Utility network compatibility
As an administrator, it is important to be aware of the compatibility between ArcGIS clients, the geodatabase, and the version of the utility network dataset when working with mixed releases to understand the functionality and capabilities that are available.
In an enterprise deployment of the utility network that uses a services-based architecture, the available capabilities are dependent on the ArcGIS Pro and ArcGIS Enterprise releases as well as the version of the utility network. In a single-user deployment of the utility network, functionality is dependent on the ArcGIS Pro release and the version of the utility network. While not required, it is recommended that you keep the versions in sync when possible, as these pieces of software are designed to work together.
Utility network version
The Utility Network Version value indicates the schema version of the utility network dataset and is recorded in the General section of the Network Properties tab on the Utility Network Properties dialog box.
The following table outlines the utility network version created with different releases of ArcGIS Pro and ArcGIS Enterprise when creating or upgrading a utility network dataset:
Compatible ArcGIS Pro version
Compatible ArcGIS Enterprise version
2.6 and later
10.8.1 and later
2.7 and later
10.9 and later
6
3.0 and later
11.0 and later
7
3.3 and later
11.3 and later
Utility network version when creating or upgrading a utility network dataset with ArcGIS Pro and ArcGIS Enterprise versions
While Utility Network Version 8 is supported in both ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1, this is primarily intended to support working with the telecom domain network. The Compatible and Current options in the choice list for the Utility Network Version parameter on the Create Utility Network tool and Upgrade Dataset tool will continue to create a Utility Network Version 7 using these releases. You can explicitly select the option from the Utility Network Version dropdown in these tools to create a version 8 dataset.
Create or upgrade a utility network
A utility network can be created in an enterprise, file, or mobile geodatabase. To create a utility network in an enterprise geodatabase, the underlying database platform must meet the minimum supported release for ArcGIS Enterprise. Starting with ArcGIS Pro 3.5, you can specify the version of the utility network that is created with the Migrate To Utility Network or Create Utility Network tools. By default, the latest version of the utility network compatible with the current ArcGIS Pro and ArcGIS Enterprise release will be created. ArcGIS Utility Network is supported on the following on-premise and cloud database platforms in ArcGIS Enterprise:
Learn more about the ArcGIS requirements for using databases in the cloud
Dive in:
The ArcGIS Architecture Center provides information and resources focused on the patterns and best practices for building a well architected system in ArcGIS. This can help provide context and guidance while architecting and deploying a system which makes the most of your investment with ArcGIS Utility Network.
An upgrade of the utility network dataset is needed to take advantage of new functionality introduced through schema changes in the information model. When working with an enterprise deployment, the version of ArcGIS Pro and ArcGIS Enterprise, as well as the current Utility Network Version value, determine whether an upgrade is available.
Keep in mind that not every ArcGIS Pro and ArcGIS Enterprise release introduce schema changes, and an upgrade of the utility network dataset is not required when moving to a new release. Upgrading is only required to take advantage of functionality introduced in a new version of the utility network. Starting with ArcGIS Pro 3.7, you can specify the version of the utility network that will be upgraded to with the Upgrade Dataset tool. By default, the latest version of the utility network compatible with the current ArcGIS Pro and ArcGIS Enterprise release will be created.
Keep the following in mind when considering the type of deployment and the compatible utility network version:
  • When using an enterprise deployment, the version of ArcGIS Pro and the portal's federated server are used to determine the compatible Utility Network Version value.
    • When working in a multiple-machine deployment in which various versions of ArcGIS Enterprise are installed, all of the portal's federated servers are checked to create a version of the utility network that is compatible with the latest release available.
  • When using a single-user deployment of the utility network, the version of ArcGIS Pro alone determines the compatible Utility Network Version value.
    • If you create a utility network in a single-user deployment with plans to migrate, ensure that the ArcGIS Pro release used will create a version of the utility network compatible with the target ArcGIS Enterprise release.
Using the table above, the following scenarios illustrate how the Utility Network Version value is determined on creation and upgrade:
  • Creating a utility network in an enterprise deployment with ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1 using the default Utility Network Version value of Compatible creates Utility Network Version 7.
  • Creating a utility network in an enterprise deployment with ArcGIS Pro 3.7 and ArcGIS Enterprise 11.1 using the default Utility Network Version value of Current creates Utility Network Version 7.
