Build LAS Dataset Pyramid (Data Management Tools)
Summary
Constructs or updates a LAS dataset display cache, which optimizes its rendering performance.
Learn more about the LAS dataset pyramid
Usage
  • The tool creates a LAS dataset pyramid, which optimizes the rendering of multiple LAS files. It is only possible to construct a LAS dataset pyramid if the LAS dataset has an .lasd extension. The pyramid construction process does not support individual .las or .zlas files. Create a LAS dataset using the Create LAS Dataset tool.
  • The LAS dataset pyramid is stored in the same location as the LAS dataset: in a directory whose name begins with the name of the LAS dataset and ends with .slas. The pyramid typically occupies one-third of the overall size of the .las files referenced by the LAS dataset and is composed of multiple levels of progressively thinned LAS points. The points participating in each level are determined by binning the space where the points exist and selecting one point in each binned region using the point selection method.
  • The construction of the LAS dataset pyramid maximizes the use of available memory resources to speed up the operation. When a sufficient amount of RAM is not available, the required memory will be paged to disk. If possible, try to maximize free memory by exiting unnecessary applications before running this tool.
  • Temporary files that are approximately equal to half the size of the .las files or the uncompressed size of the .zlas files will be generated in the scratch workspace. Ensure that the scratch workspace is set to a location with a sufficient amount of storage space.
  • A LAS dataset with a pyramid includes a new schema that is not supported in ArcGIS Desktop or in ArcGIS Pro releases earlier than 2.6. If the LAS dataset is actively used in those applications, consider creating a duplicate of the LAS dataset using the Copy tool. Then build the pyramid on the duplicate dataset. The same .las files can be referenced by both LAS datasets. If the pyramids have already been built and the .las files need to be used in applications that do not support the pyramid, use the Create LAS Dataset tool to create a LAS dataset that references the same files. You don't need another copy of the source .las files; you need another LAS dataset with no pyramid.
  • This tool can be used to update an out-dated LAS dataset pyramid. The pyramid can become outdated by any of the following:
    • The addition of new .las or .zlas file references to the LAS dataset.
    • The removal of existing .las or .zlas file references from the LAS dataset.
    • Classification updates made through geoprocessing tools that were run without specifying the option for updating the LAS dataset pyramid. When performing a series of .las classification edits through multiple geoprocessing tools, consider using the option to update the LAS dataset pyramid on the final tool that will be run.
  • Once the LAS dataset pyramid has been constructed, the point selection method cannot be changed. To use a different point selection method, the existing pyramid must be deleted. This can be done using the Remove Files From LAS Dataset tool or from the Pyramid tab on the LAS Dataset Properties dialog box. To access the LAS Dataset Properties dialog box, right-click the LAS dataset in the Catalog pane or the Catalog view and choose the Properties option.
Parameters
Label Explanation Data type
Input LAS Dataset
The input LAS dataset.
LAS Dataset Layer
Point Selection Method
(Optional)
Specifies how the point in each binned region will be selected to construct the pyramid. This parameter is disabled if the LAS dataset contains a pyramid.
  • Lowest Point—The point with the lowest z-value will be selected.
  • Highest Point—The point with the highest z-value will be selected.
  • Closest to Center—The point that is closest to the center of the binned region will be selected.
  • Class Codes and Weights—The point with the highest weight value will be selected.
String
Input Class Codes and Weights
(Optional)
The weights assigned to each class code that determine which points will be retained in each thinning region. This parameter is only enabled when the Class Code Weights option is specified for the Point Selection Method parameter. The class code with the highest weight will be retained in the thinning region. If two class codes with the same weight exist in a given thinning region, the class code with the smallest point source ID will be retained.
Value table columns:
  • Class Code—The class code with the weight being assigned. This can be any value from 0 to 255.
  • Weight—The weight assigned to each class code. This can be any integer.
Value Table
Derived output
Output LAS Dataset
The updated LAS dataset.
LAS Dataset Layer
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Requires 3D Analyst or Spatial Analyst
  • Standard: Yes
  • Advanced: Yes
