Validate Scene Layer (Data Management Tools)
Summary
Evaluates a scene layer package (*.slpk or *.i3sREST) in a cloud store to determine its conformity to I3S specifications.
Usage
This tool will validate scene layer content using the I3S specification to identify issues that may cause problems when viewing the scene layer in an ArcGIS client application. Consider running this tool before consuming or publishing a scene layer package generated outside of the ArcGIS platform.
The tool will identify the presence of the following:
Expected values for all required and recommended JSON objects
Declared textures for buildings, 3D objects, and integrated meshes
Declared attributes and associated statistics for points, buildings, 3D objects, and point clouds
Declared vertex attributes such as position, color, UV, and normals
Root nodes and declared child nodes in the node tree
The default output report is a readable
.jsonfile, but it can also be generated as a.txtor.xmlfile. The report lists warnings for issues that do not conform to the I3S specifications but may not cause a problem in displaying the data, and errors for issues that will cause problems in rendering the scene layer package.
Parameters
| Label | Explanation | Data type |
Input Scene Layer (Optional) |
The scene layer package ( |
File |
Output Log File |
The output log file that will summarize the results of the evaluation. |
File |
Input Folder (Optional) |
The scene layer content ( |
Folder |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
