SQL Server configuration parameters
Configuration parameters identify a database object to be configured. Their corresponding values identify how the object will be stored in the database. The parameters and their configuration strings are grouped together by configuration keywords.
In geodatabases stored in Microsoft SQL Server, configuration parameters and their corresponding configuration strings are used by ArcGIS to define how data is stored. The following lists storage settings available with different parameters:
Define the data type for spatial columns.
Define how character data is stored.
Make keywords available for users in the ArcGIS interface.
Provide comments that describe the configuration keyword.
Legacy:
Configuration keywords and parameters are largely legacy functionality. They were implemented when databases required far more intervention and tinkering on the part of the database administrator to get them to perform well. For the most part, you will not need to alter the configuration parameters in your geodatabase.
When you create an enterprise geodatabase, it is populated with default configuration keywords and parameters. In the majority of cases, the default parameter values are sufficient. Possible exceptions include the following:
You might want to change the spatial type used for features. If you want the majority of feature classes to use a spatial type different than the default value, change the GEOMETRY_STORAGE parameter for the DEFAULTS keyword. If you want only some feature classes to use a different spatial type, create a custom keyword and include the GEOMETRY_STORAGE parameter set to the spatial type you want, and include the UI_TEXT parameter to make your custom keyword available to users.
If you will never need to store multibyte characters in your attribute fields, you could set the UNICODE_STRING parameter for the DEFAULTS keyword to FALSE. New text fields will use the varchar data type instead of nvarchar, which could save a tiny amount of storage space in your database. If data creators in your organization need to create a few tables or feature classes that store large amounts of single-byte text inside a single field in each table, you can create a custom keyword and include the UNICODE_STRING parameter set to FALSE, and include the UI_TEXT parameter to make your custom keyword available to users.
If you want to group your data into different file groups so you can create backups of individual file groups, you can create custom keywords for different types of data and set parameters in each keyword that will store all tables and indexes for that type of data in a specific file group. For example, you might want all actively edited data to go to one file group so you can create more frequent backups, so you would create an EDITED_LAYERS keyword that contains business, adds, and deletes table parameters that store all tables and indexes for these layers in the same file group.
Additional parameters exist to control the following, but you are far less likely to use these parameters. They remain for backward compatibility and, therefore, remain in this page to help you understand their intended use when they were added:
Whether to cluster an index.
How much to fill each index page (FILLFACTOR).
How much binary data should be stored in-line to a data page (OUT_OF_ROW).
Define how XML documents are stored. Because ArcGIS does not use XML documents directly, it is unlikely you'll need to set these parameters.
The following table is an alphabetic list of all the possible configuration parameters that can be used in a geodatabase in SQL Server. Default values are listed first where applicable. Following the table is a more in-depth explanation of the parameters roughly grouped by related functionality.
Parameter name |
Description |
Values |
A_CLUSTER_RASTER |
Index type for the raster column in the Adds table |
0 or 1; 1 = clustered 0 = nonclustered |
A_CLUSTER_ROWID |
Index type for the rowid column on the Adds table |
A_CLUSTER_STATEID |
Index type for the Adds table stated column |
A_CLUSTER_USER |
Index type for any user-defined indexes on the Adds table |
A_CLUSTER_XML |
Index type for the xml doc type column of the Adds table |
A_INDEX_RASTER |
A_INDEX_ROWID |
Adds the table object ID column index storage definition |
See the Microsoft SQL Server documentation for CREATE INDEX parameters. |
A_INDEX_STATEID |
Adds the table sde_state_id column index storage definition |
A_INDEX_USER |
Adds the table index storage definition |
A_INDEX_XML |
Adds the table XML column index table storage definition |
A_OUT_OF_ROW |
Determines whether data will be stored in row or out of row for varbinary(max) columns in the adds table If set to 0, up to 8,000 bytes can be stored directly in the data page of the table. If set to 1, data will always be stored out of row. |
0 or 1 |
A_STORAGE |
Adds the table storage definition |
See the Microsoft SQL Server documentation for CREATE TABLE parameters. |
AUX_CLUSTER_COMPOSITE |
Index type for the primary key |
1 or 0; 1 = clustered 0 = nonclustered |
AUX_INDEX_COMPOSITE |
