Layout
Summary
The Layout object references a single-page layout in an ArcGIS Pro project (.aprx). It provides access to common properties such as page size and various export methods.
Discussion
An ArcGIS Pro project can contain multiple page layouts. Layouts are accessed using the listLayouts method on the ArcGISProject object and it returns a Python list of Layout objects. It is important to uniquely name each layout so a layout can be easily referenced by its name.
The listElements method provides access to all the elements on the page layout: GraphicElement, GroupElement, LegendElement, MapFrameElement, MapSurroundElement, PictureElement, TableFrameElement, and TextElement.
The Layout object is where you'll find access to various exportTo methods. Use the Layout export methods if you want to export the entire page layout. There is also a similar set of export methods on the MapFrame class, if you only want to export the contents of a single map frame.
A layout can contain a single MapSeries. If the mapSeries property returns None, a map series has not been created in the layout. You should also check to see whether the map series is enabled before attempting to manipulate its properties.
The createLayout method on the ArcGISProject object allows you to completely automate the creation of a layout. Once a layout exists, there are many additional creator methods for creating the different types of layout elements. The layout object has three create methods for creating elements that can only exist on a layout. They are createMapFrame, createMapSurroundElement, and createTableFrameElement. The ArcGISProject object includes more create methods that allow you to create elements in a layout or in a graphics layer in a map. Those methods are createGraphicElement, createGroupElement, createPictureElement, createPredefinedGraphicElement, and createTextElement.
The openView method allows you to open a new view pane of your layout. There are currently no ways to determine whether a view is already open or whether your layout view is active because views can't be queried. What you can do is use the closeViews method on the ArcGISProject object and call openView on your layout. This will open and activate your layout so that it has the area and focus you might want.
The openView and closeViews methods only work for scripts run from within the application. Stand-alone scripts can't access view panes.
Properties
| Name | Explanation | Data type |
colorModel (Read and Write) |
Returns the color model assigned to the |
String |
mapSeries (Read only) |
Returns a |
MapSeries |
metadata (Read and Write) |
Get or set the layout's Note:Setting metadata is dependent on the |
Metadata |
name (Read and Write) |
The layout's name. It is recommended that all layouts have a unique name so they can be easily referenced by name. |
String |
pageHeight (Read and Write) |
A layout's page height based on the current |
Double |
pageUnits (Read and Write) |
A layout's page units. Below is a list of valid strings when setting the page units.
String |
pageWidth (Read and Write) |
A layout's page width based on the current |
Double |
URI (Read only) |
The Universal Resource Indicator for a layout. It is a unique identifier for a layout in a project and is sometimes required when using Python CIM access. Once a layout is added and the URI is established, the value does not change over time. For example, if you modify the layout's name, the |
String |
Methods
changePageSize(page_width, page_height, {resize_elements})
The changePageSize method modifies the size of a layout.
The input size parameters are based on the layout's page_units value and the units cannot be changed.
page_width |
A double that indicates the width of a layout and is based on the |
Double |
page_height |
A double that indicates the height of a layout and is based on the |
Double |
resize_elements (Optional) |
Specifies whether the elements will be resized. If set to The default value is True. |
Boolean |
createBookmarkMapSeries(mapframe, {bookmarks[bookmarks,...]})
This method creates a new BookmarkMapSeries for a layout.
A bookmark map series page is created for each bookmark. Refer to the BookmarkMapSeries help topic for more information and code samples.
mapframe |
A |
MapFrame |
bookmarks[bookmarks,...] (Optional) |
A list of |
List |
Return value
| Data type | Explanation |
Object |
Returns a reference to the new |
createMapFrame(geometry, {map}, {name})
The createMapFrame method creates a MapFrame element in a layout.
A map frame does not have to be associated with a map when created and the default value is None. If the element is created using a point geometry, the point location will represent the anchor position and there will be a default size. Later you can resize the element using the elementWidth and elementHeight properties.
Refer to the MapFrame class help topic for more information and code samples.
geometry |
The appropriate |
Object |
map (Optional) |
The The default value is None. |
Map |
name (Optional) |
An optional string that represents the name of the new |
String |
Return value
MapFrame |
If a variable is provided, it will reference the newly returned |
createMapSurroundElement(geometry, mapsurround_type, {mapframe}, {style_item}, {name})
The createMapSurroundElement method creates a MapSurroundElement in a layout.
This method returns a reference to a new MapSurroundElement or LegendElement class. The default anchor position is dependent on the map surround type but can be changed after the new element is added to the layout using the setAnchor method.
