Create Unregistered Feature Class (Data Management Tools)
Summary
Creates an empty feature class in an enterprise database, enterprise geodatabase, GeoPackage, or SQLite database. The feature class is not registered with the geodatabase.
Usage
  • This tool creates only simple feature classes such as point, multipoint, polygon, and polyline.
  • The empty feature class created by this tool will either have a field named OBJECTID of type integer or contain the same field names and types of any selected input template feature class.
  • Unregistered feature classes can be registered with the geodatabase using the Register With Geodatabase tool.
Parameters
Label Explanation Data type
Feature Class Location
The enterprise database or enterprise geodatabase in which the feature class will be created.
Workspace; Feature Dataset
Feature Class Name
The name of the feature class that will be created.
String
Geometry Type
(Optional)
Specifies the geometry type of the feature class. This parameter is only relevant for those geometry types that store dimensionality metadata, such as ST_Geometry in PostgreSQL, PostGIS Geometry, and Oracle SDO_Geometry.
  • Point—The geometry type will be point.
  • Multipoint—The geometry type will be multipoint.
  • Polyline—The geometry type will be polyline.
  • Polygon—The geometry type will be polygon. This is the default.
String
Template Feature Classes
(Optional)
An existing feature class or list of feature classes with fields and attribute schema that will be used to define the fields in the output feature class.
Feature Layer
Has M
(Optional)
Specifies whether the feature class will have linear measurement values (m-values).
  • No—The output feature class will not have m-values. This is the default.
  • Yes—The output feature class will have m-values.
  • Same as the template feature class—The output feature class will have m-values if the dataset specified in the Template Feature Class parameter (template parameter in Python) has m-values.
String
Has Z
(Optional)
Specifies whether the feature class will have elevation values (z-values).
  • No—The output feature class will not have z-values. This is the default.
  • Yes—The output feature class will have z-values.
  • Same as the template feature class—The output feature class will have z-values if the dataset specified in the Template Feature Class parameter (template parameter in Python) has z-values.
String
Spatial Reference
(Optional)
The spatial reference of the output feature dataset. On the Spatial Reference Properties dialog box, you can select, import, or create a new coordinate system. To set aspects of the spatial reference, such as the x,y-, z-, or m-domain, resolution, or tolerance, use the Environments dialog box.
Spatial Reference
Configuration Keyword
(Optional)
Specifies the default storage parameters (configurations) for geodatabases in a relational database management system (RDBMS). This setting is applicable only when using enterprise geodatabase tables.
Configuration keywords are set by the database administrator.
Learn more about configuration keywords
String
Derived output
Output Feature Class
The output unregistered feature class.
Feature Class
Environments
Current Workspace, Output CONFIG Keyword
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