Raster AUX table composite column index storage definition |
AUX_STORAGE |
Raster AUX table storage definition |
B_CLUSTER_RASTER |
Index type for the raster column in the business table |
B_CLUSTER_ROWID |
Index type for the rowid column on the business table |
B_CLUSTER_TO_DATE |
Specifies the index type on the to_date,archive_rowid column in the history table of a table that is enabled for archiving |
B_CLUSTER_USER |
Index type for any user-defined indexes on the business table |
B_CLUSTER_XML |
Index type for the xml doc type column of the business table |
B_INDEX_RASTER |
Business table raster column index storage definition |
B_INDEX_ROWID |
Business table object ID column index raster rowid index R<N>_SDE_ROWID_UK storage definition |
B_INDEX_TO_DATE |
Storage parameter info for creating the index R<registration_id>_sde_todate, which is used when updating the history table during an archive operation |
B_INDEX_USER |
Business table user index storage definition |
B_INDEX_XML |
Business table XML column index table storage definition |
B_OUT_OF_ROW |
Determines whether data will be stored in row or out of row for varbinary(max) columns in a business table If set to 0, up to 8,000 bytes can be stored directly in the data page of the table. If set to 1, data will always be stored out of row. |
0 or 1 |
B_STORAGE |
Business table and raster attribute table storage definition |
BLK_CLUSTER_COMPOSITE |
BLK_INDEX_COMPOSITE |
Raster BLK table composite column index storage definition |
BLK_OUT_OF_ROW |
Determines whether data will be stored in row or out of row for varbinary(max) columns in the raster blocks table If set to 0, up to 8,000 bytes can be stored directly in the data page of the table. If set to 1, data will always be stored out of row. |
0 or 1 |
BLK_STORAGE |
Raster BLK table storage definition |
BND_CLUSTER_COMPOSITE |
BND_CLUSTER_ID |
Index type for RASTER_ID, SEQUENCE_NBR columns |
BND_INDEX_COMPOSITE |
Raster BND table composite column index storage definition |
BND_INDEX_ID |
Raster BND table RID column index storage definition |
BND_STORAGE |
Raster BND table storage definition |
COLLATION_NAME |
Collation of user-defined text columns |
Uses the database collation by default, unless other collation is specified |
COMMENT |
Line used for comments |
Description up to 2,048 characters |
D_CLUSTER_ALL |
Index type for SDE_STATES_ID, SDE_DELETES_ROW_ID, and DELETED_AT columns |
D_CLUSTER_DELETED_AT |
Index type for the DELETED_AT column |
D_INDEX_ALL |
FILLFACTOR and location (file group) for composite index on SDE_STATES_ID, SDE_DELETES_ROW_ID, and DELETED_AT columns |
D_INDEX_DELETED_AT |
Deletes table DELETED_AT column index storage definition |
D_STORAGE |
Deletes table storage definition |
GEOMETRY_STORAGE |
Indicates storage type for spatial column |
GEOMETRY or GEOGRAPHY |
GEOM_SRID_CHECK |
Adds a check constraint on the geometry column for an SRID value |
TRUE or FALSE |
I_STORAGE |
Defines storage for the i tables, which are used to generate IDs |
MVTABLES_MODIFIED_INDEX |
Mvtables_modified index storage definition |
MVTABLES_MODIFIED_TABLE |
Mvtables_modified table storage definition |
NUM_DEFAULT_CURSORS |
Controls the SQL Server cursor threshold |
-1 = All keysets are generated synchronously 0 = All cursor keysets are generated asynchronously For all other values, the SQL Server Query Optimizer compares the number of expected rows in the cursor set to the number set in the cursor threshold, then builds the keyset asynchronously if it exceeds the cursor threshold number. |
PERMISSION_CACHE_THRESHOLD |
Controls the amount of time (in milliseconds) the database can take to query the sysprotects table If the PERMISSION_CACHE_THRESHOLD value is exceeded, a temporary table (cache) is created to store a user's permission and is used from then on. If PERMISSION_CACHE_THRESHOLD = 0, permission will always be cached. When PERMISSION_CACHE_THRESHOLD is set to any value greater than 0, the permission is cached if the query time exceeds the value in milliseconds. If PERMISSION_CACHE_THRESHOLD is set to -1 (the default setting), the permission is never cached. |
0–1,000 -1 (disabled) is the default value |
RAS_CLUSTER_ID |
Index type for the primary key of the RAS table |
RAS_INDEX_ID |
Raster RAS table RID index storage definition |
RAS_STORAGE |
Raster RAS table storage definition |
RASTER_STORAGE |
Defines the raster data storage type |
binary |
STATES_INDEX |
States table storage definition |
STATES_LINEAGES_INDEX |
Controls the storage of the index on the SDE_state_lineages table's primary key |
STATES_LINEAGES_TABLE |
State_lineages table storage definition |
STATES_TABLE |
UI_NETWORK_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of network configuration |
Description up to 2,048 characters Not used in ArcGIS Pro |
UI_TERRAIN_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of terrain configuration |
UI_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of associated noncomposite configuration keyword |
UI_TOPOLOGY_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of topology configuration |
UNICODE_STRING |
