Add Spatial Index (Data Management Tools)
Summary
Adds a spatial index to a shapefile, file geodatabase, mobile geodatabase, or enterprise geodatabase feature class. Use this tool to either add a spatial index to a shapefile or feature class that does not already have one or to re-create an existing spatial index.
Usage
ArcGIS uses spatial indexes to quickly locate features in feature classes. Identifying a feature, selecting features by pointing or dragging a box, and panning and zooming all require a spatial index to locate features. The spatial index is defined by using a grid-based system that spans the extent of the features in a feature class, like a locator grid you might find on a common road map.
By default, ArcGIS creates and maintains a spatial index for geodatabase feature classes. For a geodatabase feature class to not have a spatial index, you must explicitly remove it using the Remove Spatial Index tool.
Adding a new spatial index to an enterprise geodatabase feature class is a server-intensive operation. It should not be done on large feature classes when a large number of users are logged in to the server.
For SQL Server and Oracle feature classes, if the index already exists, the index will be dropped and recreated. The bounding box will also be recalculated for SQL Server feature classes.
SAP HANA feature classes do not support spatial indexes.
Parameters
| Label | Explanation | Data type |
Input Features |
An enterprise geodatabase feature class, file geodatabase feature class, mobile geodatabase feature class, or shapefile to which a spatial index is to be added or rebuilt. |
Feature Layer; Mosaic Layer |
Spatial Grid 1 (Optional) |
This parameter has been deprecated in ArcGIS Pro. Any value you enter will be ignored. |
Double |
Spatial Grid 2 (Optional) |
Double |
Spatial Grid 3 (Optional) |
Double |
Derived output
Updated Input Features |
The updated input features. |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
