Recalculate Feature Class Extent (Data Management Tools)
Summary
Recalculates the xy, z, and m extent properties of a feature class based on the features in the feature class.
A feature class has a spatial extent that is based on all the coordinates in the feature class. This spatial extent is used when adding a feature class to a map to recenter and display all the features. Rather than examining every feature in the feature class each time the feature class is added to a map (a potentially long process), a feature class has an extent property containing the last known spatial extent. However, this extent property is not always updated when features in the feature class are edited. This means that the values in the extent property may not contain the actual spatial extent of the features. The Recalculate Feature Class Extent tool reads all the features and updates the extent property.
XY, Z, and M extents are not the same as spatial reference domains. The XY, Z, and M domains in a spatial reference define the valid range of coordinate values that can be stored in a feature class. The feature class extents reflect the actual range of coordinate values that exist in the feature class. These extents cannot be larger than the domains.
Usage
  • This tool updates geodatabase feature classes or shapefiles (point, multipoint, line, or polygon).
  • In an enterprise geodatabase, extent is a property of the feature class schema and requires an exclusive schema lock to run.
  • When using this tool with an enterprise geodatabase feature class as input, the extent is calculated based on the features that exist in that feature class in all versions. The extent will not reduce or expand unless this tool is run after the database has been compressed.
  • The Store Extent parameter is supported for unregistered spatial tables in a database or enterprise geodatabase. If the parameter is checked, the new extent will be stored on the shape column metadata of the underlying table. If the parameter is unchecked, the extent will be recalculated but the value will not be stored, which can be useful when the underlying data will be updated frequently.
  • This tool will fail if you do not have permissions to edit the feature class.
  • Recalculating the feature class extent cannot be undone.
  • The values of the extent are returned by the arcpy.Describe function's extent property.
    Caution:
    This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
Parameters
Label Explanation Data type
Input Feature Class
The shapefile or geodatabase feature class that will be updated.
Feature Layer
Store Extent
(Optional)
Specifies whether the extent will be stored for feature classes that are not registered. This parameter is only supported when the input feature class is an unregistered spatial table in a database or enterprise geodatabase.
If the input feature class is updated frequently, you may choose not to store the recalculated extent value. If you choose to store the extent, the extent will not be recalculated each time the feature class is added to the map.
  • Checked—The extent will be stored for the input feature class.
  • Unchecked—The extent will not be stored for the input feature class. This is the default.
Boolean
Derived output
Updated Feature Class
The updated feature class.
Feature Class
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
