Register a dataset as traditional versioned
Available with Standard or Advanced license.
When you initially add or create a dataset in an enterprise geodatabase, the dataset is not registered as versioned, and it is considered nonversioned data. Before you can edit a dataset in a version, you must register the dataset as versioned. To learn more about why you would want to edit a dataset in a version, see Overview of versioning.
There are two versioning types you can use when registering datasets as versioned:
Branch versioning—Facilitates the Web GIS model by allowing multiuser editing scenarios and long transactions while working with web feature layers. For more information, see Branch version scenarios.
Traditional versioning—Provides the flexibility to work within versions for long transactions when accessed directly from the enterprise geodatabase and a simplified editing experience when using feature services to accommodate shorter transactions. For more information, see Traditional version scenarios.
- Traditional versioning with the option to move edits to base—An optional form of traditional versioning that allows editors and applications to have direct access to the base data while also allowing other editors to work in their own isolated versions
Learn more about versioning types
Regardless of the type of versioning used, it is recommended that you complete any data loading prior to registration. All versioning types add a number of system-maintained tables, indexes, and attributes that can add to the processing time of data loading operations.
Before registering a dataset as traditional versioned, ensure your dataset is supported. You cannot register a dataset as traditional versioned if any of the following are true:
The dataset is already registered as versioned.
The dataset has archiving enabled.
The dataset has unique indexes defined.
Register a dataset as versioned
To register your dataset as versioned using traditional versioning, complete the following steps:
Connect to your enterprise geodatabase as the dataset owner in the Databases folder
of the Catalog pane
.Right-click the dataset and click Manage.
The properties dialog box appears with the Manage tab active.
Check Versioning and select Traditional.
Click OK.
The dataset is now registered as versioned.
When you register your data as traditional versioned, two delta tables are created to track insert, update, and delete operations performed on the data. Therefore, a versioned dataset consists of the original table (called the business or base table) plus any changes stored in the delta tables.
Registering a dataset creates the supporting delta tables: the adds (A) and deletes (D) tables, as well as attribute indexes. The A and D tables and their attribute indexes have the potential to be among the most active in your geodatabase. In this case, these tables are read during all queries on the feature class or table. Also, anytime a user makes an edit, a row is added to one or both of these tables, so the tables grow quickly in an actively edited geodatabase. For this reason, data administrators need to plan for their storage and periodic compression operations to maintain optimum performance. For more information about version administration tasks, see Recommended version administration workflow.
Register as versioned with the option to move edits to base
Registering data as versioned with the option to move edits to base is designed to support nonversioned edits by third-party applications while still providing the traditional versioning benefits of long transactions and isolated editing. This causes edits that have been saved to the default version, whether edited directly or merged from other versions, to be saved in the base (business) tables. Edits to other versions remain in the delta tables when you save. This option is available for simple features only—those that do not participate in a topology, network dataset, or utility network.
of the Catalog pane
Under Traditional, check Move edits to base.
Click OK.
The dataset is now registered as versioned with the option to move edits to base.
Unregister a dataset as versioned
You may want to unregister a dataset as versioned if it is no longer needed in the versioning environment or if you need to perform data loading and don't want the overhead from the extra version tables and indexes. To unregister as versioned, an exclusive lock is required on the dataset.
Caution:
When you unregister a dataset as versioned, all edits in named versions that are not posted to default and compressed will be deleted. To prevent these edits from being lost, ensure that all named versions are reconciled and posted to default before unregistering the dataset as versioned. Additionally, ensure the geodatabase is compressed before unregistering the dataset as versioned.
of the Catalog pane
Uncheck Versioning.
Click OK.
The dataset is now unregistered as versioned.
