgement Message tool. Copy and import the acknowledgment file using the Import Message tool. If the acknowledgment is not received, the next time changes are sent, they will include the new changes and the previously sent changes.
  • To synchronize replicas in a connected mode, see the Synchronize Changes tool.
Parameters
Label Explanation Data type
Export from Replica Geodatabase
The replica geodatabase from which the data change message will be exported. The geodatabase can be local or remote.
Workspace; GeoDataServer
Output Data Changes File
The output delta file.
File
Replica
The replica containing the updates to be exported.
String
Switch to Receiver once the message has been exported
Specifies whether the replica will be changed from a sender to a receiver. The receiver may not send replica updates until updates from the relative replica sender arrive.
  • Checked—The replica role will be changed from a sender to receiver.
  • Unchecked—The replica role will not be changed. This is the default.
Boolean
Include unacknowledged data changes
Specifies whether data changes that were previously exported for which no acknowledgment message was received will be included.
  • Checked—All data changes that were previously exported for which no acknowledgment message was received will be included. This is the default.
  • Unchecked—Data changes that were previously sent will not be included.
Boolean
Include new data changes since last export
Specifies whether all data changes made since the last exported data change message will be included.
  • Checked—All data changes made since the last exported data change message will be included. This is the default.
  • Unchecked—Data changes made since the last exported data change message will not be included.
Boolean
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
