Make Multidimensional Raster Layer (Multidimension Tools)
Summary
Creates a raster layer from a multidimensional raster dataset or a multidimensional raster layer by slicing data along defined variables and dimensions.
Usage
  • This tool creates a multidimensional raster layer from a multidimensional raster or mosaic dataset by extracting a subset of variables. For example, you have a mosaic dataset that contains 30 years of monthly precipitation data, and you only want to extract data for each January to see how precipitation has changed for that month.
  • Supported multidimensional raster datasets include Cloud Raster Format (CRF), multidimensional mosaic datasets, or multidimensional raster layers generated by netCDF, GRIB, or HDF format files.
  • This tool generates a temporary layer that will not persist unless it's saved to disk.
  • Use the Dimension Definition parameter to slice dimensions using an interval, a value, or a range of values. For example, if you have 10 years of ocean salinity data, collected monthly and at every 2 meters depth up to 500 meters, you can use the different dimension definition options for the following scenarios:
    • Extract salinity data for the month of January over the 10-year period. Choose By Values, set Dimension to StdTime, and set Values to January.
    • Slice salinity data over a depth range from 0 to 150 meters. Choose By Ranges, set Dimension to StdZ, and set Minimum Value to -150 and Maximum Value to 0.
    • Extract salinity data for the first 10 days of January over a 10-year period. Choose By Iteration, set Dimension to StdTime, set Start of first iteration and End of first iteration to the corresponding start and end of the iteration period, set Step to 1, and set Unit to Years.
  • To create a nonmultidimensional layer that contains data from a single slice of the multidimensional raster, choose By Values for the Dimension Definition parameter, select a single dimension value, and check the Dimensionless parameter.
Parameters
Label Explanation Data type
Input Multidimensional Raster
The input multidimensional raster dataset.
Supported inputs are netCDF, GRIB, HDF, CRF, and Zarr files, a multidimensional mosaic dataset, a multidimensional image service, an OPeNDAP URL, or a multidimensional raster layer.
A Zarr file must have an extension of .zarr and a .zgroup file in the folder.
Raster Dataset; Raster Layer; Mosaic Dataset; Mosaic Layer; Image Service; File
Output Multidimensional Raster Layer
The output multidimensional raster layer.
Raster Layer
Variables
(Optional)
The variables that will be included in the output multidimensional raster layer. If no variable is specified, the first variable will be used.
String
(Optional)
Specifies the method that will be used to slice the dimension.
  • All—The full range for each dimension will be used. This is the default.
  • By Ranges—The dimension will be sliced using a range or a list of ranges.
  • By Iteration—The dimension will be sliced over a specified interval size.
  • By Values—The dimension will be sliced using a list of dimension values.
String
Range
(Optional)
The range or list of ranges for the specified dimension.
The data will be sliced based on the dimension name and the minimum and maximum values for the range. This parameter is required when the Dimension Definition parameter is set to By Ranges.
Value table columns:
  • Dimension—The dimension from which to extract ranges.
  • Minimum Value—The minimum value for the range.
  • Maximum Value—The maximum value for the range.
Value Table
Values
(Optional)
A list of values for the specified dimension. This parameter is required when the Dimension Definition parameter is set to By Values.
  • Dimension—The dimension from which to extract values.
  • Values—The specified dimension values.
Value Table
Dimension
(Optional)
The dimension along which the variables will be sliced. This parameter is required when the Dimension Definition parameter is set to By Iteration.
String
(Optional)
The beginning of the first interval. This interval will be used to iterate through the dataset. This parameter is required when the Dimension Definition parameter is set to By Iteration.
String
(Optional)
The end of the first interval. This interval will be used to iterate through the dataset. This parameter is required when the Dimension Definition parameter is set to By Iteration.
String
Step
(Optional)
The frequency with which the data will be sliced. This parameter is required when the Dimension Definition parameter is set to By Iteration.
Double
Unit
(Optional)
Specifies the iteration unit that will be used. This parameter is required when the Dimension Definition parameter is set to By Iteration and the Dimension parameter is set to StdTime.
  • Hours—The specified unit of time will be hours.
  • Days—The specified unit of time will be days.
  • Weeks—The specified unit of time will be weeks.
  • Months—The specified unit of time will be months.
  • Years—The specified unit of time will be years.
String
Extent
(Optional)
The extent (bounding box) of the layer. Choose the appropriate Extent option for the layer.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Dimensionless
(Optional)
Specifies whether the layer will have dimension values. This parameter is only enabled if a single slice is selected to create a layer.
  • Checked—The layer will not have dimension values.
  • Unchecked—The layer will have dimension values. This is the default.
Boolean
Spatial Reference
(Optional)
The coordinate system for the Output Multidimensional Raster Layer parameter value. This parameter only applies when the Input Multidimensional Raster parameter value is in Zarr format. Use this parameter to define the spatial reference if it is missing in the data.
Coordinate System
Environments
Cell Size, Compression, Current Workspace, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Extent, Parallel Processing Factor, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
