Export Geodatabase Configuration Keywords (Data Management Tools)
Summary
Exports the configuration keywords, parameters, and values from the specified enterprise geodatabase to an editable file. Change parameter values or add custom configuration keywords to the file and use the Import Geodatabase Configuration Keywords tool to import the changes to the geodatabase.
Usage
This tool only works with enterprise geodatabases.
Only the geodatabase administrator can run the Export Geodatabase Configuration Keywords tool.
This tool is not supported for geodatabases in SAP HANA.
Parameters
| Label | Explanation | Data type |
Input Database Connection |
The connection file for the enterprise geodatabase from which you want to export configuration keywords, parameters, and values. You must connect as the geodatabase administrator. |
Workspace |
Output File |
The full path to and name of the ASCII text file to be created. The file will contain all the configuration keywords, parameters, and values from the enterprise geodatabase's DBTUNE (or SDE_DBTUNE) system table. |
File |
Derived output
Input Workspace |
The input workspace. |
Workspace |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
