Upgrade Scene Layer (Data Management Tools)
Summary
Upgrades a scene layer to the current I3S version in SLPK format or output to i3sREST format for use in ArcGIS Enterprise.
Usage
  • Version 1.4 and later scene layer packages can be converted to the latest I3S version. The I3S version for a scene layer is on the Source tab of the layer properties. See the I3S specification for the current version for each scene layer type. If the scene layer is version 1.6 or earlier, it is recommended that you upgrade for performance improvements.
  • Point cloud scene layers are not currently supported.
  • Use the Texture Optimization parameter to add or remove textures in the output scene layer package.
  • Warnings encountered during the upgrade process may be reported to the tool messages or the output log file. Warnings do not affect display of the scene layer package but may indicate noncompliance with the I3S specification.
  • Use the Target Cloud Connection parameter to output scene layer content to an object store located in the cloud such as Amazon S3, Azure Blob storage, Alibaba OSS, or Google Cloud. This content can be published as a scene service and the location you choose must be registered as a user-managed data store in ArcGIS Enterprise.
  • This tool does not fix scene layer packages that have missing or incorrect required properties from the I3S specification. Errors are written to the Output Log File parameter value.
  • Use the Time Zone environment together with the Date Format parameter to properly encode date fields in the output scene layer package. For more information about enabling time on scene layers, see Time-enabled scene layers.
Parameters
Label Explanation Data type
Input Dataset
The input scene layer or scene layer package.
File; Scene Layer
Output Folder
The location where the output scene layer package will be created or the cloud connection file (.acs) to output to i3sREST format.
Folder
Output Name
The name of the output scene layer.
String
Output Log File
(Optional)
The output log file that will summarize the results of the evaluation.
File
(Optional)
Specifies the textures that will be optimized according to the target platform where the scene layer package is used.
Caution:
Optimizations that include KTX2 may take significant time to process. For fastest results, use the Desktop or None options.
  • All—All texture formats, including JPEG, DXT, and KTX2, will be optimized for use in desktop, web, and mobile platforms.
  • Desktop—Windows, Linux, and Mac supported textures, including JPEG and DXT, will be optimized for use in ArcGIS Pro clients on Windows and ArcGIS Maps SDKs desktop clients on Windows, Linux, and Mac. This is the default.
  • Mobile—Android and iOS supported textures, including JPEG and KTX2, will be optimized for use in ArcGIS Maps SDKs mobile applications.
  • None—JPEG textures will be optimized for use in desktop and web platforms.
String
Date Format
(Optional)
The format of the date values in the scene layers date fields. This parameter is hidden if no date fields are encountered.
String
Environments
Time Zone
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
