Feature to NetCDF (Multidimension Tools)
Summary
Converts point features to a netCDF file.
Usage
  • The default variable name is the same as the input feature field name specified in the Fields to Variables parameter (fields_to_variables in Python).
  • The type of variable is the same as the type of field.
  • Special fields Shape.X and Shape.Y are always available in the Fields to Variables drop-down list. They can be used for specifying variable names for x-coordinates and y-coordinates, respectively. If variable names are not specified or Shape.X and Shape.Y are not added to the list, the x- and y-coordinates are exported with default variable names. The default Variable names for Shape.X and Shape.Y are lon and lat, respectively, when the feature is in a geographic coordinate system. In all other cases, the default Variable names for Shape.X and Shape.Y are x and y, respectively.
  • Special fields Shape.Z and Shape.M are available in the Fields to Variables drop-down list for features with z- and m-values. To export z- and m-values, you must add Shape.Z and Shape.M to the list. The default Variable names for Shape.Z and Shape.M are z and m, respectively.
  • The default dimension name is the same as the input feature field name specified in the Fields to Dimensions parameter (fields_to_ dimensions in Python).
  • The size of a dimension is equal to the number of unique values in the respective field.
  • If no field is specified as a row dimension, a dimension RecordID value is created in the output netCDF file with a size equal to the number of features.
  • String fields cannot be used to create dimensions in the netCDF file.
  • When multiple fields are used to create dimensions in the netCDF file using the Fields to Dimensions parameter, the output netCDF file may become large in size. Ensure that there is enough space in the output location to avoid tool failure.
  • The tool writes variables as Discrete Sample Geometry (DSG), such as points or trajectory, following the CF conventions. Since, this data is not gridded, the variables in the output netCDF file are not suitable for creating a voxel layer.
Parameters
Label Explanation Data type
Input Features
The input point features.
Feature Layer
Fields to Variables
The field or fields that will be used to create variables in the netCDF file.
Four special fields—Shape.X, Shape.Y, Shape.Z, and Shape.M—can be used for exporting x-coordinates or longitude, y-coordinates or latitude, z-values, and m-values of input features, respectively.
Value table columns:
  • Field—A field in the input feature attribute table.
  • Variable—The netCDF variable name.
  • Units—The units of the data represented by the field.
Value Table
Output netCDF File
The output netCDF file. The file name must have an .nc extension.
File
(Optional)
The field or fields that will be used to create dimensions in the netCDF file.
  • Dimension—The netCDF dimension name.
Value Table
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
