Update Portal Dataset Owner (Data Management Tools)
Summary
Updates the portal owner of a dataset to another user.
Certain datasets in an enterprise geodatabase store the active portal user account as the owner of the dataset, in addition to the data owner. The owner is determined based on the active portal user when the dataset is created. This ownership is stored in the metadata of the dataset and is used to control access for administrative tasks on the dataset.
If the existing portal dataset owner leaves the organization, the portal owner must be changed to another user. This user should possess the same user type and privilege as the original owner.
The following are examples of a portal dataset owner:
Utility Network—Portal utility network owner
Trace Network—Portal trace network owner
Usage
The connected ArcGIS Enterprise portal account must be the portal owner of the dataset or a portal administrator.
The Input Dataset value must be from a branch versioned workspace.
The Input Dataset value must be from a database connection established as the data owner.
The Input Dataset value must be a utility network dataset or layer.
The Target User value must exist in the organization. If the user does not exist, it must be created as a new portal account.
Updating the portal owner of a dataset requires an exclusive lock. Any active connections locking the dataset (including services) must be closed.
Parameters
| Label | Explanation | Data type |
Input Dataset |
The input dataset for which the portal owner will be updated. |
Utility Network; Utility Network Layer; Trace Network; Trace Network Layer |
Target Owner |
The name of the portal user who will be the new portal owner of the dataset. |
String |
Derived output
Updated Dataset |
The input dataset with the updated portal owner. |
Utility Network Layer; Trace Network Layer |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
