Generate File Geodatabase License (Data Management Tools)
Summary
Generates a license file (.sdlic) for displaying the contents in a licensed file geodatabase created by the Generate Licensed File Geodatabase tool.
Licensing is not supported for geodatabases created earlier than version 10.1.
Usage
  • The Allow Export of Vector Data parameter specifies whether an end user can export vector data in the licensed file geodatabase.
  • The Expiration Date parameter defines an expiration date for the license file. Access expires at midnight, after which the file geodatabase's contents can no longer be displayed. This allows a set term for a licensed geodatabase. The default value is empty (blank), which means the data license file will never expire.
  • You cannot individually license a feature class or table to produce a mixed state in which some feature classes or tables are licensed and others are not. However, a licensed file geodatabase allows you to add an unlicensed feature class or table through operations such as creating an empty feature class, copying and pasting, and importing.
  • Once you generate a license file using this tool, you must add the license to the project. See Manage file geodatabase data licenses for instructions.
Parameters
Label Explanation Data type
Input License Definition File
The license definition file (.licdef) created by the Generate Licensed File Geodatabase tool.
File
Output Data License File
The license file (.sdlic) for distribution.
File
(Optional)
Specifies whether the export of vector data will be allowed.
  • Vector data cannot be exported—Vector data cannot be exported with the data license file (.sdlic) installed. This is the default.
  • Allow export of vector data—Vector data can be exported with the data license file (.sdlic) installed.
String
Expiration Date
(Optional)
The expiration date of the data license file, after which the file geodatabase's contents can no longer be displayed. The default value is empty (blank), which means the data license file will never expire.
Date
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