  • Creating a utility network in an enterprise deployment with ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1 using the Utility Network Version value of 8 creates Utility Network Version 8.
  • Creating a utility network in an enterprise deployment with ArcGIS Pro 3.5 and ArcGIS Enterprise 11.5 using the default Utility Network Version value of Compatible creates Utility Network Version 7.
  • Creating a utility network in an enterprise deployment with ArcGIS Pro 3.3 and ArcGIS Enterprise 11.3 creates Utility Network Version 7.
  • Creating a utility network in an enterprise deployment with ArcGIS Pro 3.1 and ArcGIS Enterprise 11.3, creates Utility Network Version 6.
  • Upgrading Utility Network Version 6 in an enterprise deployment using ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1 creates Utility Network Version 7.
  • Upgrading Utility Network Version 3 in an enterprise deployment using ArcGIS Pro 3.5 and ArcGIS Enterprise 11.1 creates Utility Network Version 6.
  • Creating or upgrading a utility network in a single-user deployment with ArcGIS Pro 3.7 creates Utility Network Version 7.
  • Creating or upgrading a utility network in a single-user deployment with ArcGIS Pro 3.5 creates Utility Network Version 7.
Learn more about upgrading a utility network dataset
Access and work with a utility network
As a general rule for working with mixed releases and the utility network, ArcGIS client applications (such as ArcGIS Pro and ArcGIS Enterprise) are backward compatible. In other words, later versions of ArcGIS Pro and ArcGIS Enterprise can always access, consume, edit, and share earlier versions of the utility network. The following examples illustrate backward compatibility with the utility network:
  • ArcGIS Pro 3.7 can access, edit, and share Utility Network Version 8 in ArcGIS Enterprise 12.1.
  • ArcGIS Pro 3.5 can access, edit, and share Utility Network Version 7 in ArcGIS Enterprise 11.5.
  • ArcGIS Pro 3.3 can access, edit, and share Utility Network Version 5 in ArcGIS Enterprise 11.3.
  • ArcGIS Pro 3.3 can access, edit, and share Utility Network Version 4 in ArcGIS Enterprise 10.9.1.
  • ArcGIS Pro 3.1 can access, edit, and share Utility Network Version 6 in ArcGIS Enterprise 11.3.
In an enterprise deployment, earlier versions of ArcGIS Pro can be used to access and edit later versions of the utility network through a service as long as the utility network version is supported by the ArcGIS Enterprise release and does not participate in newer functionality. This is helpful when you are working with a newer version of the utility network to support workflows for some clients but continue to have editors using earlier versions of ArcGIS Pro.
Caution:
Earlier client software releases may not be able to open or work with utility network datasets that participate in newer functionality as follows:
  • You cannot open a utility network layer that contains newer field types such as big integer or 64-bit object ID fields using a client that does not support them.
  • The use of attribute rules can impact backward compatibility of a utility network if using functions released with a specific Arcade version.
  • ArcGIS Field Maps and ArcGIS Maps SDK for Native Apps do not currently support Utility Network Version 8 with ArcGIS Enterprise 12.1. To maintain compatibility, specify an earlier version when you create or upgrade a utility network dataset.
The following examples illustrate forward compatibility when working with a utility network through a service with mixed releases:
  • ArcGIS Pro 3.5 can access and edit a Utility Network Version 7 service in ArcGIS Enterprise 12.1.
  • ArcGIS Pro 3.3 can access and edit a Utility Network Version 7 service in ArcGIS Enterprise 11.5.
  • ArcGIS Pro 3.1 can access and edit a Utility Network Version 6 service in ArcGIS Enterprise 11.5.
  • ArcGIS Pro 3.1 cannot be used to share Utility Network Version 7. This is because the ArcGIS Pro 3.1 client does not support opening Utility Network Version 7 through a database connection.
  • ArcGIS Pro 3.7 cannot be used to share Utility Network Version 8 in ArcGIS Enterprise 11.1. This is because ArcGIS Enterprise 11.1 does not support that utility network version.
In a single-user deployment, earlier versions of ArcGIS Pro cannot open later versions of the utility network. As an example, ArcGIS Pro 3.1 cannot open Utility Network Version 7 in a file geodatabase, mobile geodatabase, or through an enterprise database connection.
Learn more about client and geodatabase compatibility
