Export Layouts (Data Management Tools)
Summary
Exports multiple layouts to a specified export format.
Usage
  • The export format file type and settings are specified in the Export Preset File parameter.
  • You can use the default export preset files that are used in the Export gallery or your own custom export preset files.
  • Use an export preset file with map series export settings to export the pages in a layout that has a map series enabled.
  • The Export Layouts tool can also be invoked in ArcGIS Pro by right clicking multiple layouts in the Catalog Pane and selecting Export to file.
Parameters
Label Explanation Data type
Input Layouts
The layouts to export. This parameter can accept layouts within an ArcGIS Pro project or a Layout file (.pagx).
String; Layout
Export Preset File
The export preset file (.xprt) that specifies the file type and settings for the export.
File
Output Folder
The folder where the output files will be written.
Folder
Derived output
Exported Files
The exported files.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