Refer to the MapSurroundElement or LegendElement class help topics for more information and code samples.
geometry |
A |
Object |
mapsurround_type |
A string that represents the map surround element that will be created
String |
mapframe (Optional) |
MapFrame |
style_item (Optional) |
An optional reference to a |
String |
name (Optional) |
String |
Return value
MapSurroundElement |
createSpatialMapSeries(mapframe, index_layer, name_field, {sort_field})
This method creates a spatial MapSeries object for a layout.
A map series page is created for each feature in the index layer. See the MapSeries help topic for more information and code samples.
mapframe |
A |
MapFrame |
index_layer |
The index The default value is None. |
Layer |
name_field |
The field name of the field used to control the name of each page in the map series. Ideally, all field values are unique so each page can be uniquely identified. |
String |
sort_field (Optional) |
The name of the field that will be used to sort the map series pages. |
String |
Return value
MapSeries |
createTableFrameElement(geometry, {mapframe}, {table[table,...]}, {fields}, {style_item}, {name})
The createTableFrameElement method creates a TableFrameElement object in a layout.
If the element is created using a point geometry, the point location will represent the anchor position and the default size will be applied. You can resize the TableFrameElement object later using the elementWidth and elementHeight properties. The direction the element expands or reduces is based on the anchor position.
This method returns a reference to a new TableFrameElement class. Refer to the TableFrameElement class help topic for more information and code samples.
geometry |
A |
Object |
MapFrame |
table[table,...] (Optional) |
Object |
fields (Optional) |
A list of strings that represent the table field names to display in the table frame. If the default value of |
String |
String |
name (Optional) |
An optional string that represents the name of the new table frame element. If no name is provided, the default |
String |
Return value
Object |
deleteElement(element)
The deleteElement function deletes a layout element.
The item is permanently deleted from the layout. Deleting an element may have an impact on other items. For example, if you delete a map frame that is referenced by other map surrounds, those elements will be affected. To delete multiple elements, iterate through a specified list and delete one at a time.
If you are iterating through all elements, you must delete group elements in reverse order otherwise if you delete a parent group element and then attempt to delete a child group element, an error will occur because the reference to the child no longer exists.
element |
An object that represents a layout element to be deleted. |
Object |
export(export_format, {display_options})
The export method exports a Layout using a specified export_format.
Refer to the specific export format or the DisplayOptions help topics to learn more details and get code samples.
export_format |
The supported export format objects are: |
Object |
display_options (Optional) |
The |
Object |
exportToAIX(out_aix, {resolution}, {image_quality}, {compress_vector_graphics}, {image_compression}, {jpeg_compression_quality}, {embed_fonts}, {embed_color_profile}, {clip_to_elements}, {keep_layout_background}, {convert_markers})
Exports the Layout to Adobe Illustrator Exchange (AIX) format. AIX files can be used with the ArcGIS Maps for Adobe Creative Cloud extension or Adobe Illustrator.
Legacy:
This method is superseded by export at ArcGIS Pro 3.4 and only remains for use in legacy scripts. All enhancements and future development will only occur on the export method.
AIX is an Adobe Illustrator Exchange file exported from ArcGIS to be used with the ArcGIS Maps for Adobe Creative Cloud plug-in. When used with the plug-in, vector and raster map content is converted into editable, layered artwork for an improved editing experience in Adobe Illustrator. Once opened in Illustrator, it can be used for high-end graphic design or map finishing workflows and migrated across the other Adobe Creative Cloud applications.
out_aix |
A string that represents the path and file name for the output export file. |
String |
resolution (Optional) |
A number that defines the resolution of the export file in dots per inch (dpi). The default value is 300. |
Integer |
image_quality (Optional) |
A string that specifies output image quality, the draw resolution of map layers that draw as rasters.
The default value is BEST. |
String |
compress_vector_graphics (Optional) |
A Boolean that controls compression of vector and text portions of the output file. Image compression is defined separately. The default value is True. |
Boolean |
image_compression (Optional) |
A string that specifies the compression scheme used to compress image or raster data in the output file.
