Merge Multidimensional Rasters (Multidimension Tools)
Summary
Combines multiple multidimensional raster datasets spatially or across variables and dimensions.
Usage
  • This tool creates a merged multidimensional raster dataset from a list of multidimensional rasters. For example, if you have a mosaic dataset that contains 30 years of monthly precipitation data and another dataset with 10 years of monthly temperature data, you can combine them into a multidimensional raster with both variables.
  • The tool supports input data in NetCDF format (.nc file).
  • If the input multidimensional rasters contain different variables, the output multidimensional raster will contain all the variables.
  • If the input multidimensional rasters contain different dimensions or dimension values, the output multidimensional raster will include all the dimensions and dimension values.
  • If the input multidimensional rasters contain the same dimensions and variables but different spatial extents, the output multidimensional raster will include the variables and dimensions across the merged spatial extents.
  • This tool produces a multidimensional raster dataset in Cloud Raster Format (CRF) or NetCDF format (.nc file).
Parameters
Label Explanation Data type
Input Multidimensional Rasters
The input multidimensional rasters to be combined.
Raster Dataset; Raster Layer; Mosaic Dataset; Mosaic Layer; Image Service; File
Output Raster
The merged multidimensional raster dataset in Cloud Raster Format (a .crf file) or NetCDF format (an .nc file).
Raster Dataset
Resolve Overlap Method
(Optional)
Specifies the method that will be used to resolve overlapping pixels in the combined datasets.
  • First—The pixel value in the overlapping areas will be the value from the first raster in the list of input rasters. This is the default.
  • Last—The pixel value in the overlapping areas will be the value from the last raster in the list of input rasters.
  • Minimum—The pixel value in the overlapping areas will be the minimum value of the overlapping pixels.
  • Maximum—The pixel value in the overlapping areas will be the maximum value of the overlapping pixels.
  • Mean—The pixel value in the overlapping areas will be the average of the overlapping pixels.
  • Sum—The pixel value in the overlapping areas will be the total sum of the overlapping pixels.
String
Environments
Cell Size, Compression, Current Workspace, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Extent, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
