Build Multidimensional Info (Multidimension Tools)
Summary
Generates multidimensional metadata in the mosaic dataset, including information regarding variables and dimensions.
Usage
  • When you create a mosaic dataset from netCDF, GRIB, or HDF files, the multidimensional information is built into the mosaic dataset, and you can view the information in the dataset properties. The Build Multidimensional Info tool creates multidimensional information for a mosaic dataset that contains images collected at multiple times, depths, or heights, but was not created from netCDF files.
  • This tool creates the following two text fields in the mosaic dataset:
    • Variable—Stores the names of the variables. For example, this field will store the string Temperature for all the images with temperature data, and Salinity for all the images containing salinity data.
    • Dimensions—Stores the names of the dimensions. For example, if your temperature data has a corresponding Date dimension field representing the day it was captured, and your salinity data has a Depth dimension field representing the depth at which it was measured, the Dimensions field for that variable would be Date, Depth. The two fields, Date and Depth, must exist and be populated in the mosaic dataset.
  • The Build Multidimensional Info tool creates Variable, Dimensions, and StdTime (or StdZ) fields. Checking the Delete Multidimensional Info parameter deletes existing multidimensional information from the Properties window. It does not delete the multidimensional fields from the attribute or metadata tables.
    If the multidimensional fields are not needed, you can delete them manually from the mosaic dataset attribute table.
Parameters
Label Explanation Data type
Mosaic Dataset
The input multidimensional mosaic dataset.
Mosaic Layer
Variable Field
(Optional)
The field in the mosaic dataset that stores the variable names and is used to populate a new field named Variable. If all rasters in the mosaic dataset represent the same variable, type the name of the variable, for example, Temperature.
If the Variable field does not already exist, an existing field or string value must be specified. If the Variable field exists, the tool will update the multidimensional information only.
String
Dimension Fields
(Optional)
The fields in the mosaic dataset that store the dimension information and are used to populate a new field named Dimensions.
If the Dimensions field already exists, the tool will update the multidimensional information only.
Value table columns:
  • Dimension Field—The name of the dimension field.
  • Description—The description of the field.
  • Units—The units of the field values.
Value Table
Variable Info
(Optional)
Specify additional information about the Variable field.
  • Variable Name—The name of the variable field.
Value Table
(Optional)
Specifies whether existing multidimensional information will be deleted.
  • Checked—If multidimensional information exists in the mosaic dataset, it will be deleted.
  • Unchecked—If multidimensional information exists in the mosaic dataset, it will not be delete. This is the default.
Boolean
Derived output
Mosaic Dataset
The updated mosaic dataset.
Mosaic Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
