LAS Dataset Statistics (Data Management Tools)
Summary
Calculates or updates statistics for a LAS dataset and generates an optional statistics report.
Usage
  • Computing statistics will create a spatial and attribute index that helps optimize display and analysis performance. Statistics also provide a more accurate estimate for average point spacing, and additional details about point attributes. The statistics are stored in a file with the same name as its corresponding LAS file, but ending in the .lasx extension.
  • Statistics enable filtering options for a LAS dataset layer to automatically display the available class codes and return values in the LAS files. The LAS dataset layer can be filtered through its Layer Properties dialog box or the Make LAS Dataset Layer tool.
  • The optional statistics report file provides an overview of LAS properties of all files in the LAS dataset or each individual LAS file in a text format that can be imported into any number of applications.
  • If a LAS file's classification codes or flags are modified, its statistics get invalidated and will need to be recomputed. Similarly, if a LAS dataset has new LAS file references added, it also will result in the statistics being invalidated.
Parameters
Label Explanation Data type
Input LAS Dataset
The LAS dataset that will be processed.
LAS Dataset Layer
Skip Existing
(Optional)
Specifies whether statistics will be calculated for all lidar files or only for those that do not have statistics:
  • Checked—LAS files with up-to-date statistics will be skipped, and statistics will only be calculated for newly added LAS files or ones that were updated since the initial calculation. This is the default.
  • Unchecked—Statistics will be calculated for all LAS files, including ones that have up-to-date statistics. This is useful if the LAS files were modified in an external application that went undetected by ArcGIS.
Boolean
Output Statistics Report Text File
(Optional)
The output text file that will contain the summary of the LAS dataset statistics.
Text File
Summary Level
(Optional)
Specify the type of summary contained in the report.
  • Aggregate Statistics for All Files—The report will summarize statistics for the entire LAS dataset. This is the default.
  • Statistics for Each LAS File—The report will summarize statistics for the LAS files referenced by the LAS dataset.
String
Delimiter
(Optional)
The delimiter that will be used to indicate the separation of entries in the columns of the text file table.
  • Space—A space will be used to delimit field values. This is the default.
  • Comma—A comma will be used to delimit field values. This option is not applicable if the decimal separator is also a comma.
String
Decimal Separator
(Optional)
The decimal character that will be used in the text file to differentiate the integer of a number from its fractional part.
  • Point—A point will be used as the decimal character. This is the default.
  • Comma—A comma will be used as the decimal character.
String
Derived output
Updated Input LAS Dataset
The updated LAS dataset.
LAS Dataset Layer
Environments
Current Workspace
Licensing information
  • Basic: Requires 3D Analyst or Spatial Analyst
  • Standard: Yes
  • Advanced: Yes