The default value is ADAPTIVE. |
String |
jpeg_compression_quality (Optional) |
A number that controls compression quality value when The default value is 80. |
Integer |
embed_fonts (Optional) |
A Boolean that controls the embedding of fonts in the export file. Font embedding allows text and character markers to be displayed correctly when the document is viewed on a computer that does not have the necessary fonts installed. The default value is True. |
Boolean |
embed_color_profile (Optional) |
Boolean |
clip_to_elements (Optional) |
If set to The default value is False. |
Boolean |
keep_layout_background (Optional) |
Boolean |
convert_markers (Optional) |
A Boolean that controls the conversion of character-based marker symbols to polygons. This allows the symbols to appear correctly if the symbol font is not available or cannot be embedded. However, setting this parameter to True disables font embedding for all character-based marker symbols, which can result in a change in their appearance. The default value is False. |
Boolean |
exportToBMP(out_bmp, {resolution}, {bmp_color_mode}, {bmp_image_compression}, {embed_color_profile}, {clip_to_elements})
Exports the Layout to the Microsoft Windows Bitmap format (BMP).
Legacy:
BMP files are native Windows raster images. BMP files can store pixel data at several bit depths. BMP images are typically much larger than formats such as JPEG or PNG.
out_bmp |
String |
A number that defines the resolution of the export file in dots per inch (dpi). The default value is 96. |
Integer |
bmp_color_mode (Optional) |
This value specifies the number of bits used to describe color.
The default value is 24-BIT_TRUE_COLOR. |
String |
bmp_image_compression (Optional) |
A string that specifies the compression scheme used to compress image or raster data in the output file. This option only applies to 8-bit
The default value is NONE. |
String |
Boolean |
Boolean |
exportToEMF(out_emf, {resolution}, {image_quality}, {output_as_image}, {clip_to_elements}, {convert_markers})
Exports the Layout to the Enhanced Metafile (EMF) format.
Legacy:
EMF files are native Windows graphics files that can contain a mixture of vector and raster data. They are useful for embedding in Windows documents because the vector portions of the EMF can be resized without loss of quality. However, since EMF does not support font embedding and is exclusively a Windows format, it is not commonly used as an interchange format between users.
out_emf |
A string that represents the system path and file name for the output export file. |
String |
Integer |
String |
output_as_image (Optional) |
Boolean |
Boolean |
Boolean |
exportToEPS(out_eps, {resolution}, {image_compression}, {image_quality}, {embed_fonts}, {output_as_image}, {clip_to_elements}, {convert_markers})
Exports the Layout to an Encapsulated PostScript (EPS) format file.
Legacy:
EPS files use the PostScript page description language to describe vector and raster objects. PostScript is the publishing industry standard for high-end graphics files, cartography, and printing. EPS files can be edited in many drawing applications or placed as a graphic in most page layout applications. EPS files support embedding of fonts so users who do not have Esri fonts installed can still view the proper symbology.
out_eps |
String |
Integer |
The default value is DEFLATE. |
String |
String |
Boolean |
Boolean |
Boolean |
Boolean |
exportToGIF(out_gif, {resolution}, {gif_color_mode}, {clip_to_elements})
Exports the Layout to Graphic Interchange Format (GIF).
Legacy:
GIF files are a legacy raster format for use on the web. GIF files cannot contain more than 256 colors (8 bits per pixel), which along with optional lossless compression, makes them smaller than other file formats.
out_gif |
String |
Integer |
gif_color_mode (Optional) |
The default value is 8-BIT_ADAPTIVE_PALETTE. |
String |
Boolean |
exportToJPEG(out_jpg, {resolution}, {jpeg_color_mode}, {jpeg_quality}, {embed_color_profile}, {clip_to_elements})
Exports the Layout to a Joint Photographic Experts Group (JPEG) format file.
Legacy:
JPEG files are compressed image files. They support 24-bit color and are a popular choice for use on the web because a JPEG file size is often substantially smaller than many other image formats. However, the JPEG compression algorithm is lossy and is not recommended for many map images, as line drawings, and text or icon graphics, become blurred by compression artifacts. Therefore, PNG is usually a superior format for map images.
out_jpg |
A string that represents the path and file name of the output export file. |
String |
Integer |
jpeg_color_mode (Optional) |
String |
jpeg_quality (Optional) |
This value (0–100) controls the amount of compression applied to the output image. With a JPEG image, quality is adversely affected the more compression is applied. A higher quality (highest = 100) setting will produce sharper images and larger file sizes. A lower quality setting will produce more image artifacts and smaller files. The default value is 80. |
Integer |
Boolean |
Boolean |
exportToPAGX(out_pagx)
Exports the Layout to a page file (.pagx).
