Import Message (Data Management Tools)
Summary
Imports changes from a delta file into a replica geodatabase or imports an acknowledgment message into a replica geodatabase.
Usage
  • Use this tool when synchronizing a replica while disconnected. First run the Export Data Change Message tool, which creates a delta file with changes to synchronize. Then copy and import the delta file to the relative replica using the Import Message tool. If the delta file gets lost and you want to resend, use the Re-Export Unacknowledged Messages tool to regenerate the delta file. After the changes are imported, you can export an acknowledgment file from the relative replica using the Export Acknowledgement Message tool. Copy and import the acknowledgment file using the Import Message tool. If the acknowledgment is not received, the next time changes are sent, they will include the new changes and the previously sent changes.
  • The geodatabase can be a local geodatabase or a geodata service.
  • The tool accepts acknowledgment messages or data change messages. Acknowledgment files are .xml files. Data change messages can be delta file geodatabase (.gdb) or delta .xml files.
  • After importing a data change message, you can immediately export an acknowledgment message. The output acknowledgment file must be an .xml file.
  • To synchronize replicas in a connected mode, see the Synchronize Changes tool.
Parameters
Label Explanation Data type
Import To Replica Geodatabase
The replica geodatabase that will receive the imported message. The geodatabase can be local or remote.
Workspace; GeoDataServer
Import from Delta file
The file from which the message will be imported.
Workspace; File
Output Acknowledgement File
(Optional)
The file that will contain the acknowledgement message. When importing data changes, you can also export a message to acknowledge the import of a data change message. This parameter is only supported for a data change message.
File
Conflict Resolution Policy
(Optional)
Specifies how conflicts will be resolved when they are encountered while importing a data change message.
  • Manually resolve conflicts—Conflicts must be manually resolved in the versioning reconcile environment.
  • In favor of the database—Conflicts will be automatically resolved in favor of the database receiving the changes.
  • In favor of imported changes—Conflicts will be automatically resolved in favor of the imported changes.
String
Conflict Definition
(Optional)
Specifies whether the conditions required for a conflict to occur will be detected by object (row) or by attribute (column).
  • By object—Conflicts will be detected by row.
  • By attribute—Conflicts will be detected by column.
String
Reconcile with the Parent Version (Check-out replicas)
(Optional)
Specifies whether data changes will be automatically reconciled once they are sent to the parent replica if no conflicts are present. This parameter is only enabled for check-out/check-in replicas.
  • Checked—Changes will be reconciled with the parent version.
  • Unchecked—Changes will not be reconciled with the parent version. This is the default.
Boolean
Derived output
Output Replica Geodatabase
The updated replica geodatabase.
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