Determines whether Unicode text types will be used If set to TRUE, character fields will be stored in UNICODE-compliant data types. For example, if the UNICODE_STRING parameter is set to FALSE, a string data type would be VARCHAR. If UNICODE_STRING is set to TRUE, the data type of the field would be NVARCHAR. |
TRUE or FALSE |
VERSIONS_INDEX |
Version index storage definition |
VERSIONS_TABLE |
Versions table storage definition |
XML_COLUMN_PATH_IDX |
Determines whether an XML path index is created |
1 or 0 0 = No path index created, 1 = Path index is created. |
XML_COLUMN_PRIMARY_IDX |
Determines whether an XML primary index is created |
1 or 0 0 = No primary index created, 1 = Primary index created |
XML_COLUMN_PROPERTY_IDX |
Determines whether an XML property index is created |
0 or 1 0 = No property index created, 1 = Property index created |
XML_COLUMN_SCHEMA |
Specifies the XML schema to be used for validation |
XML schema collection name, up to 128 characters |
XML_COLUMN_TYPE |
Specifies the XML document type that a column can store |
CONTENT or DOCUMENT |
XML_COLUMN_VALUE_IDX |
Determines whether an XML value index is created |
1 or 0 0 = No value index created, 1 = Value index is created. |
XML_DOC_INDEX |
Storage clause for xmldoc<n>_pk and xml_doc<n>_ix indexes on the sde_xml_doc<n> table |
XML_DOC_MODE |
Storage type for XML documents |
COMPRESSED or UNCOMPRESSED |
XML_DOC_OUT_OF_ROW |
Determines whether XML document BLOB data will be stored in row or out of row; only used for varbinary(max) columns If set to 0, up to 8,000 bytes can be stored directly in the data page of the table. If set to 1, data will always be stored out of row. |
0 or 1 |
XML_DOC_STORAGE |
Storage clause for the sde_xml_doc<n> table |
XML_DOC_UNCOMPRESSED_TYPE |
When the XML_DOC_MODE parameter is set to UNCOMPRESSED, the XML_DOC_UNCOMPRESSED_TYPE parameter determines the storage format for XML documents |
Since XML_DOC_MODE is set to COMPRESSED by default, the XML_DOC_UNCOMPRESSED_TYPE parameter is not present by default. Possible values: BINARY, TEXT, or UNICODE |
XML_IDX_CLUSTER_DOUBLE |
Storage clause indicating whether the xmlix<n>_db index on the double_tag column of the sde_xml_idx<n> table is clustered |
XML_IDX_CLUSTER_ID |
Storage clause indicating whether the xmlix<n>_id index on the id column of the sde_xml_idx<n> table is clustered |
XML_IDX_CLUSTER_PK |
Storage clause indicating whether the xmlix<n>_pk index on the xml_key_column identity column of the sde_xml_idx<n> table is clustered |
XML_IDX_CLUSTER_STRING |
Storage clause indicating whether the xmlix<n>_st index on the string_tag column of the sde_xml_idx<n> table is clustered |
XML_IDX_CLUSTER_TAG |
Storage clause indicating whether the xmlix<n>_tg index on the tag_id column of the sde_xml_idx<n> table is clustered |
XML_IDX_FULLTEXT_CAT |
Name of the full-text catalog in which the contents of the xml_doc_val column in the sde_xml_doc<n> table and the text_tag column of the sde_xml_idx<n> table are indexed |
The name you gave the full-text catalog when it was created; the default is SDE_DEFAULT_CAT. If you gave the catalog any other name, you must change the value of this parameter to match it. |
XML_IDX_FULLTEXT_LANGUAGE |
The language used for linguistic analysis when building the text index on the contents of the xml_doc_val column in the sde_xml_doc<n> table and the text_tag column of the sde_xml_idx<n> table |
There is no default value set for this parameter. Consult your DBMS documentation for valid language settings. |
XML_IDX_FULLTEXT_TIMESTAMP |
Determines whether a time stamp column will be added to the sde_xml_idx<n> table |
1 or 0 1 = timestamp column will be added, 0 = time stamp column will not be added. |
XML_IDX_FULLTEXT_UPDATE_METHOD |
Dictates how changes made to the xml_doc_val column in the sde_xml_doc<n> table (the XML document table) and the text_tag column of the sde_xml_idx<n> table (the index table of an XML column) are propagated to the full-text index |
CHANGE_TRACKING BACKGROUND or CHANGE_TRACKING MANUAL |
XML_IDX_INDEX_DOUBLE |
Storage clause for the xmlix<n>_db index on the double_tag column of the sde_xml_idx<n> table |
XML_IDX_INDEX_ID |
Storage clause for the xmlix<n>_id index on the ID column of the xml_idx<n> table |
XML_IDX_INDEX_PK |
Storage clause for the xmlix<n>_pk index on the xml_key_column identity column of the sde_xml_idx<n> table |
XML_IDX_INDEX_STRING |
Storage clause for the xmlix<n>_st index on the string_tag column of the sde_xml_idx<n> table |
XML_IDX_INDEX_TAG |
Storage clause for the xmlix<n>_tg index on the tag_id column of the sde_xml_idx<n> table |
XML_IDX_OUT_OF_ROW |
Determines whether the contents of the text_tag column in the sde_xml_idx<n> table (the index table of an XML column) can be stored in row or out of row; only used for varbinary(max) columns If set to 0, up to 8,000 bytes can be stored directly in the data page of the table. If set to 1, data will always be stored out of row. |
0 or 1 |
XML_IDX_STORAGE |
Storage clause for the sde_xml_idx<n> table (the index table of an XML column) |
For the XML parameters, <n> refers to the xml_column_id associated with a specific XML column.
