Register As Versioned (Data Management Tools)
Summary
Registers an enterprise geodatabase dataset as versioned.
Learn more about how to register data as branch versioned and traditional versioned.
Usage
  • Versioning tools only work with datasets in an enterprise geodatabase. File geodatabases don't support versioning.
  • The type of versioning used is determined by the database connection for the input dataset; Versioning Type is a property set in the Geodatabase Connection Properties dialog of a database connection. Learn how to set the versioning type using the geodatabase connection properties.
  • Registering a feature dataset as versioned registers all feature classes in the feature dataset as versioned.
  • The input dataset must be from a database connection established as the data owner.
  • Archive-enabled datasets cannot be registered as versioned. If you've already enabled archiving on your data but you also want to register your data as versioned, you must first disable archiving, register the data as versioned, and re-enable archiving.
    Once a dataset has been registered as branch versioned, the minimum client version for the dataset is ArcGIS Pro 2.1. This means that the dataset will no longer be available for use in ArcGIS Desktop.
Parameters
Label Explanation Data type
Input Dataset
The dataset to be registered as versioned.
Table View; Feature Dataset
Register the selected objects with the option to move edits to base
(Optional)
Specifies whether edits made to the default version will be moved to the base tables. This parameter is not applicable for branch versioning.
  • Checked—The dataset will be versioned with the option of moving edits to base.
  • Unchecked—The dataset will not be versioned with the option of moving edits to base. This is the default.
Boolean
Derived output
Updated Input Dataset
The updated input dataset.
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