This method is useful if you want to save a layout to a page file that can be imported later into a project using the ArcGISProject importDocument method.
out_pagx |
A string used to save a layout to a page file ( |
String |
exportToPDF(out_pdf, {resolution}, {image_quality}, {compress_vector_graphics}, {image_compression}, {embed_fonts}, {layers_attributes}, {georef_info}, {jpeg_compression_quality}, {clip_to_elements}, {output_as_image}, {embed_color_profile}, {pdf_accessibility}, {keep_layout_background}, {convert_markers}, {simulate_overprint})
Exports the Layout to Portable Document Format (PDF).
Legacy:
PDF files are designed to be consistently viewable and printable across various platforms. They are commonly used for distributing documents on the web, and the format is now an official ISO standard for document interchange. PDF files are editable in many graphics applications and retain map georeference information, annotation, labeling, and feature attribute data. PDF exports support embedding of fonts and can display symbology correctly even if the user does not have Esri fonts installed.
Review the PDFDocument class to learn more about how to manage PDF files, such as appending, inserting, and setting properties.
out_pdf |
String |
Integer |
String |
Boolean |
String |
Boolean |
layers_attributes (Optional) |
A string that specifies whether the PDF layer and PDF object data (attributes) will be included in the export file.
The default value is LAYERS_ONLY. |
String |
georef_info (Optional) |
A Boolean that enables the export of coordinate system information for each data frame into the output PDF file. The default value is True. |
Boolean |
Integer |
Boolean |
Boolean |
Boolean |
pdf_accessibility (Optional) |
Output a tagged PDF file where text can be read by screen readers or other assistive technology. A tagged PDF file can include alt text—a text description of a graphic element that a screen reader uses to describe the element—for map frames, pictures, and chart frames. The default value is False. |
Boolean |
If set to True, the white background will be included in the export. The default value is True. |
Boolean |
Boolean |
simulate_overprint (Optional) |
Sometimes called soft proofing, simulating overprinting shows a representation of how overlapping areas of ink will appear when printed on a page. You set up overprinting on symbol layers. The default value is False. |
Boolean |
exportToPNG(out_png, {resolution}, {color_mode}, {transparent_background}, {embed_color_profile}, {clip_to_elements})
Exports the Layout to a Portable Network Graphics (PNG) format file.
Legacy:
A PNG file is a versatile raster format file that can display in web browsers and be inserted into other documents. It supports high-bit-depth color and uses a lossless compression. For maps, PNG is often the best raster format, since the lossless compression keeps text and line work legible by preventing the compression artifacts that can occur in JPEG format. PNG files can also define a transparent color.
out_png |
String |
Integer |
The default value is 32-BIT_WITH_ALPHA. |
String |
transparent_background (Optional) |
Boolean |
Boolean |
Boolean |
exportToSVG(out_svg, {resolution}, {compress_to_svgz}, {image_quality}, {embed_fonts}, {output_as_image}, {clip_to_elements}, {convert_markers})
Exports the Layout to the Scalable Vector Graphics format (SVG).
Legacy:
SVG is an XML-based file format that has been specifically designed for viewing on the web. SVG can contain both vector and raster information. Some web browsers may require a plug-in to view SVG files. Older browsers may not be able to view SVG files at all. SVG supports font embedding, so users who do not have Esri fonts installed can still view SVG exports with proper symbology. You can also choose to produce compressed SVG files. The file extension changes to .svgz when this option is enabled.
out_svg |
String |
Integer |
compress_to_svgz (Optional) |
If set to True, the output is compressed. The default value is False. |
Boolean |
String |
Boolean |
Boolean |
Boolean |
Boolean |
exportToTGA(out_tga, {resolution}, {color_mode}, {transparent_background}, {clip_to_elements})
Exports the Layout to the Truevision Graphics Adapter format (TGA).
Legacy:
TGA files have historically been used for content that is meant to be used in other applications (for example, image sprites for animated games) and is read and written by many popular graphic arts applications. TGA format supports multiple bit depths including 32-bit with alpha (transparency) support.
out_tga |
String |
Integer |
String |
Boolean |
Boolean |
exportToTIFF(out_tif, {resolution}, {color_mode}, {tiff_compression}, {jpeg_compression_quality}, {transparent_background}, {embed_color_profile}, {clip_to_elements}, {world_file}, {geoTIFF_tags}, {georef_mapframe})
Exports the Layout to a Tagged Image File Format (TIFF) file.
Legacy:
TIFF files are the best choice for importing into image editing applications and are also a common GIS raster data format. However, they cannot be natively viewed by a web browser.
out_tif |
String |
Integer |
This value specifies the number of bits used to describe color. The available options are dependent on the specified Color Model set in the layout's Color Management properties.
