Subset Multidimensional Raster (Multidimension Tools)
Summary
Creates a subset of a multidimensional raster by slicing data along defined variables and dimensions.
Usage
  • This tool creates a multidimensional raster layer from a multidimensional raster or mosaic dataset by extracting a subset of variables. For example, you have a mosaic dataset that contains 30 years of monthly precipitation data, and you only want to extract data for each January to see how precipitation has changed for that month.
  • Supported multidimensional raster datasets include Cloud Raster Format (CRF), multidimensional mosaic datasets, or multidimensional raster layers generated by netCDF, GRIB, or HDF format files.
  • This tool produces a multidimensional raster dataset in Cloud Raster Format (CRF). Currently, no other output formats are supported.
  • Use the Dimension Definition parameter to slice dimensions using an interval, a value, or a range of values. For example, if you have 10 years of ocean salinity data, collected monthly and at every 2 meters depth up to 500 meters, you can use the different dimension definition options for the following scenarios:
    • Extract salinity data for the month of January over the 10-year period. Choose By Values, set Dimension to StdTime, and set Values to January.
    • Slice salinity data over a depth range from 0 to 150 meters. Choose By Ranges, set Dimension to StdZ, and set Minimum Value to -150 and Maximum Value to 0.
    • Extract salinity data for the first 10 days of January over a 10-year period. Choose By Iteration, set Dimension to StdTime, set Start of first iteration and End of first iteration to the corresponding start and end of the iteration period, set Step to 1, and set Unit to Years.
  • By default, the multidimensional raster output will be compressed using the LZ77 compression type. However, it is recommended that you change the compression type to LERC and adjust the maximum error value based on the data. For example, if you expect the results of the analysis to be accurate to three decimal places, use 0.001 for the maximum error value. Avoid unnecessary accuracy requirements, as they will increase the processing time and storage size.
    To change the compression type, modify the Compression environment setting.
Parameters
Label Explanation Data type
Input Multidimensional Raster
The input multidimensional raster dataset.
Supported inputs include netCDF, GRIB, HDF or CRF files, a multidimensional mosaic dataset, or a multidimensional raster layer.
Raster Dataset; Raster Layer; Mosaic Dataset; Mosaic Layer; Image Service; File
Output Multidimensional Raster
The output multidimensional raster dataset.
Raster Dataset
Variables
(Optional)
The variables that will be included in the output multidimensional raster. If no variable is specified, all of the variables will be used.
String
(Optional)
Specifies the method that will be used to slice the dimension.
  • All—The full range for each dimension will be used. This is the default.
  • By Ranges—The dimension will be sliced using a range or a list of ranges.
  • By Iteration—The dimension will be sliced over a specified interval size.
  • By Values—The dimension will be sliced using a list of dimension values.
String
Range
(Optional)
The range or list of ranges for the specified dimension.
The data will be sliced based on the dimension name and the minimum and maximum values for the range. This parameter is required when the Dimension Definition parameter is set to By Ranges.
Value table columns:
  • Dimension—The dimension from which to extract ranges.
  • Minimum Value—The minimum value for the range.
  • Maximum Value—The maximum value for the range.
Value Table
Values
(Optional)
A list of values for the specified dimension. This parameter is required when the Dimension Definition parameter is set to By Values.
  • Dimension—The dimension from which to extract values.
  • Values—The specified dimension values.
Value Table
Dimension
(Optional)
The dimension along which the variables will be sliced. This parameter is required when the Dimension Definition parameter is set to By Iteration.
String
(Optional)
The beginning of the first interval. This interval will be used to iterate through the dataset. This parameter is required when the Dimension Definition parameter is set to By Iteration.
String
(Optional)
The end of the first interval. This interval will be used to iterate through the dataset. This parameter is required when the Dimension Definition parameter is set to By Iteration.
String
Step
(Optional)
The frequency with which the data will be sliced. This parameter is required when the Dimension Definition parameter is set to By Iteration.
Double
Unit
(Optional)
Specifies the iteration unit that will be used. This parameter is required when the Dimension Definition parameter is set to By Iteration and the Dimension parameter is set to StdTime.
  • Hours—The specified unit of time will be hours.
  • Days—The specified unit of time will be days.
  • Weeks—The specified unit of time will be weeks.
  • Months—The specified unit of time will be months.
  • Years—The specified unit of time will be years.
String
Environments
Cell Size, Compression, Current Workspace, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Extent, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
