Field Statistics To Table (Data Management Tools)
Summary
Creates a table of descriptive statistics for one or more input fields in a table or feature class.
Illustration
Field Statistics To Table tool illustration
Usage
  • The tool accepts a feature class or stand-alone table as input.
  • For the Input Fields parameter, multiple fields can be specified for which statistics can be calculated. The parameter accepts numeric (Short, Long, Big Integer, Float, and Double types), Text, and Date (Date, Date Only, Time Only and Timestamp Offset) type fields.
  • The order of the fields specified by the Input Fields parameter will be the order of the rows in the output table.
  • The Group By Field parameter is used to calculate input field statistics separately for each unique value in the specified field. The statistics for each of the input fields will be calculated and reported once per unique value in the group by field.
  • The Output Tables parameter has four options for the Field Types column:
    • All—All of the input fields and output statistics, regardless of the field type, will be exported to a single output table.
    • Numeric—Only the Numeric type input fields (Short, Long, Big Integer, Float, and Double) will be exported, and only the statistics applicable to Numeric field types will be exported to the output table.
    • Text—Only the Text type input fields will be exported, and only the statistics applicable to the Text field type will be exported to the output table.
    • Date—Only the Date type input fields (Date, Date Only, Time Only, Timestamp Offset) will be exported, and only the statistics applicable to the Date field type will be exported to the output table.
    For each output table, the name of the table is specified in the Output Name column of the Output Tables parameter, and the table will be saved in the workspace specified by the Output Location parameter.
  • The output statistics and their field names can be configured using the Output Statistics parameter. If no value is provided for this parameter, all of the applicable output statistics will be included in the output tables. The following table lists the available statistics and the corresponding output field type for each option of the Field Types column of the Output Tables parameter:
    Output statistic
    All
    Numeric
    Text
    Date
    Field Name
    Text
    Text
    Text
    Text
    Alias
    Text
    Text
    Text
    Text
    Field type
    Text
    Text
    Text
    Text
    Nulls
    Long
    Long
    Long
    Long
    Minimum
    Text
    Double
    Date
    Maximum
    Text
    Double
    Date
    Mean
    Text
    Double
    Date
    Standard deviation
    Double
    Double
    Median
    Text
    Double
    Date
    Count
    Long
    Long
    Long
    Long
    Number of unique values
    Long
    Long
    Long
    Long
    Mode
    Text
    Double
    Text
    Date
    Least common
    Text
    Double
    Text
    Date
    Outliers
    Long
    Long
    Sum
    Double
    Double
    Range
    Text
    Double
    Text
    Interquartile range
    Double
    Double
    First quartile
    Text
    Double
    Date
    Third quartile
    Text
    Double
    Date
    Coefficient of variation
    Double
    Double
    Skewness
    Double
    Double
    Kurtosis
    Double
    Double
  • The available statistics are the same as those available in the Data Engineering view. For details on how each statistic is calculated, see Interact with statistics.
  • If you choose All for the Field Types column of the Output Tables parameter, all the field types will be exported in a single table. This can help you visualize all the input fields and their statistics at once. This provides advantages for certain applications; for example, it might be preferred when using the statistics in a layout or a report. However, there are caveats to exporting different field types as a single table. Some statistic options that are common across field types, including Mode, Least Common, Minimum, and Maximum, will be stored as text fields in the output table. This can cause problems, for example, when sorting these values in the statistics columns or chaining the output statistics in a model. There will also be empty cells in the table, as certain statistics do not apply to text or date fields.
  • If you choose Numeric, Text, or Date for the Field Types column of the Output Tables parameter, each field type will be exported in a separate table, and the output tables will only include the statistics applicable to that field type. Some statistics that apply to multiple field types will be stored in the format matching the input field type. For example, in the Numeric table, the Minimum field will be of type Double, and it will be of type Date in the Date table. It is recommended that you have different output tables. For example, to save the statistics as the same type as the input fields, sort the statistics in the output table or use their values in a model.
  • The Mode and Least Common options for the Statistic column of the Output Statistics parameter can correspond to multiple values in an input field in the case of a tie. In such cases, multiple values will be reported as <Null> for Numeric, Text, and Date output tables. For the All option, the output cell will contain the text Multiple Values.
Parameters
Label Explanation Data type
Input Table
The input table containing the fields that will be used to create the statistics table.
