Analyze Toolbox For Version (Data Management Tools)
Summary
Analyzes the contents of a toolbox and identifies compatibility issues with earlier versions of ArcGIS software.
The tool evaluates a toolbox (for both ModelBuilder- and Python-based tools) and determines the ArcGIS Pro geoprocessing tools it contains. It then identifies compatibility issues between the version of the software being used and a specified target version. Compatibility issues are presented as warning messages and can be written to a text file.
Learn more about saving a toolbox to an earlier version
Usage
ArcGIS Pro supports backward compatibility of geoprocessing tools. Models and scripts created with an earlier version of the software can be used by later versions of the software. For example, a model created at ArcGIS Pro 2.9 can be used in ArcGIS Pro 3.0. The purpose of the Analyze Toolbox For Version tool is to identify any compatibility issues that will cause problems when a toolbox is created (or edited) in a later version of the software (for example, ArcGIS Pro 3.0) and is then used with an earlier version of the software (for example, ArcGIS Pro 2.9).
  • The input toolbox will not be modified. To update the toolbox, use the Save Toolbox To Version tool.
  • The tool's compatibility analyzers track the list of known compatibility issues for each geoprocessing tool to each target version.
  • Compatibility issues are only tracked for ArcGIS Pro system toolboxes.
  • The tool's analyzers do not track compatibility of nongeoprocessing tool functions in ArcPy. Changes to nongeoprocessing functions (for example, changes to arcpy.da.SearchCursor) may cause compatibility issues.
  • The compatibility analyzer identifies and reports the following compatibility issues:
    • Geoprocessing tools from the system toolboxes that are not present at the target version. For example, the PDF To TIFF tool was not available in ArcGIS Pro prior to version 2.9.
    • The geoprocessing data type of a model variable or tool parameter is not present at the target version (models only). For example, the data type of Voxel Layer (GPVoxelLayer) is only supported starting at ArcGIS Pro 2.6.
    • Tool parameters that are not present at the target version. For example, the Template Tables parameter was added to the Add Fields (multiple) tool at ArcGIS Pro 2.6.
    • Modifications to certain properties of a tool parameter. Changes to the following parameter properties will produce compatibility warnings:
      • Parameter type—A parameter can have a type of required, optional, or derived.
      • Direction—A parameter can have a direction of input or output.
      • Value—The parameter's default value.
      • Multivalue—A parameter can support a single value or multiple values.
      • Data type—The data type of a parameter, for example, Feature Class (DEFeatureClass).
      • Filter list—The options and filters limiting the values that are considered valid for a parameter.
      • Filter type—The type of filter associated with the parameter. For example, a parameter can have no filter, a list of values, or a range of values (for example, 0 to 10). Typically, filter type changes are from having no filter to having a filter.
Parameters
Label Explanation Data type
Input
The input toolbox (.tbx or .atbx file) that will be analyzed.
The Python toolbox format (.pyt file) is not supported as an input.
Toolbox
Target Version
Specifies the software version that will be used for toolbox compatibility analysis.
  • ArcGIS Desktop 10.6.0—ArcGIS Desktop 10.6.0 will be used for toolbox compatibility issue analysis.
  • ArcGIS Desktop 10.7.0—ArcGIS Desktop 10.7.0 will be used for toolbox compatibility issue analysis.
  • ArcGIS Desktop 10.8.0—ArcGIS Desktop 10.8.0 will be used for toolbox compatibility issue analysis.
  • ArcGIS Desktop 10.8.2—ArcGIS Desktop 10.8.2 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.2—ArcGIS Pro 2.2 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.3—ArcGIS Pro 2.3 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.4—ArcGIS Pro 2.4 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.5—ArcGIS Pro 2.5 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.6—ArcGIS Pro 2.6 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.7—ArcGIS Pro 2.7 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.8—ArcGIS Pro 2.8 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 2.9—ArcGIS Pro 2.9 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 3.0—ArcGIS Pro 3.0 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 3.1—ArcGIS Pro 3.1 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 3.2—ArcGIS Pro 3.2 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 3.3—ArcGIS Pro 3.3 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 3.4—ArcGIS Pro 3.4 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 3.5—ArcGIS Pro 3.5 will be used for toolbox compatibility issue analysis.
  • ArcGIS Pro 3.6—ArcGIS Pro 3.6 will be used for toolbox compatibility issue analysis.
String
Output File
(Optional)
The text file that will be created containing the compatibility issues identified by the analyzers.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