There are a number of ways to categorize configuration parameters. Often, a parameter fits into more than one category. For example, the B_CLUSTER_RASTER parameter can be categorized as a business table parameter, a raster parameter, or a clustered index parameter. The following sections describe these categories.
Parameters specific to feature class and raster storage
The following parameters define how tables are stored in a geodatabase in SQL Server.
Business table parameters
The business table is the attribute table of a feature class or nonspatial table. Business table parameters begin with B and define storage for the business table and its indexes. The parameters are as follows:
Parameter |
Description |
B_CLUSTER_ROWID |
Index type for the row ID (object ID) column on the business table; 0 = nonclustered index, 1 = clustered index |
B_CLUSTER_USER |
Index type for any user-defined indexes on a business table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
B_CLUSTER_XML |
Index type for the XML type column of a business table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
B_CLUSTER_RASTER |
Index type for the raster column in a business table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
B_INDEX_ROWID |
Defines the fillfactor and location (file group) for the row ID column index of a business table To specify a file group, use the SQL
B_INDEX_USER |
Defines the fillfactor and location (file group) for any user-defined indexes on a business table To specify a file group, use the SQL
B_INDEX_XML |
Defines the fillfactor and location (file group) for the XML index on a business table To specify a file group, use the SQL
B_INDEX_RASTER |
Defines the fillfactor and location (file group) for the raster column index on a business table To specify a file group, use the SQL
B_INDEX_TO_DATE |
Storage information for creating the index R<registration_id>_sde_todate, which is used when updating the history table during an archive operation Note:This parameter does not have a corresponding adds table parameter. |
B_OUT_OF_ROW |
A value of either 0 or 1 If set to 0, up to 8,000 bytes are stored directly in the data page of the table. If set to 1, data is always stored out of row. |
B_STORAGE |
File group location for a business table Use
For a nonspatial business table, do one of the following:
Change the B_CLUSTER_ROWID parameter's config_string to 1. This will create a clustered index on the object ID field. Any subsequent user-defined indexes you create will be nonclustered.
Change the B_CLUSTER_USER parameter's config_string to 1. The first user-defined index created by ArcGIS will be clustered.
Create the data and change whatever index (or composite indexes) you want to be clustered.
Adds table parameters
An adds table is a table that stores insert and update edits made against a feature class in a geodatabase that uses traditional versioning. It is almost identical in structure to the business table but has additional columns to track state IDs. Adds table parameters begin with A. The adds table parameters are as follows:
Parameter |
Description |
A_CLUSTER_ROWID |
Index type for the row ID column on an adds table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
A_CLUSTER_STATEID |
Index type for the stated column of an adds table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. Note:This parameter does not have a corresponding business table parameter. |
A_CLUSTER_USER |
Index type for any user-defined indexes on an adds table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
A_CLUSTER_XML |
Index type for the XML type column of an adds table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
A_CLUSTER_RASTER |
Index type for a raster column in an adds table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
A_INDEX_ROWID |
Specifies the fillfactor and location (file group) for the row ID column index of an adds table To specify a file group, use the SQL
A_INDEX_STATEID |
Specifies the fillfactor and location (file group) for the state ID column index of an adds table To specify a file group, use the SQL
A_INDEX_USER |
Specifies the fillfactor and location (file group) for any user-defined indexes on an adds table To specify a file group, use the SQL
A_INDEX_XML |
Specifies the fillfactor and location (file group) for an XML index on an adds table To specify a file group, use the SQL
A_INDEX_RASTER |
Specifies the fillfactor and location (file group) for a raster column index on an adds table To specify a file group, use the SQL
A_OUT_OF_ROW |
A_STORAGE |
Specifies in which file group adds tables will be created when datasets are registered as versioned Use
Deletes table parameters
The deletes table is used to track updates and deletes made to tables that use traditional versioning. The deletes table parameters work the same way as adds table parameters. All deletes table parameters begin with D. They are as follows:
Parameter |
Description |
D_CLUSTER_ALL |
Index type for the index created on the SDE_STATES_ID, SDE_DELETES_ROW_ID, and DELETED_AT columns If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
Index type for the index on the DELETED_AT column If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
D_INDEX_ALL |
Specifies the fillfactor and location (file group) for a composite index on the SDE_STATE_ID, SDE_DELETES_ROW_ID, and DELETED_AT columns, for example:
Specifies the fillfactor and location (file group) for the index on the deleted_at column, for example:
D_STORAGE |
Specifies in which file group deletes tables will be created when datasets are registered as versioned Use
Raster table parameters
Binary and rasterblob rasters (both are BLOB storage types) in ArcGIS are stored as five separate tables: a band table (SDE_bnd_#), a block table (SDE_blk_#), a raster table (SDE_ras_#), an auxiliary table (SDE_aux_#), and a business table.