String |
tiff_compression (Optional) |
This value represents a compression scheme.
The default value is LZW. |
String |
This value (0–100) controls the amount of compression applied to the output image. With a JPEG image, quality is adversely affected the more compression is applied. A higher-quality (highest = 100) setting will produce sharper images and larger file sizes. A lower-quality setting will produce more image artifacts and smaller files. The default value is 80. |
Integer |
Boolean |
Boolean |
Boolean |
world_file (Optional) |
Boolean |
geoTIFF_tags (Optional) |
Boolean |
georef_mapframe (Optional) |
The MapFrame used to control the coordinate system when The default value is None. |
MapFrame |
getDefinition(cim_version)
Gets a layout's CIM definition.
CIM-level access to additional object properties was introduced at ArcGIS Pro 2.4. When you want to return an object's CIM definition, you must specify a cim_version. Esri follows the semantic versioning specification. This means that at major releases—for example, 3.0—breaking API changes are allowed. This allows Python script authors control over which version of the CIM is used during a script run if there is a possibility breaking changes may be introduced in the new version. If you are authoring scripts for ArcGIS Pro 2.x, specify the cim_version to be 'V2'. If you are authoring scripts for ArcGIS Pro 3.x, specify the cim_version to be 'V3'. Scripts authored using cim_version 'V2' will continue to work in ArcGIS Pro 3.x.
For more information about working with the CIM and samples, see Python CIM access.
cim_version |
A string that represents the major version of the CIM. |
String |
Return value
Object |
Returns the CIM definition for a |
listElements({element_type}, {wildcard})
Returns a Python list of page layout elements that exist in a Layout object.
Each page element has a name property that can be set within the element properties dialog box. It is the layout author's responsibility to ensure each page element is given a unique name so that elements can be uniquely identified. If two elements have the same name, there is no way to ensure it is the element you want to reference.
The listElements method will return the elements within a group element into a flattened list. This makes it possible to easily search and replace text strings, for example, without having to navigate through a group element structure.
The element_type parameter can be skipped by passing in None or by including the parameter name for all parameters that follow the skipped parameter. For example:
elm = lyt.listElements(None, "Title")[0]
#or
elm = lyt.listElements(wildcard="Title")[0]
element_type (Optional) |
A string that represents the element type that will be used to filter the returned list of elements.
String |
wildcard (Optional) |
A wildcard is based on the element name and is not case sensitive. A combination of asterisks (*) and characters can be used to help limit the results. The default value is None. |
String |
Return value
List |
A Python list of page layout elements. The types of objects that can be returned are |
openView()
Opens and activates a new layout view pane in the application.
This is useful if the layout view is not already open or another view is active in the application. The method creates a layout view zoomed to its full extent and activates it. To close other, existing views before opening a new view, use the ArcGISProject closeViews method.
This method is designed to be run in the application using a script tool, Notebook, or the Python window. It will have no effect if run outside of the application.
setColorModel(color_model)
A string constant to set the color model associated with the Layout.
color_model |
Below is a list of valid strings.
String |
setDefinition(definition_object)
Sets a layout's CIM definition.
For more information about working with the CIM and samples, see Python CIM Access.
definition_object |
A modified CIM definition object originally retrieved using |
Object |
Code sample
The following script iterates through all layouts in the current project and prints basic information about each layout including name, page size and units, number of map frames, map frame names, and the total number of layout elements.
aprx = arcpy.mp.ArcGISProject('CURRENT')
print(f'Total Project Layout Count: {str(len(aprx.listLayouts()))} \n')
for lyt in aprx.listLayouts():
print(f'Layout Name: {lyt.name}')
print(f' Width x height: {lyt.pageWidth} x {lyt.pageHeight} units are {lyt.pageUnits}')
print(f' MapFrame count: {str(len(lyt.listElements("MapFrame_Element")))}')
for mf in lyt.listElements("MapFrame_Element"):
if len(lyt.listElements("MapFrame_Element")) > 0:
print(f' MapFrame name: {mf.name}')
print(f' Total element count: {str(len(lyt.listElements()))} \n')
The following script iterates through a list of layout names and exports each layout to PDF two times. The first export uses the default PDFFormat settings. The second export produces a much smaller output file because resolution, image_quality, and output_as_image properties on the PDFFormat object are set accordingly.