Table View
Input Fields
The fields containing the values that will be used to calculate the statistics.
Field
Output Location
The location where the output tables will be created. The location can be a geodatabase, folder, or feature dataset.
Workspace
Output Tables
The output tables containing the statistics. The Field Types column specifies the field types that will be included in each output table, and the name of each output table is provided in the Output Name column. For example, you can create a single table with summaries of all field types, or you can create separate tables for summaries of Numeric, Text, and Date field types.
Value table columns:
  • Field Types—Specifies the field types that will be included in each output table.
    • Numeric—A table summarizing numeric fields of the input (Short, Long, Float, and Double types) will be created.
    • Text—A table summarizing text fields of the input (Text type) will be created.
    • Date—A table summarizing date fields of the input (Date type) will be created.
    • All—A table summarizing all numeric, text, and date fields of the input will be created.
  • Output Name—The name of each output table.
Value Table
Group By Field
(Optional)
The field that will be used to group rows into categories. If a group by field is provided, each field of the input will appear as a row in the output table once per unique value in the group by field.
Field
Output Statistics
(Optional)
Specifies the statistics that will be summarized and the names of the output fields containing the statistics. The statistic is provided in the Statistic column, and the name of the output field is provided in the Output Field Name column. If no values are provided, all applicable statistics will be calculated for all input fields.
Only statistics applicable to the input fields will be available.
  • Statistic—Specifies the statistic type that will be used.
    • Field name—The name of the field.
    • Alias—The alias of the field.
    • Field type—The field type of the field (Short, Long, Double, Float, Text, or Date).
    • Nulls—The number of records containing null values in the field.
    • Minimum—The smallest value in the field.
    • Maximum—The largest value in the field.
    • Mean—The mean (sum divided by total count) of all values in the field. To calculate the mean date for date fields, each date is converted to a number by calculating the difference between the date and a reference date (for example, 1900-01-01), calculated in milliseconds.
    • Standard deviation—The standard deviation of the values in the field. It is calculated as the square root of the variance, in which the variance is the average squared difference of each value from the mean of the field.
    • Median—The median for all values in the field. The median is the middle value in the sorted list of values. If there is an even number of values, the median is the mean of the two middle values in the distribution.
    • Count—The number of nonnull values in the field.
    • Number of unique values—The number of unique values in the field.
    • Mode—The most frequently occurring value in the field.
    • Least common—The least common value in the field.
    • Outliers—The number of records with outlier values in the field. Outliers are values that are more than 1.5 times the interquartile range above the third quartile or below the first quartile of the values of the field.
    • Sum—The sum of all values in the field.
    • Range—The difference between the largest and smallest values in the field.
    • Interquartile range—The range between the first quartile and the third quartile of the values in the field. This represents the range of the middle half of the data.
    • First quartile—The value of the first quartile of the field. Quartiles divide the sorted list of values into four groups containing equal numbers of values. The first quartile is the upper limit of the first group in ascending order.
    • Third quartile—The value of the third quartile of the field. Quartiles divide the sorted list of values into four groups containing equal numbers of values. The third quartile is the upper limit of the third group in ascending order.
    • Coefficient of variation—The coefficient of variation of the values in the field. The coefficient of variation is a measure of the relative spread of the values. It is calculated as the standard deviation divided by the mean of the field.
    • Skewness—The skewness of the values in the field. Skewness measures the symmetry of the distribution. The skewness is calculated as the third moment (the average of the cubed data values) divided by the cubed standard deviation.
    • Kurtosis—The kurtosis of the values in the field. Kurtosis describes the heaviness of the tails of a distribution compared to the normal distribution, helping identify the frequency of extreme values. The kurtosis is calculated as the fourth moment (the average of the data values taken to the fourth power) divided by the fourth power of the standard deviation.
  • Output Field Name—The name of the output field
Value Table
Derived output
Output Table for Numeric Fields
The output tables for Numeric data types. The table will be saved in the workspace specified in the Output Location parameter.
Table
Output Table for Text Fields
The output tables for Text data types. The table will be saved in the workspace specified in the Output Location parameter.
Table
Output Table for Date Fields
The output tables for Date data types. The table will be saved in the workspace specified in the Output Location parameter.
Table
Output Table for All Fields
The output tables for all data types. The table will be saved in the workspace specified in the Output Location parameter.
Table
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