Rasters can be stored as embedded catalogs or columns in feature classes or can be stand-alone datasets.
Raster table parameters begin with AUX, BLK, BND, and RAS, which correspond to the raster tables. The parameters that define storage for the business table of the raster are defined by business table parameters.
Of all the raster tables, only the block table will get large.
If using binary rasters, make certain the BND_CLUSTER_COMPOSITE config_string is set to 1 to ensure that a clustered index is generated for the band table.
The raster table parameters are as follows:
Parameter |
Description |
Index type for the primary key of the auxiliary table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
Specifies the fillfactor and file group location for the primary key index of the auxiliary table, for example:
AUX_STORAGE |
Specifies the file group location for the auxiliary table Use
Index type for the primary key of the block table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
Specifies the file group location for the composite index on the block table Use
BLK_STORAGE |
Specifies the file group location for the block table Use
Index type for the primary key index of the band table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
BND_CLUSTER_ID |
Index type for the raster_id and sequence_nbr columns of the band table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
Specifies the fillfactor and file group location for the primary key index of the band table, for example:
BND_INDEX_ID |
Specifies the fillfactor and file group location for the raster_id and sequence_nbr column index of the band table, for example:
BND_STORAGE |
The file group location for the band table Use
RAS_CLUSTER_ID |
Index type for the primary key of the raster table If set to 0, a nonclustered index is created. If set to 1, a clustered index is created. |
RAS_INDEX_ID |
Fillfactor and location (file group) for the primary key index of the raster table Use
RAS_STORAGE |
File group location for the raster table Use
RASTER_STORAGE |
Only one raster type is supported—binary—which creates an integer field in the base table and BLOB fields in the associated raster tables. |
The B_STORAGE parameter defines the storage location for raster attribute tables. This table (or tables; there can be multiple such tables) stores attribute values based on cell values in the raster. To store these tables in a different location than feature class business tables, create a raster keyword that specifies different storage information for the raster attribute tables. Instruct data creators to use this keyword when they create raster datasets.
Parameters specific to indexes
The following describe parameters that control index storage in a geodatabase in SQL Server.
Fill-factor parameters
These parameters are structured as *_INDEX_*. They allow you to specify the FILLFACTOR argument for that index. The FILLFACTOR argument specifies the percentage of space to fill with data on each page in the leaf level of an index when the index is created or rebuilt.
SQL Server uses a default value of 0, and ArcGIS uses a default of 100. Fill-factor values 0 and 100 are equivalent; both values mean that the leaf-level pages are filled to capacity.
You can use the FILLFACTOR configuration parameter to fine-tune index pages and page splits for performance. Refer to the Microsoft SQL Server documentation for information about selecting a fill factor based on the frequency and types of updates that users will make to the table on which you define the index.
Clustered index parameters
You cannot separate a clustered index from its table; therefore, for the table parameters described in the Parameters specific to feature class and raster storage section above, specify a storage location that is the same for the table's associated clustered indexes.
