Import Geodatabase Configuration Keywords (Data Management Tools)
Summary
Defines data storage parameters for an enterprise geodatabase by importing a file containing configuration keywords, parameters, and values.
Usage
  • This tool only works with enterprise geodatabases.
  • Typically, you will run the Export Geodatabase Configuration Keywords tool first to obtain a file containing the geodatabase's existing configuration keyword and parameter values. Alter this file and import the changes using the Import Geodatabase Configuration Keywords tool.
  • Only the geodatabase administrator can run this tool.
  • This tool is not supported for geodatabases in SAP HANA.
Parameters
Label Explanation Data type
Input Database Connection
The connection file for the enterprise geodatabase to which you want to import the configuration file. You must connect as the geodatabase administrator.
Workspace
Input File
The path to and name of the ASCII text file containing configuration keywords, parameters, and values to import.
File
Derived output
Updated Input Workspace
The input workspace.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
