Repair Trajectory Dataset Paths (Data Management Tools)
Summary
Repairs paths to source data for a trajectory dataset.
Usage
  • Trajectory datasets reference external files. When the referenced data is moved, the paths must be repaired to update the new reference location.
  • To change all of the paths in the trajectory dataset, use an asterisk (*) as the original path for the Paths List parameter.
Parameters
Label Explanation Data type
Trajectory Dataset
The input trajectory dataset.
Trajectory Layer
Paths List
A list of paths to remap.
Value table columns:
  • Original Path—The original paths stored in the trajectory dataset. Use an asterisk (*) to change all of the paths in the trajectory dataset.
  • New Path—The new dataset paths.
Value Table
Query Definition
(Optional)
An SQL expression that will limit the repairs to selected items in the trajectory dataset.
SQL Expression
Derived output
Trajectory Dataset Name
The updated trajectory dataset.
Trajectory Layer
Environments
Parallel Processing Factor
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
