An overview of the Multidimension toolbox
The Multidimension toolbox contains tools that are used to create and manage netCDF, GRIB, HDF, OPeNDAP, Esri's CRF, multidimensional mosaic datasets, and multidimensional image services. You can use these tools to generate multidimensional metadata; create a multidimensional raster or feature layer (from netCDF files only), or table view (from netCDF files only); select a specific slice from a multidimensional dataset; or create a subset of a multidimensional raster dataset.
Tool |
Description |
Generates multidimensional metadata in the mosaic dataset, including information regarding variables and dimensions. |
Transposes a multidimensional raster dataset, which divides the multidimensional data along each dimension to optimize performance when accessing pixel values across all slices. |
Exports one or more isosurfaces from a voxel layer, scene layer package, or netCDF file. |
Creates a raster layer from a multidimensional raster dataset or a multidimensional raster layer by slicing data along defined variables and dimensions. |
Creates a voxel layer from a multidimensional voxel dataset. |
Creates a raster layer from data stored on an OPeNDAP server. |
Edits a multidimensional raster by adding or deleting variables or dimensions. |
Combines multiple multidimensional raster datasets spatially or across variables and dimensions. |
Updates the netCDF layer display or netCDF table view based on the dimension value. |
Creates a subset of a multidimensional raster by slicing data along defined variables and dimensions. |
The NetCDF toolset contains tools that process netCDF data and write to netCDF files.
Toolset |
Description |
The NetCDF toolset contains tools that operate on netCDF data. You can use these tools to make a netCDF raster layer, feature layer, or table view. You can also convert a feature, raster, or table to a netCDF file. |
