Upgrade Dataset (Data Management Tools)
Summary
Upgrades the schema of a mosaic dataset, network dataset, annotation dataset, dimension dataset, parcel fabric, trace network, utility network, or 3D object feature class to the current ArcGIS release. Upgrading a dataset enables it to use new functionality in the current software release.
Usage
  • Before you upgrade a dataset, create a backup of it.
  • Use the Upgrade Geodatabase tool to upgrade the geodatabase to the current release before running this tool to upgrade any dataset except a trace network or utility network.
    • When upgrading ArcGIS Pro annotation and dimensions to ArcGIS Pro 3.0, the Upgrade Geodatabase tool does not need to be run.
  • For utility networks, see Utility network dataset administration for additional requirements.
  • For trace networks, see Trace network dataset administration for additional requirements.
  • When upgrading a parcel fabric dataset, the following are required:
    • An exclusive lock must be used, meaning that you must close active connections to the dataset, which may include stopping the parcel fabric layer service.
    • The input parcel fabric must be from a database connection established as the database parcel fabric owner.
  • Versioned annotation and dimension feature classes that are stored in an enterprise geodatabase must be unregistered as versioned prior to the upgrade.
  • In an ArcGIS Desktop annotation feature class, graphics that are not text graphics are not supported by the upgrade process and will be deleted. A list of their OIDs will be created and included in the tool's messages.
    Learn more about moving the graphics out of the annotation feature class
    Legacy:
    ArcGIS Desktop 8.x annotation can be upgraded to ArcGIS Pro annotation using this tool. Fields will be added to the feature class (TextString, FontName, FontStyle, and so on) and a symbol will be added to the symbol collection.
  • Once upgraded, an annotation dataset is no longer available for use in previous versions. The present version of an annotation feature class is displayed on the Source tab of the Feature Class Properties dialog box. The following table describes how annotation is supported:
    ArcGIS version
    ArcGIS Pro annotation 2.x
    ArcGIS Pro annotation 3.x
    ArcGIS Desktop
    10.x
    Full read, modify, and write access.
    Not supported. Any feature class linked to it or in the same feature dataset will be read-only.
    ArcGIS Pro 1.x
    Read-only access.
    ArcGIS Pro 2.x
    Read-only access.
    ArcGIS Pro 3.x
    Read-only access.
    Full read access. Partial modify and write access. It may be downgraded based on symbols and annotation properties used.
    Consult the Companion ArcGIS Pro and ArcGIS Enterprise versions section in the Release notes when using annotation with ArcGIS Enterprise. The ArcGIS Enterprise version must match or be later than the ArcGIS Pro version for use in GIS services. For example, ArcGIS Pro 3.x annotation requires ArcGIS Enterprise 11.0 or later.
  • Once upgraded, a dimension dataset is no longer available for use in previous versions. The present version of a dimension feature class is displayed on the Source tab of the Feature Class Properties dialog box. The following table describes how annotation is supported:
    ArcGIS version
    ArcGIS Desktop dimensions
    ArcGIS Pro dimensions 2.x
    ArcGIS Pro dimensions 3.x
    ArcGIS Desktop
    10.x
    Not supported. Any feature class in the same feature dataset will be read-only.
    ArcGIS Pro 1.x
    Read-only access.
    ArcGIS Pro 2.x
    Read-only access.
    ArcGIS Pro 3.x
    Read-only access.
    Full read access. Partial modify and write access. It may be downgraded based on symbols and dimension properties used.
    Consult the Companion ArcGIS Pro and ArcGIS Enterprise versions section in the Release notes when using dimensions with ArcGIS Enterprise. The ArcGIS Enterprise version must match or be later than the ArcGIS Pro version for use in GIS services. For example, ArcGIS Pro 3.x dimensions require ArcGIS Enterprise 11.0 or later.
  • If a catalog dataset created in ArcGIS Pro 3.1 is upgraded in ArcGIS Pro 3.6 or later versions, the upgraded catalog dataset is no longer available for use in ArcGIS Pro 3.1.
Parameters
Label Explanation Data type
Dataset to upgrade
The dataset that will be upgraded to the current ArcGIS client release.
Parcel Fabric Layer for ArcMap; Parcel Layer; Mosaic Layer; Network Dataset Layer; Trace Network Layer; Utility Network Layer; Annotation Layer; Dimension Layer; Catalog Layer; 3D Object Feature Layer
Utility Network Version
(Optional)
Specifies the version of the utility network that will be created.
  • Compatible—The latest version of the utility network compatible with the current ArcGIS Pro and ArcGIS Enterprise releases will be created. When you are working in a single-user deployment, the latest version of the utility network compatible with the current ArcGIS Pro release will be created. When working in an enterprise deployment, the latest version of the utility network compatible with the current ArcGIS Enterprise release will be created. In a multimachine deployment where various versions of ArcGIS Enterprise are installed, all of the portal's federated servers will be checked to create a version of the utility network that is compatible with the latest release available. This is the default.
  • Current—The latest version of the utility network compatible with the current ArcGIS Pro release will be created.
  • 8—A version 8 utility network will be created.
  • 7—A version 7 utility network will be created.
  • 6—A version 6 utility network will be created.
  • 5—A version 5 utility network will be created.
String
Derived output
Upgraded Dataset
The upgraded input dataset.
Parcel Fabric Layer for ArcMap; Parcel Layer; Mosaic Dataset; Network Dataset Layer; Trace Network Layer; Utility Network Layer; Annotation Layer; Dimension Layer; Catalog Layer; 3D Object Feature Layer
Environments
Current Workspace
Licensing information
  • Basic: Yes
    ArcGIS Desktop Standard or Desktop Advanced license is required to upgrade mosaic datasets.
  • Standard: Yes
  • Advanced: Yes
