Save Toolbox To Version (Data Management Tools)
Summary
Analyzes and saves a toolbox for use with a specific earlier version of ArcGIS software.
The analyzers check for a variety of geoprocessing tool compatibility issues between the installed version of ArcGIS Pro and a specified target version. For a list of compatibility issues, see the Analyze Toolbox For Version tool, as it uses the same analyzer logic.
Learn more about saving a toolbox to an earlier version
The tool's analyzers will report compatibility issues with both ModelBuilder- and Python-based tools (only for script tools with a Python file as the tool's source). The following are distinctions on the actions that will be performed:
  • Model tool—Certain types of compatibility issues will be addressed as part of the operation.
  • Script tool—No change will be made to the tool's source file.
Usage
  • This tool creates an output toolbox where the result will be written. The original toolbox will not be modified. It is recommended that you keep the original toolbox to avoid data loss.
  • No action is necessary to use a toolbox in a specific later release.
  • The tools in the output toolbox may produce results that are not consistent with the original. Test the tools in the output toolbox for consistency.
  • Some functionality in models, particularly related to filters, domains, and choice lists (value drop-down lists), will be removed from the output toolbox. To address this, add and reconnect the relevant tools to the model's workflow.
  • For script tools, the path to the tool's Python file will not be changed in the output toolbox. The script tools in the original and output toolboxes will use the same file. If modifications are required, make a copy of the .py file and update one of the two script tool's Script file properties to use the second .py file. This does not apply to script tools with an embedded script file.
  • Certain compatibility issues cannot be repaired by this tool. For example, data types that are not present at the target version will produce an error. To address this, make a copy of the toolbox, manually remove the problematic data, and use that toolbox as input.
Parameters
Label Explanation Data type
Input Toolbox
The input toolbox (.tbx or .atbx file) that will be analyzed and saved. The file will not be modified.
The Python toolbox format (.pyt file) is not supported as an input.
Toolbox
Target Version
Specifies the software version that will be used for toolbox compatibility issue analysis.
  • ArcGIS Desktop 10.6.0—ArcGIS Desktop 10.6.0 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Desktop 10.7.0—ArcGIS Desktop 10.7.0 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Desktop 10.8.0—ArcGIS Desktop 10.8.0 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Desktop 10.8.2—ArcGIS Desktop 10.8.2 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.2—ArcGIS Pro 2.2 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.3—ArcGIS Pro 2.3 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.4—ArcGIS Pro 2.4 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.5—ArcGIS Pro 2.5 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.6—ArcGIS Pro 2.6 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.7—ArcGIS Pro 2.7 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.8—ArcGIS Pro 2.8 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 2.9—ArcGIS Pro 2.9 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 3.0—ArcGIS Pro 3.0 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 3.1—ArcGIS Pro 3.1 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 3.2—ArcGIS Pro 3.2 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 3.3—ArcGIS Pro 3.3 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 3.4—ArcGIS Pro 3.4 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 3.5—ArcGIS Pro 3.5 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
  • ArcGIS Pro 3.6—ArcGIS Pro 3.6 will be used for toolbox compatibility issue analysis. The output toolbox will be saved to this version.
String
Output Toolbox
The toolbox that will be created for use with ArcGIS software of the specified Target Version parameter value.
Toolbox
Error on missing tool
(Optional)
Specifies whether an error will be produced if a tool is encountered that is not present at the target version.
  • Checked—An error will be produced and the output toolbox will not be created. This is the default.
  • Unchecked—A warning message will be produced and the output toolbox will be created. For model tools, the problematic tool will be removed from the model, which will require manual editing.
Boolean
Error on missing required parameter
(Optional)
Specifies whether an error will be produced if a parameter is encountered that is not present at the target version and that parameter has a value that is not its default value.
  • Unchecked—A warning message will be produced, the parameter will be removed from the model, and the output toolbox will be created.
Boolean
Error on invalid parameter value
(Optional)
Specifies whether an error will be produced if a parameter value is encountered that is not present in its parameter filter at the target version.
  • Unchecked—A warning message will be produced and the output toolbox will be created. The output toolbox will produce an error with a value that is not in domain or is invalid.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
