Disable Attachments (Data Management Tools)
Summary
Disables attachments on a geodatabase feature class or table. The tool deletes the attachment relationship class and attachment table.
Usage
If the input dataset is from an enterprise geodatabase, it must be from a database connection established as the data owner.
This tool permanently deletes all attachments internally stored in the geodatabase and associated with the Input Dataset. If attachments are enabled after being disabled, no attachments that were previously associated with the feature class or table will be present.
If the geodatabase feature class or table does not have attachments enabled, a warning message will appear and no processing will occur.
Parameters
| Label | Explanation | Data type |
Input Dataset |
The geodatabase table or feature class for which attachments will be disabled. The input must be in a version 10 or later geodatabase. |
Table View |
Derived output
Updated Input Dataset |
The updated input dataset. |
Table View |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
