Table to NetCDF (Multidimension Tools)
Summary
Converts a table to a netCDF file.
Usage
  • The default variable name is the same as the field name specified in the Fields to Variables (fields_to_variables in Python) parameter.
  • The type of variable is the same as the type of field.
  • The default dimension name is the same as the field name specified in the Fields to Dimensions (fields_to_dimensions in Python) parameter.
  • The size of a dimension is equal to the number of unique values in the respective field.
  • If no field is specified as dimension, then a dimension named RecordID is created in the output netCDF file.
  • String fields cannot be used to create dimensions in the netCDF file.
  • The tool writes variables either as Discrete Sample Geometry (DSG) such as points, or as gridded data following the CF conventions, depending on the fields specified in the Fields to Dimensions parameter.
    • If the default, non-geometry type fields are specified in Fields to Dimensions parameter, the tool writes variables as Discrete Sample Geometry (DSG) such as points or trajectory following the CF-convention. Since, these data are not gridded, the variables in the output netCDF file is not suitable for creating a voxel layer.
    • If the geometry type fields such as Shape.X and Shape.Y are specified as coordinate dimensions in Fields to Dimensions parameter, the tool writes variable as regularly spaced gridded data following the CF-convention. Therefore, the variable in the output netCDF file is suitable for creating a voxel layer.
Parameters
Label Explanation Data type
Input Table
The input table.
Table View
Fields to Variables
The field or fields that will be used to create variables in the netCDF file.
Value table columns:
  • Field—A field in the input feature attribute table.
  • Variable—The netCDF variable name.
  • Units—The units of the data represented by the field.
Value Table
Output netCDF File
The output netCDF file. The file name must have an .nc extension.
File
(Optional)
The field or fields that will be used to create dimensions in the netCDF file.
  • Field—A field in the input raster attribute table.
  • Dimension—The netCDF dimension name.
Value Table
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
