Export Acknowledgement Message (Data Management Tools)
Summary
Creates an output acknowledgement file to acknowledge the reception of previously received data change messages.
Usage
  • Use this tool when synchronizing a replica while disconnected. First run the Export Data Change Message tool, which creates a delta file with changes to synchronize. Then copy and import the delta file to the relative replica using the Import Message tool. If the delta file gets lost and you want to resend, use the Re-Export Unacknowledged Messages tool to regenerate the delta file. After the changes are imported, you can export an acknowledgment file from the relative replica using the Export Acknowledgement Message tool. Copy and import the acknowledgment file using the Import Message tool. If the acknowledgment is not received, the next time changes are sent, they will include the new changes and the previously sent changes.
  • The geodatabase can be a local geodatabase or a geodata service.
  • The output acknowledgement file must be XML.
  • This tool is not applicable for check-out replicas.
  • To synchronize replicas in a connected mode, see the Synchronize Changes tool.
Parameters
Label Explanation Data type
Export from Replica Geodatabase
Specifies the replica geodatabase from which to export the acknowledgement message. The geodatabase may be local or remote.
Workspace; GeoDataServer
Output Acknowledgement File
Specifies the delta file to export to.
File
Replica
The replica from which the acknowledgement message will be exported.
String
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
