Generate Symbol Rotation Attribute Rule (Data Management Tools)
Summary
Generates an attribute rule specific to symbol rotation logic. The tool outputs a .csv file containing an ArcGIS Arcade attribute rule based on the inputs provided.
Usage
  • The Output Folder parameter specifies where a folder will be created using the name of the input feature class. The output .csv file will use the Rotation Field parameter value. If the tool is run multiple times, additional .csv files will be added to the folder.
  • After the tool has been run, import the attribute rule and apply it to the dataset. If the dataset is in an enterprise geodatabase, you must be the data owner to apply the output template attribute rule.
    Learn more about importing attribute rules
Parameters
Label Explanation Data type
Input Table
The point feature class that the new rule will be applied to.
Feature Layer
Output Folder
The folder where the output .csv file will be saved. The name of the file will be the same as the Input Table parameter value.
String
Rotation Field
The name of an existing field to which the rule will be applied.
Field
Intersecting Line Classes
The line feature classes that will be used to intersect the point feature class. The orientation field is a numeric field that is used as a tie breaker when there are multiple intersecting lines.
Value table columns:
  • Line Class—The line feature classes that are used to intersect the point feature class.
  • Orientation Field—Orientation field is a numeric field that is used as a tie breaker when there are multiple intersecting lines.
Value Table
Expression
(Optional)
A SQL expression that limits the features the attribute rule will be applied to.
SQL Expression
Rotation Options
(Optional)
The rotation options for the point feature class.
  • Point Class Expression—A SQL query that will further limit the features the attribute rule will be applied to. The default is none.
  • Rotation Style—Specifies how the direction will be measured.
    • Arithmetic—The rotation will start at zero in the east direction and is calculated counterclockwise. This is the default.
    • Geographic—The rotation will start at zero in the north direction and is calculated clockwise.
  • Rotate Towards—Specifies whether the feature will be oriented toward the maximum or minimum value.
    • Minimum—The feature will be oriented toward the minimum value. This is the default.
    • Maximum—The feature will be oriented toward the maximum value.
  • Additional Rotation—The rotation value that will be added to the calculated rotation value. The default is 0.
Value Table
Derived output
Output CSV File
The output .csv file containing the template attribute rule.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