These parameters are structured as *_CLUSTER_*, and they indicate whether a particular index should be clustered (1 = cluster; 0 = nonclustered). Clustered indexes store tabular data at their leaf nodes. The data pages at the clustered index leaf level derive their order from the clustered index key value. This has one important consequence with regard to the configuration parameters: you cannot separate a table from its clustered index. For example, you specify that a feature class's row ID (ROWID) index be created on the NEWIDXGRP file group while the feature class's business table should be stored on the NEWGRP file group. The ROWID index is created as clustered. The configuration settings might look like this:
keyword |
parameter_name |
config_string |
DEFAULTS |
B_CLUSTER_ROWID |
1 |
DEFAULTS |
B_INDEX_ROWID |
WITH FILLFACTOR=100 ON NEWIDXGRP |
DEFAULTS |
B_STORAGE |
ON NEWGRP |
In the preceding example, both the business table and business table's index will reside on the NEWIDXGRP file group. The business table is created first, then a primary key constraint is applied to the ROWID column. The constraint creates a clustered index on the ROWID column and references the NEWIDXGRP file group in this statement:
ALTER TABLE data.dbo.mytable
ADD CONSTRAINT f4_pk PRIMARY KEY CLUSTERED (OBJECTID)
WITH FILLFACTOR=100
ON NEWIDXGRP
Therefore, the ON NEWGRP configuration string is redundant, as the index is created after the table, and the B_INDEX_ROWID configuration string will overwrite that of B_STORAGE. The next example specifies a file group for the feature table but not for the feature table's index.
keyword |
parameter_name |
config_string |
DEFAULTS |
B_CLUSTER_ROWID |
1 |
DEFAULTS |
B_INDEX_ROWID |
WITH FILLFACTOR=100 |
DEFAULTS |
B_STORAGE |
ON NEWGRP |
In this case, both the business table and clustered index on the FID column will reside on the NEWGRP file group. This occurs because the table is created first, and when the ALTER TABLE statement is applied, no ON statement is appended because no such string is listed in the preceding config_string column.
ALTER TABLE date.dbo.mytable
ADD CONSTRAINT r15_pk PRIMARY KEY CLUSTERED (OBJECTID)
WITH FILLFACTOR=100
Parameters for storing text
The following parameters define how different types of text data are stored in a geodatabase SQL Server.
Text out of row parameters
Raster columns use varbinary(max) data types. You can use the *_OUT_OF_ROW parameters to specify whether the first 8,000 bytes of varbinary(max) data is stored in line or whether all of it is stored out of line. By default, these parameters are set to 0, meaning all the data will be stored out of line.
Text column storage parameters
There are two parameters that affect text columns in user tables: UNICODE_STRING and COLLATION_NAME. The UNICODE_STRING parameter determines whether text columns use Unicode encoding. By default, this parameter is set to TRUE, meaning all text data created using the DEFAULTS configuration keyword will be stored in Unicode format (UTF-8). If this parameter is set to FALSE, text is stored using the encoding set for the database.
If UNICODE_STRING is set to TRUE, the COLLATION_NAME parameter can be used to specify a collation for user-defined text columns that differs from the collation of the database. By default, all character data columns use the default database collation. When a new dataset (such as a table or feature class) is created, the collation specified in COLLATION_NAME is applied to every character data column. If COLLATION_NAME is blank, the database collation is used. If the UNICODE_STRING parameter is set to FALSE, the COLLATION_NAME parameter is ignored.
If you set the COLLATION_NAME parameter, use the case-sensitive version of your database collation. This usually means altering the CI in the collation name to CS. If you are unsure, check the SQL Server documentation or run the following query for a list of collation names:
SELECT * FROM ::fn_helpcollations()
The COLLATION_NAME parameter is especially important if you will store text values in Turkish. To avoid issues with uppercasing and lowercasing the letter i in the Turkish alphabet, Turkish language users should set the COLLATION_NAME parameter to indicate they are using a Turkish, case-sensitive collation for text data.
Parameters that affect spatial storage
Spatial index parameters were discussed in the Parameters specific to indexes section above. Other parameters that affect spatial data storage are GEOMETRY_STORAGE and GEOM_SRID_CHECK.
GEOMETRY_STORAGE
Geodatabases in SQL Server can use the spatial data storage formats described below. The GEOMETRY_STORAGE parameter indicates which geometry storage method to use for new feature classes.
Microsoft SQL Server Geometry type—The Microsoft spatial type for managing spatial data defined by coordinates on an arbitrary plane and for which the curvature of the Earth is not a consideration. This is the default spatial storage method of geodatabases in SQL Server. Keep the GEOMETRY_STORAGE parameter set to GEOMETRY to store your spatial data in this format. If the GEOMETRY_STORAGE parameter is not set, the GEOMETRY type is assumed.
Microsoft SQL Server Geography type—The Microsoft spatial type for managing spatial data defined by lat/long coordinates. Use this type when your features span large areas and need to take into consideration the curvature of the Earth. To make this format the default storage type for your geodatabase, set the GEOMETRY_STORAGE parameter to GEOGRAPHY under the DEFAULTS configuration keyword parameter list. To use it for only some datasets, create a custom keyword that contains the GEOMETRY_STORAGE parameter set to GEOGRAPHY and include the UI_TEXT parameter so the keyword will be available to data creators in ArcGIS client apps.
