Make OPeNDAP Raster Layer (Multidimension Tools)
Summary
Creates a raster layer from data stored on an OPeNDAP server.
Usage
  • The performance of this tool depends on the speed of the remote OPeNDAP server and the robustness of the Internet connection between the machine executing the tool and the remote server.
  • To create a raster layer, the spacing of the x-coordinates must be equal and the spacing between the y-coordinates of the remote data must be equal. This is often referred to as regularly gridded data.
  • Use the Cell Registration parameter (cell_registration in Python) to specify how the extent of the netCDF raster layer will be computed from the x dimension and y dimension values. The cell size, number of rows, number of columns, and the width and height of the output raster remain the same, regardless of the option used.
Parameters
Label Explanation Data type
Input OPeNDAP URL
The URL that references the remote OPeNDAP dataset. The URL should resolve to the dataset level (for example, file name), not a directory name.
File; String
Variable
The variable from the OPeNDAP dataset that will be used to create the raster layer.
String
X Dimension
The dimension of the OPeNDAP dataset used to define the x, or longitude, coordinates of the output raster layer.
String
Y Dimension
The dimension of the OPeNDAP dataset used to define the y, or latitude, coordinates of the output raster layer.
String
Output Raster Layer
The name of the output raster layer.
Raster Layer
Extent
(Optional)
The output extent of the raster layer. Specify the extent coordinates in the units of the OPeNDAP data source (these could be latitude-longitude, projected coordinates, or some arbitrary grid coordinates). The purpose of this parameter is to allow subsetting to an area of interest or to reduce the size of the data that is transferred.
Envelope
Dimension Values
(Optional)
The starting and ending values of the dimensions or dimensions used to constrain which data will be extracted from the remote OPeNDAP server. By default, the minimum and maximum values of the dimension or dimensions will be used.
Value table columns:
  • Dimension—A netCDF dimension.
  • Start Value—The start value to use for the specified dimension.
  • End Value—The end value to use.
Value Table
Value Selection Method
(Optional)
Specifies the dimension value selection method that will be used.
  • By value—The input value will be matched with the actual dimension value.
  • By index—The input value will be matched with the position or index of a dimension value. The index is 0 based; that is, the position starts at 0.
String
Cell Registration
(Optional)
Specifies how the cells will be registered with respect to the x,y coordinate.
  • Center—The x,y coordinate represents the center of the cell. This is the default.
  • Lower Left—The x,y coordinate represents the lower left of the cell.
  • Upper Left—The x,y coordinate represents the upper left of the cell.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
