Remove Rule From Relationship Class (Data Management Tools)
Summary
Removes a rule from a relationship class.
Learn more about relationship rules
Usage
  • If the relationship class is stored in an enterprise geodatabase, this tool can only be successfully run as the data owner.
Parameters
Label Explanation Data type
Input Relationship Class
The relationship class with the rule to remove.
Relationship Class
Origin Subtype
(Optional)
If the origin class has subtypes, the subtype that is associated with the relationship class rule to be deleted.
String
Destination Subtype
(Optional)
If the destination class has subtypes, the subtype that is associated with the relationship class rule to be deleted.
String
Remove All
(Optional)
Specifies the relationship rules to be removed from the relationship class.
  • Checked—All relationship rules will be removed from the input relationship class.
  • Unchecked—Only rules from the origin and destination subtypes specified will be removed. This is the default.
Boolean
Derived output
Updated Relationship Class
The updated input relationship class with the relationship class rule removed.
Relationship Class
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