If all the feature classes in your database use the same geometry storage method, set the GEOMETRY_STORAGE parameter once in the DEFAULTS configuration keyword.
The following geometry storage types have been deprecated in ArcGIS Pro:
SDEBINARY
WKB_GEOMETRY
You cannot create feature classes that use these storage types. Currently, you can view feature classes that use these geometry storage types, but this functionality will be removed in a future release. Use the Migrate Storage geoprocessing tool to migrate feature classes to supported data types to ensure that you can continue to access the data.
GEOM_SRID_CHECK
If you create feature classes in ArcGIS that use the SQL Server geometry type, or you create a spatial table with a SQL Server geometry column using SQL and register the table with the geodatabase, all records in the table must use the same spatial reference ID (SRID).
The database management system does not enforce having a single SRID for all records in a table. Therefore, if you plan to use SQL to edit tables that have a SQL Server geometry column but are registered with the geodatabase, you may want to set the GEOM_SRID_CHECK parameter to TRUE. When this parameter is set to TRUE, ArcGIS adds a check constraint on the geometry column for a SRID value. This ensures that users editing outside of ArcGIS do not add multiple SRIDs to the same table.
Caution:
Setting this parameter to TRUE can impact performance. For that reason, do not set this parameter to TRUE if none of your users are using SQL (or third-party software) to edit spatial tables registered with the geodatabase.
Parameters for XML document storage
ArcGIS clients do not work directly with XML columns. If you do not use XML columns and XML documents in your geodatabase, you do not need to configure these parameters.
You can set the following parameters for tables that use native SQL Server XML columns (DB_XML):
XML_COLUMN_SCHEMA
XML_COLUMN_TYPE
XML_COLUMN_PATH_IDX
XML_COLUMN_SCHEMA specifies a schema collection to be used when adding or altering XML data. XML schema collections enforce schema constraints on XML data.
XML data that is associated with an XML schema collection is referred to as typed XML. The XML_COLUMN_TYPE parameter specifies what type of XML document the column stores; either CONTENT or DOCUMENT. CONTENT is the default value. DOCUMENT should only be used if the XML data has only one top-level element.
XML_COLUMN_PRIMARY_IDX, XML_COLUMN_PATH_IDX, XML_COLUMN_PROPERTY_IDX, and XML_COLUMN_VALUE_IDX determine whether primary, path, property, or value indexes will be created on the XML column.
If searches typically examine the entire content of XML documents to see whether they contain specific words, or if you don't search XML documents at all, the XML document table will be more heavily used. XML document tables will have three parameters:
XML_DOC_INDEX
XML_DOC_STORAGE
XML_DOC_OUT_OF_ROW
XML_DOC_STORAGE provides the storage string for the table's creation statement. XML_DOC_INDEX has the index fill factor and storage parameters, while XML_DOC_OUT_OF_ROW pertains to storing BLOB data out of line. See the section in the Text in row parameters topic for more information.
If individual elements are frequently searched, the XML document index table will be the most heavily accessed of the XML tables. It has more configuration parameters; they all begin with XML_IDX_.
XML_IDX_CLUSTER_ID
XML_IDX_CLUSTER_PK
XML_IDX_CLUSTER_TAG
XML_IDX_INDEX_ID
XML_IDX_INDEX_PK
XML_IDX_INDEX_TAG
XML_IDX_STORAGE
XML_IDX_OUT_OF_ROW
The XML_IDX_CLUSTER_* parameters dictate which index of the XML document index table should be clustered. By default, the primary key's index (on the xml_key_column) is clustered.
The following parameters affect both the XML document table and the XML document index table for an XML column. They control how and when the document content is indexed.
XML_IDX_FULLTEXT_CAT contains the name of the full-text catalog you created. The default is SDE_DEFAULT_CAT. If you name your full-text catalog something other than SDE_DEFAULT_CAT, you must update the config_string for this parameter.
XML_IDX_FULLTEXT_LANGUAGE represents the language to be used for linguistic analysis when building the text indexes on the XML document's content. A default value is not provided; therefore, the language defined for the SQL Server default full-text language setting is used. If a value is provided, this language will be used for linguistic analysis instead.
XML_IDX_FULLTEXT_TIMESTAMP and XML_IDX_FULLTEXT_UPDATE_METHOD control full-text index maintenance. The update_method parameter dictates how changes made to the document table are propagated to the full-text index. The time stamp parameter, by default (1), will add a time stamp column to the SDE_xml_idx<xml_column_id> table. If set to 0, no such column is added.
