Consolidate Project (Data Management Tools)
Summary
Consolidates an ArcGIS Pro project (.aprx file) and referenced maps and data into a folder.
Usage
  • The data and elements in the project will be consolidated and included in the .aprx file, including maps, the data referenced by the layers, toolboxes, styles, layouts, and connections when appropriate.
  • The Share outside of organization parameter controls whether the data referenced from networked resources will be consolidated into the folder.
    • Unchecked—Packages will be created for your internal environment, meaning the data will not be consolidated. Data stored on UNC paths, enterprise geodatabase layers, feature services, styles, and connections will remain referenced in the consolidated project.
    • Checked—All required data sources for the package will be copied to the consolidated folder. Items that would be unavailable outside your network—such as enterprise geodatabase connections, feature services, and data stored on shared folders—will be converted or copied to the output folder.
    Data and maps will be consolidated if the project references them from a local path, such as c:\gisdata\landrecords.gdb\, regardless of the Share outside of organization parameter value.
  • Templates can be created using the Consolidate as template parameter. You can use a project template to define layers, maps, and data, as well as required connections when creating a project.
    Learn more about creating a project template
  • Use the Analyze Tools For Pro and Analyze Toolbox for Version tools to analyze toolboxes that are part of a project before consolidation. Errors that are identified can stop the consolidation process. You must either fix the errors or remove the tool from the project.
  • Connections—such as folder, server, database, workflow, and data reviewer—will only be included in an internal package. These items will be removed if the package is created to be shared outside your organization.
  • Items such as attachments, styles, and tasks will be referenced for internal packages if they were part of the project from a UNC path. These items will be copied and packaged in all other situations.
  • For feature layers, use the Extent parameter to select the features that will be consolidated. For raster layers, use the Extent parameter to clip the raster datasets.
Parameters
Label Explanation Data type
Input Project
The project (.aprx file) that will be consolidated.
File
Output Folder
The output folder that will contain the consolidated project and data. If the specified folder does not exist, a folder will be created.
Folder
(Optional)
Specifies whether the project and all data will be consolidated into a single folder (for sharing outside your organization) or referenced to network data (for sharing within your organization).
  • Checked—Data stored on networked resources will be converted or copied into the package. The format of the data will be preserved when possible.
  • Unchecked—Data stored on networked resources such as enterprise geodatabases, feature services, and file shares (UNC path) will be referenced as is. The data will not be converted or included in the package. This is the default.
Boolean
Extent
(Optional)
Specifies the extent that will be used to select or clip features.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Intersection of Inputs Intersect—The extent will be the intersecting extent of all inputs.
  • Union of Inputs Union—The extent will be the combined extent of all inputs.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Apply Extent only to enterprise geodatabase layers
(Optional)
Specifies whether the extent will be applied to all layers or to enterprise geodatabase layers only.
  • Checked—The extent will be applied to enterprise geodatabase layers only.
  • Unchecked—The extent will be applied to all layers. This is the default.
Boolean
(Optional)
Specifies whether the project will be consolidated as a template or a regular project. Templates can include maps, layouts, connections to databases and servers, and so on. A project template allows you to standardize a series of maps for use in a project and ensure that the correct layers are immediately available for use.
  • Checked—The project will be consolidated as a template into a folder
  • Unchecked—The project will be consolidated as a project into a folder. This is the default.
Boolean
Preserve Mobile Geodatabase
(Optional)
Specifies whether mobile geodatabases will be preserved or converted to file geodatabases.
This parameter applies only to mobile geodatabases (.geodatabase) used primarily for offline workflows in ArcGIS Maps SDKs for Native Apps. SQLite databases with .sqlite or .gpkg file extensions will be converted to file geodatabases.
  • Checked—Mobile geodatabases will be preserved.
  • Unchecked—Mobile geodatabases will be converted to file geodatabases. This is the default.
Boolean
Version
(Optional)
Specifies the ArcGIS Pro version to which objects such as projects, maps, and layers will be persisted. Saving to an earlier version is useful if the project will be used with earlier versions of ArcGIS Pro.
A project saved to an earlier version may lose functionality or properties that are only available in later versions.
  • Current version—The contents of the consolidated folder will match the current version of the ArcGIS Pro release.
  • ArcGIS Pro 2.2—The contents of the consolidated folder will be ArcGIS Pro version 2.2.
  • ArcGIS Pro 2.3—The contents of the consolidated folder will be ArcGIS Pro version 2.3.
  • ArcGIS Pro 2.4—The contents of the consolidated folder will be ArcGIS Pro version 2.4.
  • ArcGIS Pro 2.5—The contents of the consolidated folder will be ArcGIS Pro version 2.5.
  • ArcGIS Pro 2.6—The contents of the consolidated folder will be ArcGIS Pro version 2.6.
  • ArcGIS Pro 2.7—The contents of the consolidated folder will be ArcGIS Pro version 2.7.
  • ArcGIS Pro 2.8—The contents of the consolidated folder will be ArcGIS Pro version 2.8.
  • ArcGIS Pro 2.9—The contents of the consolidated folder will be ArcGIS Pro version 2.9.
  • ArcGIS Pro 3.0—The contents of the consolidated folder will be ArcGIS Pro version 3.0.
  • ArcGIS Pro 3.1—The contents of the consolidated folder will be ArcGIS Pro version 3.1.
  • ArcGIS Pro 3.2—The contents of the consolidated folder will be ArcGIS Pro version 3.2.
  • ArcGIS Pro 3.3—The contents of the consolidated folder will be ArcGIS Pro version 3.3.
  • ArcGIS Pro 3.4—The contents of the consolidated folder will be ArcGIS Pro version 3.4.
  • ArcGIS Pro 3.5—The contents of the consolidated folder will be ArcGIS Pro version 3.5.
  • ArcGIS Pro 3.6—The contents of the consolidated folder will be ArcGIS Pro version 3.6.
  • ArcGIS Pro 3.7—The contents of the consolidated folder will be ArcGIS Pro version 3.7.
String
Keep only the rows that are related to features within the extent
(Optional)
Specifies whether the specified extent will be applied to related data sources.
  • Checked—Only related data corresponding to records within the specified extent will be consolidated.
  • Unchecked—Related data sources will be consolidated in their entirety. This is the default.
Boolean
Environments
Current Workspace, Parallel Processing Factor
Special cases
If the environment is not specified, the tool will use one half of the available cores.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
