Multidimension toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Build Multidimensional Info
Version
2.8
New parameter added: delete_multidimensional_info
2.5
New at this version
Build Multidimensional Transpose
Version
2.7
New parameter added: delete_transpose
2.5
New at this version
Describe NetCDF File
Version
3.3
New at this version
Export Voxel Isosurface
Version
3.7
New at this version
Feature to NetCDF
Version
1.0
Ported from ArcMap 10.3
Make Multidimensional Raster Layer
Version
2.9
New parameter added: spatial_reference
2.6
New parameter added: dimensionless
2.5
New at this version
Make Multidimensional Voxel Layer
Version
3.2
New at this version
Make NetCDF Feature Layer
Version
1.0
Make NetCDF Raster Layer
Version
2.3
New parameter added: cell_registration
1.0
Make NetCDF Table View
Version
1.0
Make OPeNDAP Raster Layer
Version
2.3
1.1
New at this version
Manage Multidimensional Raster
Version
3.6
3 new parameters added:
  • min_value
  • dimension_def
  • max_value
Parameter manage_mode had new option added: REMOVE_SLICES
3.5
2 new parameters added:
  • truncation_unit
  • startEnd_keyword
Parameter manage_mode had new option added: TRUNCATE_DIMENSION_VALUES
2.7
New parameters added: update_statistics, update_transpose
2.6
New at this version
Merge Multidimensional Rasters
Version
2.7
New at this version
NetCDF Points To Feature Class (Discrete Sampling Geometry)
Version
3.1
New at this version
NetCDF Profiles To Feature Class (Discrete Sampling Geometry)
Version
3.0
New at this version
NetCDF Time Series To Feature Class (Discrete Sampling Geometry)
Version
3.0
New at this version
NetCDF Trajectories To Feature Class (Discrete Sampling Geometry)
Version
3.0
New at this version
Raster to NetCDF
Version
2.4
New parameter added: compression_level
1.0
Select by Dimension
Version
1.4
Parameter in_layer_or_table has new data type: Mosaic Layer
1.0
Subset Multidimensional Raster
Version
2.5
New at this version
Table to NetCDF
Version
1.0
