Add Rule To Relationship Class (Data Management Tools)
Summary
Adds a rule to a relationship class.
A relationship class is created with one-to-one, one-to-many, or many-to-many cardinality. A relationship class can be defined in more restrictive terms by adding a rule to a relationship class. Once a rule is added to a relationship class, that rule becomes the only valid relationship that can exist. To make other relationship combinations and cardinalities valid, additional relationship rules must be added.
Usage
- If the relationship class is stored in an enterprise geodatabase, this tool can only be successfully run by the data owner.
Parameters
| Label | Explanation | Data type |
Input Relationship Class |
The relationship class to which a rule will be added. |
Origin Subtype (Optional) |
Specifies the subtype of the origin class. If the origin class has subtypes, choose the subtype to which you want to associate a relationship class rule. If the origin class has no subtypes, the relationship rule will apply to all features. |
String |
Origin Minimum (Optional) |
Specifies the minimum range cardinality for the origin class if the relationship class is many-to-many. |
Long |
Origin Maximum (Optional) |
Specifies the maximum range cardinality for the origin class if the relationship class is many-to-many or one-to-many. |
Long |
Destination Subtype (Optional) |
Specifies the subtype of the destination class. If the destination class has subtypes, choose the subtype to which you want to associate a relationship class rule. If the destination class has no subtypes, the relationship rule will apply to all features. |
String |
Destination Minimum (Optional) |
Specifies the minimum range cardinality for the destination class if the relationship class is many-to-many or one-to-many. |
Long |
Destination Maximum (Optional) |
Specifies the maximum range cardinality for the destination class if the relationship class is many-to-many or one-to-many. |
Long |
Derived output
Updated Relationship Class |
The updated relationship class with the relationship rule added. |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
