Create Random Points (Data Management Tools)
Summary
Creates a specified number of random point features. Random points can be generated in an extent window, inside polygon features, on point features, or along line features.
Learn more about how Create Random Points works
Usage
  • The area in which random points will be generated can be defined either by constraining polygon, point, or line features or by a constraining extent window.
  • The Number of Points parameter can be specified as a number or as a numeric field in the constraining feature class containing values for how many random points to place within each feature. The field option is only valid for polygon or line constraining features. If the number of points is supplied as a number, each feature in the constraining feature class will have that number of random points generated inside or along it.
    If you are using a constraining feature class that has more than one feature, and you wish to specify the total number of random points to be generated (as opposed to the number of random points to be placed inside each feature), first use the Dissolve tool so that the constraining feature class only contains a single feature; then use that dissolved feature class as the constraining feature class.
  • The coordinate system of the output feature class will be the coordinate system of the
    • Constraining feature class if one is specified
    • Map data frame if a constraining extent is specified in the map using a layer in the map or the path to a feature class
    • Feature class if a constraining extent is specified in Python by using the path to a feature class
    • Output Coordinate System geoprocessing environment if it is set (and overrides all other behaviors detailed above)
    • Unknown if none of the above applies
  • To assign random values to randomly placed points, first generate random points using this tool. Second, use the Add Field tool to create a new numeric field in the random points feature class. Suggested field types are long integer or float. Third, use the Calculate Field tool to assign random values to the empty field in the random points feature class. To generate a random integer between a and b (inclusively), use the Python expression random.randint(a,b). To generate a random float number between a and b (exclusively), use the Python expression random.uniform(a,b). In the code block, import the random module using the expression import random.
  • The Constraining Extent parameter can be entered as a set of minimum and maximum x- and y-coordinates or as equal to the extent of a feature layer or feature class.
  • If both a constraining feature class and constraining extent are specified, the constraining feature class value will be used and the constraining extent value will be ignored.
  • When unable to place anymore random points within a constraining area without breaking the minimum allowed distance specified, the number of random points in the constraining area will be reduced to the maximum possible under the minimum allowed distance.
  • The Minimum Allowed Distance parameter can be specified as a linear unit or a field from the constraining features containing numeric values. This value will determine the minimum allowed distance between random points within each input feature. The field option is only valid for polygon or line constraining features. Random points may be within the minimum allowed distance if they were generated inside or along different constraining feature parts.
  • Using point features as the constraining feature class creates a random subset of the constraining point features. No new point locations are generated.
  • Noninteger (whole) positive values for the Number of Points and Minimum Allowed Distance parameters will be rounded to the nearest whole number. Nonnumeric and negative values are set to 0.
Parameters
Label Explanation Data type
Output Location
The location or workspace in which the random points feature class will be created. This location or workspace must already exist.
Feature Dataset; Workspace
Output Point Feature Class
The name of the random points feature class to be created.
String
Constraining Feature Class
(Optional)
Random points will be generated inside or along the features in this feature class. The constraining feature class can be point, multipoint, line, or polygon. Points will be randomly placed inside polygon features, along line features, or at point feature locations. Each feature in this feature class will have the specified number of points generated inside it (for example, if you specify 100 points, and the constraining feature class has 5 features, 100 random points will be generated in each feature, totaling 500 points).
Feature Layer
Constraining Extent
(Optional)
Random points will be generated inside the extent. The constraining extent will only be used if no constraining feature class is specified.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent; Feature Layer; Raster Layer
Number of Points [value or field]
(Optional)
The number of points to be randomly generated.
The number of points can be specified as a long integer number or as a field from the constraining features containing numeric values for how many random points to place within each feature. The field option is only valid for polygon or line constraining features. If the number of points is supplied as a long integer number, each feature in the constraining feature class will have that number of random points generated inside or along it.
Field; Long
Minimum Allowed Distance [value or field]
(Optional)
The shortest distance allowed between any two randomly placed points. If a value of 1 Meter is specified, all random points will be farther than 1 meter away from the closest point.
Field; Linear Unit
Create Multipoint Output
(Optional)
Specifies whether the output feature class will be a multipart or single-part feature class.
  • Checked—The output will be geometry type multipoint (all points are a single feature).
  • Unchecked—The output will be geometry type point (each point is a separate feature). This is the default.
Boolean
Maximum Number of Points per Multipoint
(Optional)
If Create Multipoint Output is checked, specify the number of random points to be placed in each multipoint geometry.
Long
Derived output
Output Feature Class
The output random points feature class.
Feature Class
Environments
Default Output Z Value, M Resolution, M Tolerance, Output M Domain, Output XY Domain, Output Z Domain, Output Coordinate System, Current Workspace, Geographic Transformations, Scratch Workspace, Output has M values, Output has Z values, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Random number generator, Extent
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
