Unregister As Versioned (Data Management Tools)
Summary
Unregisters an enterprise geodatabase dataset as versioned.
Usage
  • The input dataset must be from a database connection established as the data owner.
  • An exclusive lock is required on the dataset.
  • Unregistering a branch versioned dataset without first posting all named versions to the default version may result in a loss of edits.
  • Unregistering a traditional versioned dataset without first compressing the geodatabase may lead to loss of edited data.
Parameters
Label Explanation Data type
Input Dataset
The name of the dataset to be unregistered as versioned.
Table View; Feature Dataset
Do not run if there are versions with edits
(Optional)
Specifies whether edits made to the versioned data will be maintained.
  • Checked—When there are outstanding edits that could be lost, the tool will fail. Outstanding edits include edits in the delta tables (traditional versioned dataset) and edits in named versions (branch versioned dataset). This is the default. For traditional versioned datasets, do not use this option when compressing edits from the Default version in the Compress all edits in the Default version into the base table parameter.
  • Unchecked—When there are outstanding edits, the tool will delete the edits. For traditional versioned datasets, use this option when compressing edits from the Default version in the Compress all edits in the Default version into the base table parameter.
Boolean
(Optional)
Specifies whether edits will be compressed and unused data will be removed. This option is ignored if the Do not run if there are versions with edits parameter is checked.
This parameter is only applicable for traditional versioned datasets.
  • Checked—Edits in the Default version will be compressed to the base table.
  • Unchecked—Any edits remaining in the delta tables will not be compressed. This is the default.
Boolean
Derived output
Unregistered Dataset
The unregistered dataset.
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
