Create Table (Data Management Tools)
Summary
Creates a geodatabase table or a dBASE table.
Usage
  • To create a dBASE table in a folder, append the .dbf extension to the Table Name parameter value.
  • This tool supports creating a table in a memory workspace.
Parameters
Label Explanation Data type
Table Location
The workspace where the output table will be created.
Workspace
Table Name
The name of the table that will be created.
String
Template Datasets
(Optional)
One or more datasets from which the attribute schema will be used to define the output table. Fields in the template datasets will be added to the output table.
Table View
Configuration Keyword
(Optional)
The configuration keyword that determines the storage parameters of the table in an enterprise geodatabase.
String
Table Alias Name
(Optional)
The alternate name of the output table that will be created.
String
OID Type
(Optional)
Specifies whether the output Object ID field will be 32 bit or 64 bit.
  • Same as template—The output Object ID field type (32 bit or 64 bit) will be the same as the Object ID field of the first template dataset. This is the default.
  • 64-bit—The output Object ID field will be 64 bit.
  • 32-bit—The output Object ID field will be 32 bit.
String
Derived output
Output Table
The new output table.
Table
Environments
Current Workspace, Output CONFIG Keyword, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