If update_method is set to 0 and time stamp is set to 0, no index maintenance is performed, and whenever ArcGIS is instructed to update the full-text index (through SE_xmlindex_update_text_index), the index will be fully populated.
If update_method is set to 0 and time stamp is set to 1, no index maintenance is performed, and ArcGIS will perform an incremental index population of whatever has changed since the last incremental update.
If update_method is set to CHANGE_TRACKING MANUAL, the database maintains a list of changed rows but does not update the index.
If update_method is set to CHANGE_TRACKING BACKGROUND, the database tracks changes and automatically updates the index.
It is recommended that you use the default settings provided with the geodatabase. If your server is unable to service its workload and your only recourse is to change indexing behavior, set change tracking to manual (CHANGE_TRACKING MANUAL).
The next parameters, XML_IDX_INDEX_*, control index fill factor and storage on the SDE_xml_idx<xml_column_id> table. The XML_IDX_TEXT_IN_ROW controls how much of the XML document BLOB can be in-line. As with most text in row settings, it is recommended that you do not change the defaults.
Parameters that affect log file tables and indexes
Log file tables are used by ArcGIS to maintain temporary and persistent sets of selected records.
Session log file tables are always created in tempdb in geodatabases in SQL Server. Even if log file table parameters are present in SDE_dbtune table, they are ignored.
Additional configuration parameters
Some parameters do not fit well in a particular category. These are described in this section.
NUM_DEFAULT_CURSORS parameter
The NUM_DEFAULT_CURSORS parameter controls the cursor threshold. It specifies the number of rows in a cursor set for which cursor keysets will be generated asynchronously. The default value of -1 means all keysets are generated synchronously, which is better for smaller cursor sets. If you set it to 0, all cursor keysets are generated asynchronously. If you use a value other than 0 or -1, the Query Optimizer compares the number of expected rows in the cursor set to the number set in the cursor threshold, then builds the keyset asynchronously if it exceeds the cursor threshold number. Asynchronous population means that you can access rows already in the cursor while the cursor is being populated. With synchronous population, all rows are put in the cursor before any are accessible.
Caution:
It is best not to alter the default value; changes made to this value affect the entire server. It is difficult to determine how big your average cursor keyset is going to be. Unless you know that changing this value is going to help performance, it is best not to change it.
Although still present in the geodatabase, this parameter no longer affects connection performance to any great degree. By default, the setting is disabled (it is set to -1).
When this parameter was added, the method for determining object privileges in the database required querying a database system table and building a list of the datasets to which the connecting user had access. Connection performance was sometimes slow if the database contained a large number of objects. SQL Server subsequently improved how this information is accessed, thereby rendering this parameter obsolete.
The PERMISSION_CACHE_THRESHOLD builds a temporary table if the initial query of object permission information exceeds the threshold, in milliseconds, that you set for the parameter. The maximum setting is 1,000 milliseconds. If you set PERMISSION_CACHE_THRESHOLD to 0, the temporary table is always built, and stores the permission for the duration of the connection.
PERMISSION_CACHE_THRESHOLD can be used only in the DEFAULTS parameter group. The temporary table persists for the duration of the connection, so if the connecting user's permissions change during the session, changes won't be seen until the user disconnects and reconnects to the database.
User interface parameters
User interface parameters begin with UI and indicate whether their associated configuration keyword will be available through the ArcGIS user interface and ArcObjects. UI_TEXT is used for noncomposite configuration keywords. UI_TOPOLOGY_TEXT is used for topology keywords. UI_NETWORK_TEXT is used for network keywords. The default configuration keywords that need UI parameters already have them. You would only add one of these parameters if you created your own custom keywords.
Parameters for deprecated geometry storage types
Compressed binary geometry storage formats—ArcSDE compressed binary (SDEBINARY) and Open Geospatial Consortium (OGC) well-known binary (OGCWKB)—were deprecated as of the ArcGIS Pro 2.6 and ArcGIS Enterprise 10.8.1 releases. Support for these data types will end in an upcoming ArcGIS release. Use the Migrate Storage geoprocessing tool to migrate feature classes to a supported geometry storage type.
Because you cannot create feature classes that use this storage type from ArcGIS Pro or use tools run from ArcGIS Server 11.0 or later, new geodatabases will not contain configuration parameters and keywords used to control binary geometry storage. This starts with geodatabases created using ArcGIS Pro 3.2 or tools installed with ArcGIS Server 11.2.
If you created the geodatabase with ArcGIS Pro 3.1 or earlier or tools installed with ArcGIS Server 11.1 or earlier, these parameters and keywords will still be present unless you removed them; upgrading the geodatabase will not remove them.
These parameters include those beginning with F_ and S_, ending with _SHAPE, and configuration keywords referring to SDEBINARY.
