Enable Editor Tracking (Data Management Tools)
Summary
Enables editor tracking for a feature class, table, feature dataset, or relationship class in a geodatabase.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • If the input dataset is from an enterprise geodatabase, it must be from a database connection established as the data owner.
  • This tool can add fields if they do not exist. If fields do exist, they must be of the correct data type. The values specified for the Creator Field and Last Editor Field parameters must be string fields, and the values specified for the Creation Date Field and Last Edit Date Field parameters must be date fields.
  • Editor tracking applies to operations on existing datasets only. It does not apply to operations that create datasets. For example, if you copy a dataset to create a new one, tracking values will not update in the new dataset.
  • You can record the dates of edits in either the time zone in which the database is located or in coordinated universal time (UTC).
    If you plan to copy or replicate data across time zones or edit through a feature service, use UTC. Since editors can apply edits from potentially anywhere in the world, UTC works well because it ensures that times are recorded in a universally accepted and consistent way.
    Configuring editor tracking to use the time zone in which the database is located is only recommended if you are certain that all edits will be performed in that time zone.
  • You can run this tool on a dataset that has editor tracking enabled but only to enable tracking of additional information. For example, if a dataset is only tracking the creator and creation date, you can run this tool to add tracking of the editor and last edited date. This tool cannot disable tracking on a field, switch tracking from one field to another, or switch between UTC and the database time zone. To perform any of these operations, disable editor tracking on the input dataset before you run this tool.
  • Not all relationship class types can have editor tracking enabled. Editor tracking can only be enabled on table-based relationship classes (that is, many-to-many or attributed relationship classes).
  • If editor tracking is enabled on a feature class that has attachments, editor tracking will also be enabled on the attachment table. If you add new fields, those fields will also be added to the attachment table. If you reuse existing fields, and those fields do not exist in the attachment table, they will be added.
  • At ArcGIS Pro 2.4, feature datasets are supported as input for this tool. If you add new fields to each item in the feature dataset, the fields will be named created_user, created_date, last_edited_user, and last_edited_date by default. If you use existing fields, the fields must already exist for all items in the feature dataset.
Parameters
Label Explanation Data type
Input Dataset
The feature class, table, feature dataset, or relationship class in which editor tracking will be enabled.
Dataset; Topology; Network Dataset
Creator Field
(Optional)
The name of the field that will store the names of users who create features or records. If this field already exists, it must be a string field.
String
Creation Date Field
(Optional)
The name of the field that will store the date that features or records are created. If this field already exists, it must be a low precision date field.
String
Last Editor Field
(Optional)
The name of the field that will store the names of users who last edited features or records. If this field already exists, it must be a string field.
String
(Optional)
The name of the field that will store the date that features or records were last edited. If this field already exists, it must be a low precision date field.
String
Add fields
(Optional)
Specifies whether fields will be added if they don't exist.
  • Checked—Fields will be added if they do not exist. You must specify the names of the fields to add in the Creator Field, Creation Date Field, Last Editor Field, and Last Edit Date Field parameters.
  • Unchecked—Fields will not be added. Fields specified must already exist in the Input Dataset parameter value. This is the default.
Boolean
Record Dates in
(Optional)
Specifies the time format in which the created date and last edited date will be recorded.
  • UTC (Coordinated Universal Time)—Dates will be recorded in UTC. This is the default.
  • Time zone of database—Dates will be recorded in the time zone in which the database is located.
String
Derived output
Modified Input Dataset
The modified input dataset.
Dataset
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