import arcpy, os
prjPath = r'C:\Projects\YosemiteNP'
p = arcpy.mp.ArcGISProject(os.path.join(prjPath, 'YosemiteTrails.aprx'))
layoutNames = ['Main Attractions', 'Scenic Views']
for lytName in layoutNames:
lyt = p.listLayouts(lytName)[0]
#export to PDF - default settings
pdf = arcpy.mp.CreateExportFormat('PDF', os.path.join(prjPath, 'Output', f'{lytName}_defaults.pdf'))
lyt.export(pdf)
#export to PDF - smaller file size
pdf.filePath = os.path.join(prjPath, 'Output', f'{lytName}_small.pdf')
pdf.setImageQuality("FASTEST")
pdf.outputAsImage = True
pdf.resolution = 72
lyt.export(pdf)
The following script creates a map and layout. It also creates a map frame, north arrow, and scale bar in the layout. A rectangle helper function is included for making the geometries needed for the map frame and scale bar. Finally, it ensures that the new layout is opened and activated in the application.
def MakeRec_LL(llx, lly, w, h):
xyRecList = [[llx, lly], [llx, lly+h], [llx+w,lly+h], [llx+w,lly], [llx,lly]]
array = arcpy.Array([arcpy.Point(*coords) for coords in xyRecList])
rec = arcpy.Polygon(array)
return rec
p = arcpy.mp.ArcGISProject('current')
#Create a new map and layout
m = p.createMap('New Map', 'MAP')
lyt = p.createLayout(8.5, 11, 'INCH')
#Create a map frame
mf = lyt.createMapFrame(MakeRec_LL(0.5,5.5,7.5,5), m, "New Map Frame")
#Create a north arrow
naStyle = p.listStyleItems('ArcGIS 2D', 'North_Arrow', 'Compass North 1')[0]
na = lyt.createMapSurroundElement(arcpy.Point(7,7), 'North_Arrow', mf,
naStyle, "Compass North Arrow")
na.elementWidth = 0.5
#Create a scale bar
sbName = 'Double Alternating Scale Bar 1 Metric'
sbStyle = p.listStyleItems('ArcGIS 2D', 'Scale_bar', sbName)[0]
sbEnv = MakeRec_LL(0.5, 5.5, 2.5, 0.5)
sb = lyt.createMapSurroundElement(sbEnv, 'Scale_bar', mf, sbStyle, 'New Scale Bar')
#Close all view and open and active the layout view
p.closeViews()
lyt.openView()
The following script shows different ways to use deleteElement. Note that to remove group elements that may exist inside of other group elements, you must delete group elements in opposite order because you must delete the child elements before the parent.
lyt = p.listLayouts('Layout')[0]
#Delete one element by name
elm = lyt.listElements('GRAPHIC_ELEMENT', 'Point')[0]
lyt.deleteElement(elm)
#Delete all the group elements and their children in reverse order
for elm in reversed(lyt.listElements('GROUP_ELEMENT')):
#Delete remaining elements
for elm in lyt.listElements():
The following script demonstrates how to use Python CIM Access to add guides to a layout. It creates four new guides 0.5 inches from the edges of the layout.
#CAUTION - this script will remove any existing guides
p = arcpy.mp.ArcGISProject('CURRENT')
for lyt in p.listLayouts():
lyt_cim = lyt.getDefinition('V3')
newGuides = []
#Bottom horizontal guide
botHorz = arcpy.cim.CreateCIMObjectFromClassName('CIMGuide', 'V3')
botHorz.position = 0.5
botHorz.orientation = 'Horizontal'
newGuides.append(botHorz)
#Top horizontal guide
topHorz = arcpy.cim.CreateCIMObjectFromClassName('CIMGuide', 'V3')
topHorz.position = lyt.pageHeight - 0.5
topHorz.orientation = 'Horizontal'
newGuides.append(topHorz)
#Left vertical guide
leftVert = arcpy.cim.CreateCIMObjectFromClassName('CIMGuide', 'V3')
leftVert.position = 0.5
leftVert.orientation = 'Vertical'
newGuides.append(leftVert)
#Right vertical guide
rightVert = arcpy.cim.CreateCIMObjectFromClassName('CIMGuide', 'V3')
rightVert.position = lyt.pageWidth - 0.5
rightVert.orientation = 'Vertical'
newGuides.append(rightVert)
#Add guides and make sure they are turned on
lyt_cim.page.guides = newGuides
lyt_cim.page.showGuides = True
#Set back to layer
lyt.setDefinition(lyt_cim)
