Reconcile Versions (Data Management Tools)
Summary
Reconciles a version or multiple versions with a target version.
Learn more about how to reconcile and post versions
Usage
  • The reconcile process requires that you are the only user currently editing the version and the only user who will edit the version throughout the reconcile process until you save or post.
  • The reconcile process requires that you have full permissions to all the feature classes that have been modified in the version being edited.
  • This tool supports reconcile and post operations for data published from a branch workspace with version management capabilities enabled. Reconcile and post operations for branch versioning using a geodatabase connection file are not supported.
    License:
    When working with branch versioning in an ArcGIS Enterprise 11.2 or later deployment, organization members must be assigned a license for the ArcGIS Advanced Editing user type extension to use this tool.
Parameters
Label Explanation Data type
Input Workspace
The enterprise geodatabase that contains the versions to be reconciled.
For branch versioning, this will be the feature service URL (for example, https://mysite.mydomain/server/rest/services/ElectricNetwork/FeatureServer) or the feature layer portal item.
Workspace
Reconcile Mode
Specifies the versions that will be reconciled.
If the input is a branch workspace, the only valid option for this parameter is to reconcile all versions.
  • Reconcile all versions—Edit versions will be reconciled with the target version. This is the default.
  • Reconcile blocking versions only—Versions that are blocking the target version from compressing will be reconciled. This option uses the recommended reconcile order.
String
Target Version
(Optional)
The name of any version in the direct ancestry of the edit version, such as the parent version or the default version.
It typically contains edits from other versions that you want included in the edit version.
If the input is a branch workspace, the only valid option for this parameter is to reconcile with the default version.
String
Edit Versions
(Optional)
The name of the edit version or versions that will be reconciled with the selected target version.
Only versions that are in the direct ancestry of the selected target version will be displayed.
String
Acquire Locks
(Optional)
Specifies whether feature locks will be acquired.
This parameter is only applicable for a dataset that is registered as traditional versioned.
If the input is a branch workspace, locks are not acquired during the reconcile process.
  • Checked—Locks will be acquired during the reconcile process. Use this option when the intention is to post edits. It ensures that the target version is not modified in the time between the reconcile and post operations. This is the default.
  • Unchecked—Locks will not be acquired during the reconcile process. This allows multiple users to reconcile in parallel. Use this option when the edit version will not be posted to the target version because the target version may be modified in the time between the reconcile and post operations.
Boolean
Abort if Conflicts Detected
(Optional)
Specifies whether the reconcile process will end if conflicts are found between the target version and the edit version during the reconcile process.
  • Checked—The reconcile will end if conflicts are found.
  • Unchecked—The reconcile will not end if conflicts are found. This is the default.
Boolean
Conflict Definition
(Optional)
Specifies whether the conditions required for a conflict to occur will be defined by object (row) or by attribute (column).
  • Conflicts defined by object (by row)—Conflicts will be defined by object. Any changes to the same row or feature in the parent and child versions will conflict during reconcile. This is the default.
  • Conflicts defined by attribute (by column)—Conflicts will be defined by attribute. Only changes to the same attribute (column) of the same row or feature in the parent and child versions will be flagged as a conflict during reconcile. Changes to other attributes will not be considered a conflict during reconcile.
String
Conflict Resolution
(Optional)
Specifies the resolution that will be used if a conflict is detected.
If the input is a branch workspace, the default is to favor the edit version.
  • Resolve conflicts in favor of the target version—All conflicts will be resolved in favor of the target version. This is the default for traditional versioning.
  • Resolve conflicts in favor of the edit version—All conflicts will be resolved in favor of the edit version. This is the default for branch versioning.
String
Post Versions After Reconcile
(Optional)
Specifies whether the current edit session will be posted to the reconciled target version.
  • Checked—The current edit version will be posted to the target version after the reconcile.
  • Unchecked—The current edit version will not be posted to the target version after the reconcile. This is the default.
Boolean
Delete Versions After Post
(Optional)
Specifies whether the reconciled edit version will be deleted after posting. This parameter only applies when the Post Versions After Reconcile parameter is checked.
  • Checked—The current edit version that was reconciled will be deleted after being posted to the target version.
  • Unchecked—The current edit version that was reconciled will not be deleted. This is the default.
Boolean
Reconcile Versions Log
(Optional)
The name and location where the log file will be written. The log file is an ASCII file containing the contents of the geoprocessing messages.
File
Proceed if unreviewed conflicts are detected
(Optional)
Specifies whether the reconcile will proceed if existing unreviewed conflicts are detected before the reconcile process starts. If you proceed, existing conflicts from previous sessions will be lost when the tool runs. This parameter is only applicable to branch versioning.
  • Checked—The reconcile process will proceed if existing unreviewed conflicts are detected. This is the default.
  • Unchecked—The reconcile process will not proceed if existing unreviewed conflicts are detected.
Boolean
Reconcile checkout replica versions
(Optional)
Specifies whether the reconcile process will include checkout replica versions. If you are creating a checkout replica as part of a geodatabase replication workflow, an associated version is created in the geodatabase. This parameter allows you to include or remove these types of versions from the list of versions to be reconciled. This parameter is not applicable to branch versioning.
  • Checked—The reconcile process will include checkout replica versions. This is the default.
  • Unchecked—The reconcile process will not include checkout replica versions.
Boolean
Derived output
Updated Input Workspace
The updated input workspace.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: Limited
    Supported for branch versioning when using ArcGIS Enterprise named user licensing with a member that has the ArcGIS Advanced Editing user type extension.
  • Standard: Yes
  • Advanced: Yes
